Transmission drain plug #942942
03/04/11 09:41 PM
03/04/11 09:41 PM
Under My Car
Mopar_Country Offline OP
Under My Car
Anybody run one of the aftermarket drain plugs for the trans pan? I'm planning on installing a TF-2 in the next few weeks and thought I would throw one on the pan. Are there any to stay away from?
Re: Transmission drain plug [Re: Mopar_Country] #942943
03/04/11 10:57 PM
03/04/11 10:57 PM
I prefer to put it in the side rather than in the bottom as the ones I've seen hang a bit too low & a side mounted one will get enough fluid out so you can R&R the pan WO spillage & I want to ch the filter/adj the bands as opposed to just a fluid change and a side mounted one will not let all the fluid drain but a moot point as the pan is coming off. check the (side) location b 4 you drill so you wont hit the VB
Re: Transmission drain plug [Re: RapidRobert] #942944
03/05/11 06:35 AM
03/05/11 06:35 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Is it my bad luck or do they ALL leak?
Re: Transmission drain plug [Re: Kern Dog] #942945
03/05/11 08:00 AM
03/05/11 08:00 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
No leaks on mine.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Transmission drain plug [Re: Kern Dog] #942946
03/05/11 09:52 AM
03/05/11 09:52 AM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
no leaks on mine, we did put a little rtv on the threads to help ensure a seal.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Transmission drain plug [Re: blk00rt] #942947
03/05/11 12:04 PM
03/05/11 12:04 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I want to change the filter/adj the bands as opposed to just a fluid change.
This is why there is no drain plug. Made it necessary to drop the pan, might as well adjust bands and change filter. I am not saying don't use the plug, just why it wasn't there in the first place. Many people forget the transmission till it fails. Not as much of a problem with enthusiasts.
Re: Transmission drain plug [Re: bboogieart] #942948
03/05/11 12:06 PM
03/05/11 12:06 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Drain plugs are nice so you don't have all the fluid in there while trying to drop the pan.
Re: Transmission drain plug [Re: bboogieart] #942949
03/05/11 12:24 PM
03/05/11 12:24 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
No .... the reasonS why was .. primary one - way back when - was that some of the oil-change-monkeys were draining the trans INSTEAD of the engine ...and then filling UP the engine with oil.
Secondary ...was that it was cheaper to make the pan without a plug.
Re: Transmission drain plug [Re: dOc !] #942950
03/05/11 07:13 PM
03/05/11 07:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I agree with bboogieart, the reason for omitting the drain plug was to make sure the pan was removed at each fluid change...fleet cars/trucks got a drain plug because they thought fleet mechanics would do a better job of maintaining.
Re: Transmission drain plug [Re: Kern Dog] #942951
03/05/11 07:26 PM
03/05/11 07:26 PM
Under My Car
Under My Car
That's kinda what I am worried about.
Re: Transmission drain plug [Re: MI_Custumz] #942952
03/05/11 07:29 PM
03/05/11 07:29 PM
Under My Car
Under My Car
I agree, that's why I want one, I just want to make sure these aftermarket plugs don't leak, or which is the better one.
Re: Transmission drain plug [Re: Mopar_Country] #942953
03/05/11 07:46 PM
03/05/11 07:46 PM
hooziewhatsit Offline
I found a matching bolt and nut, then used a grinder to cut a groove in the bottom of the nut, and welded that to the inside of the pan.
I also found a nylon type washer that fit, so now the seal is between the bolt and the pan, and not the weld.
(Cutting the groove in the bottom of the nut allows complete drainage, vs just draining to the thickness of the nut)
Re: Transmission drain plug [Re: hooziewhatsit] #942954
03/05/11 09:09 PM
03/05/11 09:09 PM
Under My Car
Under My Car
That's a thought, you have no issues with the bolt loosening?
Re: Transmission drain plug [Re: Mopar_Country] #942955
03/05/11 09:40 PM
03/05/11 09:40 PM
Not yet at least
It does seep a little around the bolt though. I should try to find a better washer, but then I have to drain it
