Re: anyone install a JW ultra bell?
[Re: Plumb Wired]
#951846
03/18/11 10:57 AM
03/18/11 10:57 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
If your just wanting to attached a JW Ultra bell to a stock case, you can do it with brake lathe like above but we've done a ton of them with a Sawzall, it's not pretty but all your doing it cutting the stock bell out of the way so the ultra can mount to the pump bolts so you just cut it at a little bit of an angle. (the pump is mounted to a machined surface inside the tranny and the ultra bell mounts to the outside pump surface so don't need to be precise)
I know of 100s of them done that way, yea it's crude but it works just fine.
I run a JW Ultra case and Ultra bell now but ran stock cases for year without any trouble.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: mac56]
#951849
03/18/11 08:32 PM
03/18/11 08:32 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Loaded mine up in my buddies Bridgeport mill...worked real nice...still have the glide...sitting in the corner of the shop collecting dust...pm me...please...hint hint...lol
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: rowin4]
#951851
03/19/11 07:49 AM
03/19/11 07:49 AM
Posts: 976 ontario canada
mac56
ontario canada
I have never heard that the stock GM pump couldn't be used with the JW ultra bell.
[Re: SB412DUSTER]
#951852
03/19/11 10:39 AM
03/19/11 10:39 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Actually the JW bell is designed to be used with their front pump for a powerglide, it has a raised edge that fits in the groove on the bell.
Right here mac?
[Re: moparguy7074]
#951853
03/19/11 01:31 PM
03/19/11 01:31 PM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Right here mac?
I never said it could not be used with a stock GM pump. I was answering Steve when he asked why it does not have some way to line it up to the transmission better, That was in reply # 6535457
