440 Cam help
#938857
02/27/11 10:54 AM
02/27/11 10:54 AM
Posts: 2,405 Lee Co. Fla.
5carguy
Lee Co. Fla.
I'm building a stock 69 440 for my Coronet.The cam I'm looking at is a Mopar Performance P4286677. Specs are Duration @ .050 inch lift 231int/231exh. Advertised Duration 272int/272exh. Intake and exhaust lift.455 Lobe Separation 112 degrees Do you guys think this is a good cam? Thanks in advance
Re: 440 Cam help
[Re: gch]
#938860
02/27/11 11:35 AM
02/27/11 11:35 AM
Posts: 905 SD
zrxkawboy
SD
I'm no big block expert, but that cam looks like a good pick to me.
It's Swifty! Swifty, you toad sucker!
Re: 440 Cam help
[Re: zrxkawboy]
#938861
02/27/11 11:51 AM
02/27/11 11:51 AM
Posts: 92 south carolina U.S.
DOUGG
south carolina U.S.
Absolutely great cam for completely stock set-up. Had one in a worn out 440 in 66 satellite, gobs of torque &good power to 5200-5500 rpm, low 13's in 1/4 mi. with 3.55's while starving for fuel at top of every gear.
Re: 440 Cam help
[Re: HYPER8oSoNic]
#938865
03/06/11 07:56 PM
03/06/11 07:56 PM
Posts: 894 Connecticut, USA
sixty7gtx
Connecticut, USA
here is my cam and it works great!!!
1967 Plymouth GTX, 1968 HEMI, 4 Spd. Super Bee, 2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: 440 Cam help
[Re: 5carguy]
#938866
03/06/11 08:01 PM
03/06/11 08:01 PM
Posts: 21,839 Kirkland, Washington
Pacnorthcuda
Gear Ratio? Rear tire size? Auto or 4-speed? If Auto, stock converter? Stock exhaust?
You're picking a pretty mild cam, which may be fine, but you're also leaving some important variables unanswered
Re: 440 Cam help
[Re: 5carguy]
#938867
03/08/11 02:46 AM
03/08/11 02:46 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Would P4286677 be a better street cam than the factory original in 383 HP Roadrunner (4 spd, stock except for headers, 3.55 or so)?
If it made more power, would that power be higher up in the rpm range?
68 Roadrunner. 383 4-spd. Beat up.
