Re: anyone install a JW ultra bell? [Re: SB412DUSTER] #951844
03/18/11 06:27 AM
03/18/11 06:27 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I also was thinking you can't use a JW bell with Ati case for the reasons mentioned. They mount the bells in different ways.
Re: anyone install a JW ultra bell? [Re: mac56] #951845
03/18/11 10:46 AM
03/18/11 10:46 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Look at Reid Racing (Dedenbear), they now offer their case and SB Mopar bellhousing #BH060.
http://www.reidracing.biz/TMcase.php
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: anyone install a JW ultra bell? [Re: Plumb Wired] #951846
03/18/11 10:57 AM
03/18/11 10:57 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
If your just wanting to attached a JW Ultra bell to a stock case, you can do it with brake lathe like above but we've done a ton of them with a Sawzall, it's not pretty but all your doing it cutting the stock bell out of the way so the ultra can mount to the pump bolts so you just cut it at a little bit of an angle. (the pump is mounted to a machined surface inside the tranny and the ultra bell mounts to the outside pump surface so don't need to be precise)
I know of 100s of them done that way, yea it's crude but it works just fine.
I run a JW Ultra case and Ultra bell now but ran stock cases for year without any trouble.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: anyone install a JW ultra bell? [Re: WadeMetzinger] #951847
03/18/11 05:30 PM
03/18/11 05:30 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I have never heard that the stock GM pump couldn't be used with the JW ultra bell. Is that like the input shaft has to be lined up with the hole in the bushing?
Re: anyone install a JW ultra bell? [Re: rowin4] #951848
03/18/11 08:17 PM
03/18/11 08:17 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I didn't see where that was said.
Re: anyone install a JW ultra bell? [Re: mac56] #951849
03/18/11 08:32 PM
03/18/11 08:32 PM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Loaded mine up in my buddies Bridgeport mill...worked real nice...still have the glide...sitting in the corner of the shop collecting dust...pm me...please...hint hint...lol
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: anyone install a JW ultra bell? [Re: mac56] #951850
03/19/11 01:09 AM
03/19/11 01:09 AM
rowin4 Offline
rowin4  Offline
what ya talking about? the GM pump or the hole lining up?
Re: anyone install a JW ultra bell? [Re: rowin4] #951851
03/19/11 07:49 AM
03/19/11 07:49 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Re: anyone install a JW ultra bell? [Re: SB412DUSTER] #951852
03/19/11 10:39 AM
03/19/11 10:39 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Actually the JW bell is designed to be used with their front pump for a powerglide, it has a raised edge that fits in the groove on the bell.
Right here mac?
Re: anyone install a JW ultra bell? [Re: moparguy7074] #951853
03/19/11 01:31 PM
03/19/11 01:31 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Right here mac?
I never said it could not be used with a stock GM pump.
I was answering Steve when he asked why it does not have some way to line it up to the transmission better, That was in reply # 6535457
Re: anyone install a JW ultra bell? [Re: SB412DUSTER] #951854
08/09/11 09:59 AM
08/09/11 09:59 AM
MN
mkvien Offline
mkvien  Offline
MN
Sorry to dig up an old thread, but this is the only one I see relating to this. I want to install one on a 727 behind a small block, I gether from the above that I can just hack the stock bellhousing off and bolt it on, doesn't have to be beautiful. Is that correct? I see them for as low as about $335, sound about right?
