Soaping slicks. Do you have a favorite?
#951873
03/16/11 11:21 AM
03/16/11 11:21 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
When running slicks without tubes and soaping the inside to help them not leak, do you have a soap that works better than the others? I'm taking the radials off the Challenger and going back to a regular slick, but plan to run them without tubes. So is there a special soap that works best?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Soaping slicks. Do you have a favorite?
[Re: Locomotion]
#951876
03/16/11 11:38 AM
03/16/11 11:38 AM
[Re: sg66mopar]
#951878
03/16/11 12:30 PM
03/16/11 12:30 PM
Posts: 642 New Jersey
Craig
New Jersey
I used dish soap when I first got my new Monocoque wheels and next time I changed the slicks the wheels were all pitted inside. Use a real tire lube, they are non-corrosive. I had Ballistol already on hand, and tire lube is one of its uses, so I used that. It works a lot better than soap too. I'm referring to mounting the tire, neither soap nor lube is going to seal a leaky tire/wheel.
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
[Re: Craig]
#951879
03/16/11 01:49 PM
03/16/11 01:49 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
The Hoosier dealer told me to use Joy dish soap and Joy only. I have had the tires on my car all winter in the cold garage -20 to -30 below at points and havent had to put air in them all winter! They are starting to look a little low but its been 7 months since I put air in them.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#951880
03/16/11 01:56 PM
03/16/11 01:56 PM
Jacob Pitt
Mansfield, Tx
Thanks for the tips, and thanks for the link Myron!
[Re: Cab_Burge]
#951882
03/16/11 05:44 PM
03/16/11 05:44 PM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: pittsburghracer]
#951885
03/16/11 08:45 PM
03/16/11 08:45 PM
Posts: 1,235 TN
65racer
2009 IHRA World Champion
TN
Have had my best results using Dawn, plus I like the lemony smell. Plus if you use any of those so called tire shine sprays, get ready to start putting air in your tires, that stuff soaks thru the sidewall, and they will start leaking, just like you never used anything to seal them up. AMHIK Dave
