472 Crate Hemi... What should I lookout for?
#947170
03/09/11 04:52 PM
03/09/11 04:52 PM
Posts: 683 Northern NJ
68 Sat
Northern NJ
I have a beat on a 472 crate hemi that has been sitting for about 3 years. It is new and has never been installed in a car. I have read about problems with these engines. What should I look for? The tough question.. What should I expect to pay for this? It's a completr engine from intake to pan...
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor
1969 Dodge Coronet 500
1956 Desoto Hemi
1955 Chrysler C300
Re: 472 Crate Hemi... What should I lookout for?
[Re: 68 Sat]
#947172
03/09/11 05:41 PM
03/09/11 05:41 PM
Posts: 18,025 S.E. Michigan
ZIPPY
S.E. Michigan
Depends on where it was sitting...in some guy's leaky garage? Then no warranty.
However if it's one of the four ACs left in Chrysler dealer inventory, MP will have to provide a normal 90 day 'parts only' warranty to the original purchaser, starting from the day the purchaser picks up the engine from the dealer, as stated in writing. If it is one of those, document the sale carefully and avoid ebay if at all possible.
Rich H.
Esse Quam Videri
[Re: 68 Sat]
#947174
03/10/11 10:43 AM
03/10/11 10:43 AM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
it is a brand new engine bought in 2007 from Jegs. It looks to be stored in a clean garage and looks to have been oiled. With all I have read about 472 I am thinking I will have to tear it down anyway. All thoughts are appreciated...
It's a Cummins recon , you will have to have the heads redone , guides are too tight , valve springs are bigger than locating step on the head and the locating lands on the retainers , I wwas able to move the spring around by hand with the valveclosed. They put a big blob of RED RTV around the big water ports on the head gaskets I had RTV inside at least 2 cylinders , the #1 exh pushrod was rubbing the head gasket , the #1 exhaust lifter didn't rotate very well when spinning the engine over by hand ... that's just off the top of my head. I have a friend that bought a 472 of that vintage , he had similar findings.
[Re: JohnRR]
#947175
03/10/11 10:49 AM
03/10/11 10:49 AM
Posts: 2,826 NY usa
540challenger
NY usa
Lets not forget the extra hardware ofund in the valley by a member here The pric ebetter be dirt cheap like mentioned before b/c your going to must likely need to tear down a rebuild it good luck
[Re: 540challenger]
#947176
03/10/11 10:58 AM
03/10/11 10:58 AM
JohnRR
A gulag near you.
Come on now , don't be hating on MP for the less than stellar product they put out ...
I missed that one , got a link ? I do remember one guy that had an intake valley pull of alum chips ...
