Wilwood Dana rear brakes?
#936810
02/24/11 11:37 PM
02/24/11 11:37 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I just got front Wilwood for the Arrow from a sponsor..yea...and was thinking of replacing the Dana drums with Wilwood also. One issue...I have 5/8th's studs and from what I read the Wilwood kit is drilled for .52 . Can I drill the hat larger? Anyone ever have this problem?..Should I just buy Strange?...I really wanted to keep them all the same. I'll probably just run the drums for awhile but when I catch up on some funds I'd love to ditch them..freakin' heavy stuff Thanks for any input...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Wilwood Dana rear brakes?
[Re: Eric]
#936811
02/24/11 11:40 PM
02/24/11 11:40 PM
Buy Strange, Wilwoods suck. They'll go on in 30 minutes with no issues at alol.
[Re: Eric]
#936813
02/25/11 12:14 AM
02/25/11 12:14 AM
Posts: 1,169 MI
68shifter
MI
I have Wilwood on the back of my cuda. I had to drill out for the 5/8 stud and also send the hats off to have the centers opened up. They were smaller than the axle and wouldn't sit flat on the face of the axle - Strange 35 spline pro-race gun drilled and star flanged, dana 60. Other than that I love them over the drum.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: 68shifter]
#936816
02/25/11 12:38 AM
02/25/11 12:38 AM
Posts: 2,054 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I have Strange on both ends of my 'cuda, and Strange on the front with Wilwood on the rear of my Daytona, The Wilwood hat is thicker (approx 1/2" compared to Strange 1/8") and I had to drill them to fit the 5/8" drive lugs. I personally like the Strange 1 piece hat and rotor better because its lighter and it doesn't have the bolts holding the hat and rotor together to deal with (must safety wire). Other than that, a lot of people use them and like them. ****A word of caution, no matter who's set up you use, always safety wire the bolts that attach the caliper to the bracket and on Wilwoods, safety wire the bolts that attach the rotor to the hat. DAMHIK ***** Brian Dunnigan
[Re: 70blackfish]
#936824
02/25/11 04:49 PM
02/25/11 04:49 PM
Eric
Pittsburgh PA
I figure front and rear would take 70-80# off the car..Plus the crappy rolling resistance of the Mustang II stuff thats on the front now....Should put the car below 2100# empty easy.
[Re: blownzoom440]
#936828
02/27/11 06:10 AM
02/27/11 06:10 AM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
When I put the Wilwood rear disc brakes on my Daytona with a Dana 60, I had to drill out the hats for the 5/8 drive studs in the Strange axles. I used a Unibit to drill them out. I also had to space the axles out to center the rotor in the mount.
dont you shim the calliper to fit the rotor spacing?
Wilwood supplies thin shim washers to better center the caliper and on the pro-street brakes you can also mill down or add shim washers between the flange mount and caliper bracket.
