Who is the most Mopar-friendly custom cam grinder ... ? #94202
07/25/08 04:47 AM
07/25/08 04:47 AM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
I need a 2008-tech RV/towing cam made ... either a standard hyd or hyd roller. OR maybe there is a company that already makes a decent "shelf" item. I thought I remember seeing a list from a dealer or WD in Canada that had a very impressive listing - but I can not seem to find it now.
Anyone have a list of the most "friendly" companies? ..... someone that will not just throw a Chebbie grind at you.
And cost is a concern also ... but quality is the main concern.
Re: Who is the most Mopar-friendly custom cam grinder . [Re: dOrk !] #94203
07/25/08 07:51 AM
07/25/08 07:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
check with COMP
also ENGLE is known for making MOPAR lobe cams ...
but what do you call COST friendly ? you won't get a CUSTOM grind for what summit charges for their cam and lifter package
Re: Who is the most Mopar-friendly custom cam grinder . [Re: JohnRR] #94204
07/25/08 08:32 AM
07/25/08 08:32 AM
Cam Motion
Re: Who is the most Mopar-friendly custom cam grinder . [Re: dOrk !] #94205
07/25/08 09:27 AM
07/25/08 09:27 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Racer Brown AKA Jim Dowell.
Re: Who is the most Mopar-friendly custom cam grinder ... ? [Re: dOrk !] #94206
07/25/08 09:43 AM
07/25/08 09:43 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you really don't need a "fast rate .904 lifter" profile for rv/towing. the dreaded chebbie lobe will work fine and may last a lot longer.
Re: Who is the most Mopar-friendly custom cam grinder ... ? [Re: lewtot184] #94207
07/25/08 10:18 AM
07/25/08 10:18 AM
dogdays Offline
dogdays  Offline
Yeah, you really don't need it but it could help the engine to run strong with better torque and economy, so why not?
First you have to calculate the rpm at which you are most likely to spend most of your time. The torque peak needs to be close to that rpm. This will probably mean you will end up with an intake lobe of less than 210 degrees.
Then you need to know your real compression ratio, or as close as you can guess.
Next figure out what your intake and exhaust tracts will look like. Manifolds or headers?
Then call someone like Hughes or some of the board members who specialize in ordering custom grinds. I bet your cam will be close to an off-the-shelf cam with possibly a tweak in the LSA or change of an exhaust lobe. Contrary to popular belief, having a customized cam ground isn't all that expensive. And most of the major grinders will do it quickly. Comp advertises that they do. Don't forget Crower either.
R.
Re: Who is the most Mopar-friendly custom cam grinder ... ? [Re: dogdays] #94208
07/25/08 10:49 AM
07/25/08 10:49 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Erson
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Who is the most Mopar-friendly custom cam grinder . [Re: 5spdcuda] #94209
07/25/08 11:05 AM
07/25/08 11:05 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who is the most Mopar-friendly custom cam grinder . [Re: lewtot184] #94210
07/25/08 11:43 AM
07/25/08 11:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
nevermind the fact that if the lifter geometry isn't pretty much PERFECT you're looking at potential problems with the lifters eating the cam lobes , been there , bought the shirt .
Re: Who is the most Mopar-friendly custom cam grinder ... ? [Re: dOrk !] #94211
07/25/08 02:11 PM
07/25/08 02:11 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Engle is a good choice as well
Re: Who is the most Mopar-friendly custom cam grinder . [Re: JohnRR] #94212
07/25/08 02:16 PM
07/25/08 02:16 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
john, are we preaching to deaf ears?
Re: Who is the most Mopar-friendly custom cam grinder . [Re: lewtot184] #94213
07/25/08 05:38 PM
07/25/08 05:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what , on MOPARTS.COM ...
Re: Who is the most Mopar-friendly custom cam grinder . [Re: JohnRR] #94214
07/25/08 06:13 PM
07/25/08 06:13 PM
Florida STAYcation
dOrk ! Offline OP
dOrk !  Offline OP
Florida STAYcation
THX Guys ..... I am not as knowledgeable in cams as I should be ....
I called Comp Cams awhile back and he suggested a roller setup.....for $ 1,300.00 ! He was talking about a fast-rate, short-duration and high-lift.
Now if this HAS to be done ...I will do it .. because the return-on-investment on fuel econ can be very quickly done. PLUS ...I don't want to wind up on the side-of-the-road with a broken or wiped-out cam.
