472 Crate Hemi... What should I lookout for? #947170
03/09/11 04:52 PM
03/09/11 04:52 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I have a beat on a 472 crate hemi that has been sitting for about 3 years. It is new and has never been installed in a car. I have read about problems with these engines. What should I look for? The tough question.. What should I expect to pay for this? It's a completr engine from intake to pan...
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: 472 Crate Hemi... What should I lookout for? [Re: 68 Sat] #947171
03/09/11 05:02 PM
03/09/11 05:02 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
If it's a Cummins recon engine and it's cheap buy it , if it's not cheap do not waste your money because you'll need to COMPLETELY disassemble it and go thru everything , also note it has NO WARRANTY , that expired 90 days after it was purchased.
I have an 05ish vintage 426 and it's APART so I know what I am talking about .
Re: 472 Crate Hemi... What should I lookout for? [Re: 68 Sat] #947172
03/09/11 05:41 PM
03/09/11 05:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Depends on where it was sitting...in some guy's leaky garage? Then no warranty.
However if it's one of the four ACs left in Chrysler dealer inventory, MP will have to provide a normal 90 day 'parts only' warranty to the original purchaser, starting from the day the purchaser picks up the engine from the dealer, as stated in writing. If it is one of those, document the sale carefully and avoid ebay if at all possible.
Rich H.
Esse Quam Videri
Re: 472 Crate Hemi... What should I lookout for? [Re: ZIPPY] #947173
03/10/11 10:34 AM
03/10/11 10:34 AM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
it is a brand new engine bought in 2007 from Jegs. It looks to be stored in a clean garage and looks to have been oiled. With all I have read about 472 I am thinking I will have to tear it down anyway. All thoughts are appreciated...
Re: 472 Crate Hemi... What should I lookout for? [Re: 68 Sat] #947174
03/10/11 10:43 AM
03/10/11 10:43 AM
U.S.S.A.
U.S.S.A.
It's a Cummins recon , you will have to have the heads redone , guides are too tight , valve springs are bigger than locating step on the head and the locating lands on the retainers , I wwas able to move the spring around by hand with the valveclosed. They put a big blob of RED RTV around the big water ports on the head gaskets I had RTV inside at least 2 cylinders , the #1 exh pushrod was rubbing the head gasket , the #1 exhaust lifter didn't rotate very well when spinning the engine over by hand ... that's just off the top of my head. I have a friend that bought a 472 of that vintage , he had similar findings.
Re: 472 Crate Hemi... What should I lookout for? [Re: JohnRR] #947175
03/10/11 10:49 AM
03/10/11 10:49 AM
NY usa
540challenger Offline
NY usa
Lets not forget the extra hardware ofund in the valley by a member here The pric ebetter be dirt cheap like mentioned before b/c your going to must likely need to tear down a rebuild it good luck
Re: 472 Crate Hemi... What should I lookout for? [Re: 540challenger] #947176
03/10/11 10:58 AM
03/10/11 10:58 AM
U.S.S.A.
U.S.S.A.
Come on now , don't be hating on MP for the less than stellar product they put out ...
I missed that one , got a link ? I do remember one guy that had an intake valley pull of alum chips ...
Re: 472 Crate Hemi... What should I lookout for? [Re: JohnRR] #947177
03/10/11 11:19 AM
03/10/11 11:19 AM
NY usa
NY usa
I didn't save the link i will try to do a search it was a simliar thread topic like this one but i might be at least a year back
I have lost the battle with the search feature it is in your hands now
Re: 472 Crate Hemi... What should I lookout for? [Re: 68 Sat] #947178
03/10/11 11:47 AM
03/10/11 11:47 AM
PEI Canada
chromedome426 Offline
PEI Canada
I'm not sure on this, but I think starting in 2008 the Mopar Performance crate engines were made from brand new tooling and assembled by Ray Barton Racing and Gary Stanton Racing. Ray assembles the 528's and Gary assembles the 472's and 426's. I assume that the 2007 and earlier engines are the one's with known problems.
To see if it is made from the new tooling, check the front of the block for a frost plug on each side of the water pump. The older engines did not have frost plugs on the front.
