help me pick a cam PLEASE!!??? #950737
03/14/11 07:33 PM
03/14/11 07:33 PM
mesa arizona
moturbopar Offline OP
mesa arizona
Well I cant make up my mind on what to do about a camshaft. I need help making up my mind!!!!!
The car is a 69 barracuda
3.55 gears 26" tall drag radials
904 with coan 2800 stall, but may go 9.5 3500 stall if I dont like the 2800.
The engine is .030 360
9.4 to 1 but can go a little higher with a thinner head gasket if needed.
heads a 587 casting with 2.02 x 1.60 valves, with some portwork, cant find flow # but I do remember it flowed 240cfm at .050 on the intake, not much help ,but all I can remember.
Have m1 single plane intake but might go RPM
750 holley annular discharge boosters
1 5/8 headers and 2.5 exhaust
I was building it to run a comp xe268 but i think I would like to go bigger. I want something that is streetable, but not worried about vacuum, no power anything. Rough idle is good. wouls like to get close to 400hp. The car is not a daily driver, for cruises and strip. i will also be running a 100 shot of nitrous.
Please help me pick a cam so I can sleep at night!!!!
help me pick a freakin cam so i can sleep!!
single choice
Votes accepted starting: 03/14/11 06:29 PM
You must vote before you can view the results of this poll.
Re: help me pick a cam PLEASE!!??? [Re: moturbopar] #950738
03/15/11 01:17 AM
03/15/11 01:17 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
i would use the mopar 284/528 solid !
Re: help me pick a cam PLEASE!!??? [Re: calrobb2000] #950739
03/15/11 01:59 AM
03/15/11 01:59 AM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
I would stick with the 268 comp cam you already have. It will have great power and won't be too big for your 360. I think that in this case less is more. You can always change it later!
Go to the Comp Cams website and download Cam Quest. It is a free program in which you enter all of your motor variables and then choose different cams and it will give you a dyno chart so you can see how much HP and TQ each cam will give at what RPM. Is is pretty accurate.
Good luck!
CAC
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: help me pick a cam PLEASE!!??? [Re: 69rrgrabber] #950740
03/15/11 05:20 PM
03/15/11 05:20 PM
mesa arizona
mesa arizona
Well it looks pretty even so far. I really like the .904 lobe cams, but I dont know if it would be worth the $$ to swap over now.
Re: help me pick a cam PLEASE!!??? [Re: moturbopar] #950741
03/15/11 09:11 PM
03/15/11 09:11 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
With 3.55 gear, 750 carb, 3500 stall, a short 26" tire and 100 hp shot.......
I'd go at least 230-235 @ .050 duration and a wide lobe center (LSA, for the N2O).
Re: help me pick a cam PLEASE!!??? [Re: Dean_Kuzluzski] #950742
03/15/11 10:13 PM
03/15/11 10:13 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: help me pick a cam PLEASE!!??? [Re: HYPER8oSoNic] #950743
03/16/11 03:28 AM
03/16/11 03:28 AM
mesa arizona
mesa arizona
My goal is mid to low 12s with the 100 shot.
Re: help me pick a cam PLEASE!!??? [Re: moturbopar] #950744
03/16/11 02:40 PM
03/16/11 02:40 PM
Central NC
gch Online content
gch  Online Content
Central NC
I would go with either the voodoo or the xe275hl.For motor only I would go with the rpm intake.With the giggle juice I like a single plane but at that level either will be fine.
For street driving it will be much more responsive down low/at part throttle with the rpm intake.
Re: help me pick a cam PLEASE!!??? [Re: gch] #950745
03/16/11 05:32 PM
03/16/11 05:32 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I could be wrong, but I don't think you're gonna be anywhere near 400 hp. It takes a pretty serious street mill to go over 1 hp. Per cube. 9:1 compression, Stock casting heads and smallish hydraulic FT cams usually don't get you there. A 100-shot in a 360 might get you as much as a full second, but with street friendly 3.55 gears, I think that still leaves you in the high-12, low-13 second range.
Hope I'm wrong, but if you want to see low 12's, I think you need more compression, deeper gearing, and I'd perhaps look at a solid lifter cam.
Re: help me pick a cam PLEASE!!??? [Re: StealthWedge67] #950746
03/16/11 06:39 PM
03/16/11 06:39 PM
mesa arizona
mesa arizona
I hope it will be faster than that! My old 2.3 turbocoupe ran 13.2 at 102, and 12.01 at 112 with a 75 shot. I will be pretty dissapointed if I cant get close to that. Anyways they are getting pretty good power out of this 360 https://board.moparts.org/ubbthreads/show...e=3#Post6526468
Re: help me pick a cam PLEASE!!??? [Re: moturbopar] #950747
03/17/11 09:53 PM
03/17/11 09:53 PM
mesa arizona
mesa arizona
Well looks like Im going to be ordering the voodoo 276 this weekend! I probably will be switching to 3.91s also. I think it will make for a fun car.
Re: help me pick a cam PLEASE!!??? [Re: moturbopar] #950748
03/24/11 02:14 PM
03/24/11 02:14 PM
mesa arizona
mesa arizona
well I havnt ordered any cams yet, but got another cam reccomendation from bullet cams
Its a solid lifter cam
GRIND CRA 270/270F106+4
MASTERS NF-62 NF-62
DUR @ .050 243/243
LIFT .548/.548
LSA 110
INT C/L 106
so what you all think?
Re: help me pick a cam PLEASE!!??? [Re: moturbopar] #950749
03/24/11 02:37 PM
03/24/11 02:37 PM
Cab_Burge Online work
Cab_Burge  Online Work
MASTERS NF-62 NF-62
DUR @ .050 243/243
LIFT .548/.548
LSA 110
INT C/L 106
That one should work real well in your car How is the traction now
