4 Speed floor pan openings, torched or stamped? #949685
03/13/11 12:49 AM
03/13/11 12:49 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I was just curious as to what means the factory used to section out a floor pan to accomadate 4 speeds. I just removed a floor hump from an A body floor pan (year unknown 67-69 maybe) and it appears as though the original opening in the floor pan was stamped as it has very sharp crisp lines. My Dad had mentioned he had removed a floor hump from a 69 B body years back and the opening in the floor pan appeared to have been cut out with a torch. He said it had the original black sealer around the floor hump and had stitch welds holding it in place both which seem correct to an original 4 speed car. I am curious as to what the factory method was for the cutting the floor pans for 4 speed applications. Torched or stamped? Anyone have some light to shed on this?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 4 Speed floor pan openings, torched or stamped? [Re: MadMopars] #949686
03/13/11 01:00 AM
03/13/11 01:00 AM
Muskegon Mi
dcr Offline
dcr  Offline
Muskegon Mi
My 64 coronet had a torched out hole and I dont believe chrysler was alone in doing that as i had a 75 camaro that was the same way.I did clean up the edges a bit .
Re: 4 Speed floor pan openings, torched or stamped? [Re: dcr] #949687
03/13/11 02:08 AM
03/13/11 02:08 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
In 2007 I bought a 74 Duster from a local guy for $1500. This car was a real turd. I named it the ROACH. Wiring was a rats nest. 1/2" thick bondo over most of the LH quarter. Crappy pop up sunroof, Interior looked like a pack of badgers had a fight in there. NON running 318....but it was the FIRST V8 manual trans Duster that I ever saw for sale. I was mesmerized and I had to have it. I did everything to make the car right, then sold it and actually made a small profit. It was originally an automatic, but some scumbag converted it to a floor shifted 3 speed. When I pulled the floor hump to use in the FrankenDuster, I intended to use the floor cutaway as a pattern. Uhhhh... No, not a good idea. It looked like it was cut out with an axe. The floor hump barely covered the butchery.
Re: 4 Speed floor pan openings, torched or stamped? [Re: Kern Dog] #949688
03/13/11 02:37 AM
03/13/11 02:37 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I see I'm not the only one thats seen this guys handiwork.... My 68 Coronet R/T vert was born a floor shifted auto... When the original owner blew the transmission apart with a 5000 rpm neutral drop he decided to upgrade to a 4spd... I'm not sure if he used a hatchet or a hand grenade but what ever it was it wasn't pretty..
Re: 4 Speed floor pan openings, torched or stamped? [Re: 1_WILD_RT] #949689
03/13/11 02:38 AM
03/13/11 02:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I decided to go back to the floor shifted auto... so...
Re: 4 Speed floor pan openings, torched or stamped? [Re: 1_WILD_RT] #949690
03/13/11 04:10 AM
03/13/11 04:10 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Wow. You could have just patched the hole, but the lengths that you are going there are impressive. Thats the mark of a man with integrity.
Re: 4 Speed floor pan openings, torched or stamped? [Re: Kern Dog] #949691
03/13/11 12:44 PM
03/13/11 12:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I had the donor metal, it really isn't that hard to do it the way I did.. So why try to cheat... My Falcon wagon I might do a patch, a real deal Coronet R/T vert.. I'll do it right..
Re: 4 Speed floor pan openings, torched or stamped? [Re: 1_WILD_RT] #949692
03/13/11 01:20 PM
03/13/11 01:20 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I bought a 71 Barracuda vert several years back, the cars was an original console auto ,but some guy had changed it over to a 4-speed. When i pulled the console to figure out why you coudn't change gears, i found that he had used an "A" body trany and used the pivot bolt in the shifter to hold it to the side of the tunnel. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 4 Speed floor pan openings, torched or stamped? [Re: MadMopars] #949693
03/13/11 01:34 PM
03/13/11 01:34 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
its was stamped in giant press
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 4 Speed floor pan openings, torched or stamped? [Re: Kern Dog] #949694
03/13/11 01:37 PM
03/13/11 01:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This answers the question HOW ?
Along with the many after it ???
It should have been STAMPED out
Re: 4 Speed floor pan openings, torched or stamped? [Re: JohnRR] #949695
03/13/11 10:37 PM
03/13/11 10:37 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
The early '60's cars were torched out. I'll dig out some '63 T85 car pics. Later were stamped.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 4 Speed floor pan openings, torched or stamped? [Re: 70440+6bbl] #949696
03/14/11 04:02 PM
03/14/11 04:02 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
1963 hump cut-out... Very crudely done and I'm sure no two pans were the same
Re: 4 Speed floor pan openings, torched or stamped? [Re: 70440+6bbl] #949697
03/14/11 04:03 PM
03/14/11 04:03 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
From the top with the tunnel in place, it looks a-ok
