Re: Transmission drain plug
[Re: Mopar_Country]
#942943
03/04/11 10:57 PM
03/04/11 10:57 PM
RapidRobert
I prefer to put it in the side rather than in the bottom as the ones I've seen hang a bit too low & a side mounted one will get enough fluid out so you can R&R the pan WO spillage & I want to ch the filter/adj the bands as opposed to just a fluid change and a side mounted one will not let all the fluid drain but a moot point as the pan is coming off. check the (side) location b 4 you drill so you wont hit the VB
[Re: Kern Dog]
#942946
03/05/11 09:52 AM
03/05/11 09:52 AM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
no leaks on mine, we did put a little rtv on the threads to help ensure a seal.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#942947
03/05/11 12:04 PM
03/05/11 12:04 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I want to change the filter/adj the bands as opposed to just a fluid change.
This is why there is no drain plug. Made it necessary to drop the pan, might as well adjust bands and change filter. I am not saying don't use the plug, just why it wasn't there in the first place. Many people forget the transmission till it fails. Not as much of a problem with enthusiasts.
[Re: bboogieart]
#942949
03/05/11 12:24 PM
03/05/11 12:24 PM
Posts: 30,448 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
No .... the reasonS why was .. primary one - way back when - was that some of the oil-change-monkeys were draining the trans INSTEAD of the engine ...and then filling UP the engine with oil.
Secondary ...was that it was cheaper to make the pan without a plug.
[Re: dOoC]
#942950
03/05/11 07:13 PM
03/05/11 07:13 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I agree with bboogieart, the reason for omitting the drain plug was to make sure the pan was removed at each fluid change...fleet cars/trucks got a drain plug because they thought fleet mechanics would do a better job of maintaining.
[Re: Kern Dog]
#942951
03/05/11 07:26 PM
03/05/11 07:26 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Is it my bad luck or do they ALL leak?
That's kinda what I am worried about.
[Re: MI_Custumz]
#942952
03/05/11 07:29 PM
03/05/11 07:29 PM
Mopar_Country
Under My Car
Drain plugs are nice so you don't have all the fluid in there while trying to drop the pan.
I agree, that's why I want one, I just want to make sure these aftermarket plugs don't leak, or which is the better one.
[Re: Mopar_Country]
#942953
03/05/11 07:46 PM
03/05/11 07:46 PM
Posts: 3,895 Oregon
hooziewhatsit
I found a matching bolt and nut, then used a grinder to cut a groove in the bottom of the nut, and welded that to the inside of the pan.
I also found a nylon type washer that fit, so now the seal is between the bolt and the pan, and not the weld.
(Cutting the groove in the bottom of the nut allows complete drainage, vs just draining to the thickness of the nut)
[Re: hooziewhatsit]
#942954
03/05/11 09:09 PM
03/05/11 09:09 PM
Mopar_Country
Under My Car
That's a thought, you have no issues with the bolt loosening?
