Re: Who is the most Mopar-friendly custom cam grinder .
[Re: dOrk !]
#94203
07/25/08 07:51 AM
07/25/08 07:51 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
check with COMP
also ENGLE is known for making MOPAR lobe cams ...
but what do you call COST friendly ? you won't get a CUSTOM grind for what summit charges for their cam and lifter package
[Re: JohnRR]
#94204
07/25/08 08:32 AM
07/25/08 08:32 AM
[Re: lewtot184]
#94210
07/25/08 11:43 AM
07/25/08 11:43 AM
JohnRR
U.S.S.A.
you really don't need a "fast rate .904 lifter" profile for rv/towing. the dreaded chebbie lobe will work fine and may last a lot longer.
nevermind the fact that if the lifter geometry isn't pretty much PERFECT you're looking at potential problems with the lifters eating the cam lobes , been there , bought the shirt .
Re: Who is the most Mopar-friendly custom cam grinder ... ?
[Re: dOrk !]
#94211
07/25/08 02:11 PM
07/25/08 02:11 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I need a 2008-tech RV/towing cam made ... either a standard hyd or hyd roller. OR maybe there is a company that already makes a decent "shelf" item. I thought I remember seeing a list from a dealer or WD in Canada that had a very impressive listing - but I can not seem to find it now.
Anyone have a list of the most "friendly" companies? ..... someone that will not just throw a Chebbie grind at you.
And cost is a concern also ... but quality is the main concern.
Engle is a good choice as well
[Re: JohnRR]
#94212
07/25/08 02:16 PM
07/25/08 02:16 PM
Posts: 3,916 usa
lewtot184
usa
john, are we preaching to deaf ears?
[Re: lewtot184]
#94213
07/25/08 05:38 PM
07/25/08 05:38 PM
JohnRR
U.S.S.A.
what , on MOPARTS.COM ...
