Page 1 of 3 1 2 3
Ray Barton HEMI Rocker System: worth it? #948698
03/11/11 06:46 PM
03/11/11 06:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I was wondering if the Barton HEMI Rocker System (the one with the individual shafts) is really worth it over lets, say, a Stage V roller rockers system.
Thanks!
Domingo
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948699
03/11/11 08:18 PM
03/11/11 08:18 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Depends on cam lift and usage. The OEM style rocker gear has high side loads, and can be a pain to get oiling to the tips of the push rods. I generally have to replace the titanium lash caps each year. The guys running the Barton set-ups run more lift and rpm than I do with few issues. My cam is .780" lift with lots of spring pressure and I street it. If my heads could run them, I would.Stage V is really good, but I think the benifits from the newer design becomes a must at a certain point.
Re: Ray Barton HEMI Rocker System: worth it? [Re: Dragula] #948700
03/11/11 08:21 PM
03/11/11 08:21 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
right......besides, a nice roller setup with stage V roller rockers, hardened thick wall shafts, aluminum stands, etc isnt cheap as well....might as well go for the good stuff from the get go an be done with it!
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948701
03/11/11 08:23 PM
03/11/11 08:23 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
The Barton piece is made by T&D & is a beautiful piece. Expensive, but very nice...
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948702
03/11/11 09:12 PM
03/11/11 09:12 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I bought them, but my engine is so mild it didn't need them, that's for sure.
And NOBODY better complain about cost, as when I bought them the dollar was at 62 cents. I paid almost $5000 for my rockers.
O-U-C-H.
CrAzYMoPaRGuY
Re: Ray Barton HEMI Rocker System: worth it? [Re: CrAzYMoPaRGuY] #948703
03/11/11 09:17 PM
03/11/11 09:17 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Do you have to do any drilling or machine work to fit the Ray Barton individual rocker set up? They even look expensive.
Re: Ray Barton HEMI Rocker System: worth it? [Re: CrAzYMoPaRGuY] #948704
03/11/11 09:19 PM
03/11/11 09:19 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
O-U-C-H.
Now that is pretty
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948705
03/11/11 09:28 PM
03/11/11 09:28 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Hi!
Thanks!
Domingo
Short answer.....you don't "need" them for what you're building. Just buy a set of rockers that have a track record of keeping pushrod cups oiled sufficiently, and their ratios are close to the advertised numbers.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948706
03/11/11 09:32 PM
03/11/11 09:32 PM
ohio
6440nssa Offline
6440nssa  Offline
ohio
Money well spent, not a problem in five years.
sean dornan
Re: Ray Barton HEMI Rocker System: worth it? [Re: DusterDave] #948707
03/11/11 09:38 PM
03/11/11 09:38 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
Thanks!
Domingo
They will be for a 4,5 bore hemi,4,375 billet crank, stage V CNC raised exh port heads, pump gas.....want to shoot for 900 hp? maybe more if possible....
Domingo
Re: Ray Barton HEMI Rocker System: worth it? [Re: 6440nssa] #948708
03/11/11 09:39 PM
03/11/11 09:39 PM
rowin4 Offline
rowin4  Offline
If I got a set of those I would need to get a set of Charlie Westcott"s [ Hemi Mallitia ] see through valve covers.
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948709
03/11/11 10:06 PM
03/11/11 10:06 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
STAGE V-STAGE V-STAGE V if you gunna turn it 8,500 rpms plus then id go jessel hemi rockers.
MOPAR OR NO CAR
Re: Ray Barton HEMI Rocker System: worth it? [Re: rowin4] #948710
03/11/11 11:35 PM
03/11/11 11:35 PM
mogadore ohio 44260
racingblues1426 Offline
mogadore ohio 44260
I had to do some minor grinding to make them sit flat on a new set of stage V hemi head motor. They are the proverbial cat meow for a high (800 up) lift cam. Price must have went up--last set i bought was $3400.
Re: Ray Barton HEMI Rocker System: worth it? [Re: rowin4] #948711
03/12/11 12:25 PM
03/12/11 12:25 PM
Canada
Canada
Barton assembled mine, it's the first and only engine I've had built for me by somebody else.
Great looking rocker setup, but they obviously look exactly like every other rocker system once the valve covers are on....
CrAzYMoPaRGuY
Re: Ray Barton HEMI Rocker System: worth it? [Re: CrAzYMoPaRGuY] #948712
03/12/11 01:00 PM
03/12/11 01:00 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Time for some clear top valve covers.
Re: Ray Barton HEMI Rocker System: worth it? [Re: CrAzYMoPaRGuY] #948713
03/12/11 01:07 PM
03/12/11 01:07 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
You need a set of these for a Hemi!
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948714
03/12/11 01:07 PM
03/12/11 01:07 PM
hemigod426 Offline
hemigod426  Offline
member here is blowing out a set of t/d new hemi rockers on ebay now
MOPAR OR NO CAR
Re: Ray Barton HEMI Rocker System: worth it? [Re: domingo] #948715
03/12/11 02:08 PM
03/12/11 02:08 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Hi!
Thanks!
Domingo
YUP !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Ray Barton HEMI Rocker System: worth it? [Re: chryco] #948716
03/12/11 06:20 PM
03/12/11 06:20 PM
QLD Australia
Keith Black® Offline
QLD Australia
Great subject..
How would the T&D's compare vs the Jesels?
How would the Stage V's live, say in comparison, considering side-loading issues on valves? ...what would the expected reduction in valve guide/value wear life be?
Darren Beale
Keith Black Racing Engines®
Re: Ray Barton HEMI Rocker System: worth it? [Re: Keith Black®] #948717
03/12/11 06:22 PM
03/12/11 06:22 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Isnt stage v what every several thousen hp cars use?
Page 1 of 3 1 2 3
