440 Cam help #938857
02/27/11 10:54 AM
02/27/11 10:54 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I'm building a stock 69 440 for my Coronet.The cam I'm looking at is a Mopar Performance P4286677.
Specs are
Duration @ .050 inch lift 231int/231exh.
Advertised Duration 272int/272exh.
Intake and exhaust lift.455
Lobe Separation 112 degrees
Do you guys think this is a good cam?
Thanks in advance
Re: 440 Cam help [Re: 5carguy] #938858
02/27/11 11:25 AM
02/27/11 11:25 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The cam's actual 0.050" duration is 222. The 231, like every MP cam advertised specification @ 0.050" is wrong.
It is a good cam and will make more power than the factory original. I ran in the high 12s at 108 mph in a nearly stock 440 in my 4250 lb (at the time) Charger - no headers, no slicks, 3.23 gear and stock 12" converter.
I would use it again.
If you want a better - faster near stock cam, Contact Bob K.
Re: 440 Cam help [Re: BSB67] #938859
02/27/11 11:33 AM
02/27/11 11:33 AM
Central NC
gch Offline
gch  Offline
Central NC
I ran that cam in a 71 300 2dr with manifolds and 3.55 gears and it was very fun to drive.Lots of mid range and pulled well up to 5500 IIRC.Had a bit of idle but nothing lumpy by any means.
Re: 440 Cam help [Re: gch] #938860
02/27/11 11:35 AM
02/27/11 11:35 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I'm no big block expert, but that cam looks like a good pick to me.
It's Swifty! Swifty, you toad sucker!
Re: 440 Cam help [Re: zrxkawboy] #938861
02/27/11 11:51 AM
02/27/11 11:51 AM
south carolina U.S.
DOUGG Offline
DOUGG  Offline
south carolina U.S.
Absolutely great cam for completely stock set-up. Had one in a worn out 440 in 66 satellite, gobs of torque &good power to 5200-5500 rpm, low 13's in 1/4 mi. with 3.55's while starving for fuel at top of every gear.
Re: 440 Cam help [Re: DOUGG] #938862
02/27/11 12:08 PM
02/27/11 12:08 PM
Colorado
67plymouthman Offline
Colorado
In one of my cars I have a .484 purpleshaft with an RV converter and performer intake. It is a real nice steet set-up. Maybe a little to big if you want to go on long trips but for cruising it is nice. I hear the next one smaller (.474 I think) is nice also but I would go bigger than the cam you are asking about.
Re: 440 Cam help [Re: BSB67] #938863
03/06/11 07:39 PM
03/06/11 07:39 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 440 Cam help [Re: BSB67] #938864
03/06/11 07:55 PM
03/06/11 07:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
do you think that would mean a 280 MP cam ( rated at [Email]238@50[/Email] ) would be 228 or so ?
being proportional it looks it is... however I think somebody measured being 234@50
MP rule is 85% of the total duration is what is being rated as the 050 lift
Re: 440 Cam help [Re: HYPER8oSoNic] #938865
03/06/11 07:56 PM
03/06/11 07:56 PM
Connecticut, USA
sixty7gtx Offline
sixty7gtx  Offline
Connecticut, USA
here is my cam and it works great!!!
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: 440 Cam help [Re: 5carguy] #938866
03/06/11 08:01 PM
03/06/11 08:01 PM
Kirkland, Washington
Pacnorthcuda Offline
Specs are
Thanks in advance
Gear Ratio?
Rear tire size?
Auto or 4-speed?
If Auto, stock converter?
Stock exhaust?
You're picking a pretty mild cam, which may be fine, but you're also leaving some important variables unanswered
Re: 440 Cam help [Re: 5carguy] #938867
03/08/11 02:46 AM
03/08/11 02:46 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Would P4286677 be a better street cam than the factory original in 383 HP Roadrunner (4 spd, stock except for headers, 3.55 or so)?
If it made more power, would that power be higher up in the rpm range?
68 Roadrunner. 383 4-spd. Beat up.
Re: 440 Cam help [Re: Mebsuta] #938868
03/08/11 09:22 AM
03/08/11 09:22 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd go a little bigger. I ran the Summit 224/234 465/488 in a 67 GTX the only upgrade was the CH4B intake. Stock convert, manis, 3.55's and 2.5 exhuast and the car ran 13.80 on street tires. The best I got out of the stock cam was 14.20. Summit also sell a smaller cam that should work it's 214/224 442/465.
Coming soon!!!!
