Re: Which intake should I use for my build? [Re: VITC_GTX] #937696
02/27/11 03:47 PM
02/27/11 03:47 PM
What are the drawbacks to advancing the cam?
just reduces the piston to valve clearance on one of the valves (in or ex) I forget which
Re: Which intake should I use for my build? [Re: RapidRobert] #937697
02/27/11 04:10 PM
02/27/11 04:10 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Reduces intake piston to valve clearance (intake is further open around TDC, closes intake valve sooner after BDC building more compression pressure.
Street wise mentioned the Crower 271HDP cam, that is what I have in the 383. If you were going to buy a new intake, the Performer RPM would be a good choice.
Re: Which intake should I use for my build? [Re: 451Mopar] #937698
02/27/11 04:20 PM
02/27/11 04:20 PM
Rochester, NY
Red63440 Offline
Red63440  Offline
Rochester, NY
Here is a test done on 12 intakes...read for yourself.
http://www.hotrod.com/techarticles/h...aro/index.html
68 Barracuda Fastback
Re: Which intake should I use for my build? [Re: Red63440] #937699
02/27/11 04:27 PM
02/27/11 04:27 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
383, short stroke, low compression, 3.23, low stall ALL equates to a sloooooooooow air/fuel response in the intake tract. Notta good idea.
An old DP4B aluminum intake is whatchya need.
I'd use the stock iron piece until you sell/trade the Torquer for a aluminum dual-plane.
Re: Which intake should I use for my build? [Re: 451Mopar] #937700
02/27/11 04:32 PM
02/27/11 04:32 PM
from that descrip I will b able to remem which is which
Re: Which intake should I use for my build? [Re: RapidRobert] #937701
02/27/11 05:49 PM
02/27/11 05:49 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
My 383 had the stock Iron 4bbl intake, then I switched to a Performer, then to a torker. Still run the torker on my 451. I never noticed any power loss or gain for that matter by switching intakes. Not on that motor. It was also a very low compression motor with the psi killing MP474 cam. Cranking psi was only 96-98. Still made 13.72 1/4 mile times with the 3.91's , 3000 stall and headers.
I'd just advance the Summit cam, Run the Torker and put in the 3.91's if you want to beat on it. Without tearing into the thing and getting the compression up with some quench, you'll most likely just be stirring the poop soup.
My 383 (attached picture) was a big mismatch of whatever I could find for cheap, the 4780 holley 800 probably was way too much but it ran fastest with that carb too. Intakes and carbs on big blocks are a one or two beer job so for now I'd just run what ya have.
Don
Re: Which intake should I use for my build? [Re: Streetwize] #937702
02/27/11 06:54 PM
02/27/11 06:54 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
my real preference would be the Crower 271HDP 224/234, .486/.496 but have it custom ground for a 108 centerline (std is 112) and put it in your motor +3 at 105, on paper it's similar specs to the Summit, but it's a much better mopar lobe and it makes a mild 383 run like a scalded dog
So you would recommend the the Crower custom ground at 108 LSA even for an automatic? I was under the impression that since he was running an automatic that he'd be better off with the wider powerband of the standard 112 LSA cam? What kind of difference in vacuum would you expect between the 112 and 108 versions of this cam?
Re: Which intake should I use for my build? [Re: Red63440] #937703
02/27/11 07:49 PM
02/27/11 07:49 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
im getting nothing from that but I will look it up
Re: Which intake should I use for my build? [Re: rss] #937704
02/27/11 10:40 PM
02/27/11 10:40 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
the Crower 271HDP cut on 108 is to me the hot ticket to really wake up a mild street 383, it's not a ton of duration so overlap is not an issue even with an automatic.
PM member Mopork, he took my recommendation of this exact cam and dropped it in his uber-sweet 383 71 coronet cop car, he's told me on more than one occassion he's VERY pleased with how that cam runs.
WIZE
In Car:
Re: Which intake should I use for my build? [Re: 10secGTX] #937705
02/27/11 10:48 PM
02/27/11 10:48 PM
Rochester, NY
Red63440 Offline
Red63440  Offline
Rochester, NY
Re: Which intake should I use for my build? [Re: MoparDonny] #937706
02/28/11 01:59 AM
02/28/11 01:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't recall if the vam was installed advanced or not?
The engine is at my parents house, maybe I'll go get it and check the installed CL.
I did not want to give the wrong impression, the cam made power, but my stock converter and 3.23:1 gears made it slow off the line although that may have been partly the way the engine was tuned. I was using the stock advance curve in the Mopar distrubitor. It seemed to have good power from 2,500-5,000 RPM. I later did replace the rear gears with 3.91:1 ratio and used a single plane intake, but then I accidently over reved the engine. Went from third to first and had the dumb shift kit option that lets you do first gear at any speed. I think it may have hit 8,000 RPM? Result was a few bent intake valves.
Re: Which intake should I use for my build? [Re: 451Mopar] #937707
02/28/11 01:50 PM
02/28/11 01:50 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
From what I have read the original Torker is a nice intake- dyno tests even shock the testers. And you ALREADY own one to boot. I think Edelbrock and Weiand use descriptions for chevy motors to describe products for all makes. Examples: 1. Weiand states their tunnel ram for the 440 is not suitable for the street- lack of low end. Many tunnel ram users find this to be wrong- one member here has one on his big Dodge truck and it is a powerhouse. BBC guys can not make the same testimonial- their tunnel rams are flat till about 4 grand. 2. Edelbrock states the Torker for the 440 is soft on the bottom end- not alot of low end but dyno testing has proved this to be untrue ON A BIG MOPAR- I am guessing on a BBC the low end is soft until 3 grand??? Many lump the Torker and Torker 2 in with a Team G and a Victor. They are not the same. Victor and Team G are large plenum serious race items.
Keep old mopars alive.
Re: Which intake should I use for my build? [Re: 2boltmain] #937708
02/28/11 05:34 PM
02/28/11 05:34 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
Since this subject has been raised...
I took an intake in on trade for some parts, I thought at first glance that it was a 383 Torker intake but it actually says...Edelbrock TM6 ...on it..
Is this the same as a Torker or????
Re: Which intake should I use for my build? [Re: GLR] #937709
02/28/11 09:33 PM
02/28/11 09:33 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
Different intake. Runners of the TM6 are larger than the Torker but at first glance they look very sinilar. Click on the link someone gave above from HRM for more info. Here's some pics from the archive: http://www.moparts.org/Tech/Archive/bb/14.html
Re: Which intake should I use for my build? [Re: forphorty] #937710
02/28/11 11:20 PM
02/28/11 11:20 PM
MoparDonny Offline
MoparDonny  Offline
The TM6 ,and RB version TM7 are both very good intakes. At a quick glance they are almost identical to a Torker.
Here's a TM7.
Re: Which intake should I use for my build? [Re: MoparDonny] #937711
02/28/11 11:26 PM
02/28/11 11:26 PM
MoparDonny Offline
MoparDonny  Offline
And my Current Torker 383.
