Well I cant make up my mind on what to do about a camshaft. I need help making up my mind!!!!!
The car is a 69 barracuda
3.55 gears 26" tall drag radials
904 with coan 2800 stall, but may go 9.5 3500 stall if I dont like the 2800.
The engine is .030 360
9.4 to 1 but can go a little higher with a thinner head gasket if needed.
heads a 587 casting with 2.02 x 1.60 valves, with some portwork, cant find flow # but I do remember it flowed 240cfm at .050 on the intake, not much help ,but all I can remember.
Have m1 single plane intake but might go RPM
750 holley annular discharge boosters
1 5/8 headers and 2.5 exhaust
I was building it to run a comp xe268 but i think I would like to go bigger. I want something that is streetable, but not worried about vacuum, no power anything. Rough idle is good. wouls like to get close to 400hp. The car is not a daily driver, for cruises and strip. i will also be running a 100 shot of nitrous.
Please help me pick a cam so I can sleep at night!!!!
