#949685 - 03/12/11 09:49 PM 4 Speed floor pan openings, torched or stamped?
MadMopars Offline
Loc: Tucson AZ,
I was just curious as to what means the factory used to section out a floor pan to accomadate 4 speeds. I just removed a floor hump from an A body floor pan (year unknown 67-69 maybe) and it appears as though the original opening in the floor pan was stamped as it has very sharp crisp lines. My Dad had mentioned he had removed a floor hump from a 69 B body years back and the opening in the floor pan appeared to have been cut out with a torch. He said it had the original black sealer around the floor hump and had stitch welds holding it in place both which seem correct to an original 4 speed car. I am curious as to what the factory method was for the cutting the floor pans for 4 speed applications. Torched or stamped? Anyone have some light to shed on this?
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
#949686 - 03/12/11 10:00 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: MadMopars]
dcr Offline
Loc: Muskegon Mi
My 64 coronet had a torched out hole and I dont believe chrysler was alone in doing that as i had a 75 camaro that was the same way.I did clean up the edges a bit .
#949687 - 03/12/11 11:08 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: dcr]
Frankenduster Offline
Moparts proctologist
Loc: Granite Bay CA
In 2007 I bought a 74 Duster from a local guy for $1500. This car was a real turd. I named it the ROACH. Wiring was a rats nest. 1/2" thick bondo over most of the LH quarter. Crappy pop up sunroof, Interior looked like a pack of badgers had a fight in there. NON running 318....but it was the FIRST V8 manual trans Duster that I ever saw for sale. I was mesmerized and I had to have it. I did everything to make the car right, then sold it and actually made a small profit. It was originally an automatic, but some scumbag converted it to a floor shifted 3 speed. When I pulled the floor hump to use in the FrankenDuster, I intended to use the floor cutaway as a pattern. Uhhhh... No, not a good idea. It looked like it was cut out with an axe. The floor hump barely covered the butchery.
#949688 - 03/12/11 11:37 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: Frankenduster]
1_WILD_RT Offline
Management Trainee
Loc: Today? Who Knows?
I see I'm not the only one thats seen this guys handiwork.... My 68 Coronet R/T vert was born a floor shifted auto... When the original owner blew the transmission apart with a 5000 rpm neutral drop he decided to upgrade to a 4spd... I'm not sure if he used a hatchet or a hand grenade but what ever it was it wasn't pretty..
#949689 - 03/12/11 11:38 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: 1_WILD_RT]
1_WILD_RT Offline
Management Trainee
I decided to go back to the floor shifted auto... so...
#949690 - 03/13/11 01:10 AM Re: 4 Speed floor pan openings, torched or stamped? [Re: 1_WILD_RT]
Loc: Granite Bay CA
Wow. You could have just patched the hole, but the lengths that you are going there are impressive. Thats the mark of a man with integrity.
#949691 - 03/13/11 10:44 AM Re: 4 Speed floor pan openings, torched or stamped? [Re: Frankenduster]
1_WILD_RT Offline
Management Trainee
I had the donor metal, it really isn't that hard to do it the way I did.. So why try to cheat... My Falcon wagon I might do a patch, a real deal Coronet R/T vert.. I'll do it right..
#949692 - 03/13/11 11:20 AM Re: 4 Speed floor pan openings, torched or stamped? [Re: 1_WILD_RT]
rattler Offline
Loc: Crofton, Ky.
I bought a 71 Barracuda vert several years back, the cars was an original console auto ,but some guy had changed it over to a 4-speed. When i pulled the console to figure out why you coudn't change gears, i found that he had used an "A" body trany and used the pivot bolt in the shifter to hold it to the side of the tunnel. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
#949693 - 03/13/11 11:34 AM Re: 4 Speed floor pan openings, torched or stamped? [Re: MadMopars]
440beep Offline
Loc: eganville ont
its was stamped in giant press
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
#949694 - 03/13/11 11:37 AM Re: 4 Speed floor pan openings, torched or stamped? [Re: Frankenduster]
JohnRR Offline
Loc: U.S.S.A.
This answers the question HOW ?
Along with the many after it ???
It should have been STAMPED out
#949695 - 03/13/11 08:37 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: JohnRR]
70440+6bbl Offline
Loc: NY
The early '60's cars were torched out. I'll dig out some '63 T85 car pics. Later were stamped.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
'70 'Cuda 340 4-spd 3.23SG N96 FC7
#949696 - 03/14/11 02:02 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: 70440+6bbl]
70440+6bbl Offline
Loc: NY
1963 hump cut-out... Very crudely done and I'm sure no two pans were the same
#949697 - 03/14/11 02:03 PM Re: 4 Speed floor pan openings, torched or stamped? [Re: 70440+6bbl]
70440+6bbl Offline
Loc: NY
From the top with the tunnel in place, it looks a-ok
25,250 Registered Members
188,890 Topics
First win of the season !!
by Gary Robbins
04/22/18 03:39 PM
Dome/ Dish volume known for 77 400 HP piston
by paironines
04/22/18 03:07 PM
FIRE !!!!!! truck nice
by azmopar
04/22/18 02:35 PM
1971 duster orange interior dye
by Purestocker
04/22/18 02:01 PM
