Wilwood Dana rear brakes? #936810
02/24/11 11:37 PM
02/24/11 11:37 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
I just got front Wilwood for the Arrow from a sponsor..yea...and was thinking of replacing the Dana drums with Wilwood also. One issue...I have 5/8th's studs and from what I read the Wilwood kit is drilled for .52 . Can I drill the hat larger? Anyone ever have this problem?..Should I just buy Strange?...I really wanted to keep them all the same. I'll probably just run the drums for awhile but when I catch up on some funds I'd love to ditch them..freakin' heavy stuff Thanks for any input...
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Wilwood Dana rear brakes? [Re: Eric] #936811
02/24/11 11:40 PM
02/24/11 11:40 PM
Buy Strange, Wilwoods suck.
They'll go on in 30 minutes with no issues at alol.
Re: Wilwood Dana rear brakes? #936812
02/24/11 11:41 PM
02/24/11 11:41 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Great...I just opened the box for the fronts.
Re: Wilwood Dana rear brakes? [Re: Eric] #936813
02/25/11 12:14 AM
02/25/11 12:14 AM
MI
68shifter Offline
68shifter  Offline
MI
I have Wilwood on the back of my cuda. I had to drill out for the 5/8 stud and also send the hats off to have the centers opened up. They were smaller than the axle and wouldn't sit flat on the face of the axle - Strange 35 spline pro-race gun drilled and star flanged, dana 60.
Other than that I love them over the drum.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Wilwood Dana rear brakes? [Re: 68shifter] #936814
02/25/11 12:25 AM
02/25/11 12:25 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Re: Wilwood Dana rear brakes? [Re: Eric] #936815
02/25/11 12:36 AM
02/25/11 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont recall drilling mine and I have 5/8 studs
Re: Wilwood Dana rear brakes? [Re: 68shifter] #936816
02/25/11 12:38 AM
02/25/11 12:38 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have Strange on both ends of my 'cuda, and Strange on the front with Wilwood on the rear of my Daytona, The Wilwood hat is thicker (approx 1/2" compared to Strange 1/8") and I had to drill them to fit the 5/8" drive lugs. I personally like the Strange 1 piece hat and rotor better because its lighter and it doesn't have the bolts holding the hat and rotor together to deal with (must safety wire).
Other than that, a lot of people use them and like them.
****A word of caution, no matter who's set up you use, always safety wire the bolts that attach the caliper to the bracket and on Wilwoods, safety wire the bolts that attach the rotor to the hat. DAMHIK *****
Brian Dunnigan
Re: Wilwood Dana rear brakes? #936817
02/25/11 12:59 AM
02/25/11 12:59 AM
QLD Australia
Keith Black® Offline
QLD Australia
I have Wilwoods no problems here.
Darren Beale
Keith Black Racing Engines®
Re: Wilwood Dana rear brakes? [Re: Keith Black®] #936818
02/25/11 01:33 AM
02/25/11 01:33 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
I love my wilwoods. I drilled my hats out for the larger studs and yes you must safety wire the hat attachment bolts and caliper bolts. No biggie. Beep
Re: Wilwood Dana rear brakes? [Re: Bigbeep] #936819
02/25/11 01:38 AM
02/25/11 01:38 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I have Wilwoods on rear with 5/8 studs and didnt drill them or have to open the center....?
Re: Wilwood Dana rear brakes? [Re: DaKuda] #936820
02/25/11 04:57 AM
02/25/11 04:57 AM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
Eric, order them from wilwood and have them set them up for the 5/8 studs.
Re: Wilwood Dana rear brakes? [Re: 68valiant68] #936821
02/25/11 08:35 AM
02/25/11 08:35 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We drill them out all the time with no issues. I like the thicker hats
Re: Wilwood Dana rear brakes? [Re: 68valiant68] #936822
02/25/11 08:40 AM
02/25/11 08:40 AM
pa
572charger Offline
572charger  Offline
pa
eric ive got wilwoods on my charger, fts since 2003 and installad the rears pro street brakes with parking brake in 2008,ive got 5/8studs on the rear, dont remember drilling out the rotors? i got the kits from summit dont remember any problems installing them at all and they work awesome street and strip p.s ive got a wilwood master cylinder and adj proportioning valve : also
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Wilwood Dana rear brakes? [Re: 572charger] #936823
02/25/11 04:47 PM
02/25/11 04:47 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
from drum to rear aerospace disc, was 50lbs lighter.
Re: Wilwood Dana rear brakes? [Re: 70blackfish] #936824
02/25/11 04:49 PM
02/25/11 04:49 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
I figure front and rear would take 70-80# off the car..Plus the crappy rolling resistance of the Mustang II stuff thats on the front now....Should put the car below 2100# empty easy.
Re: Wilwood Dana rear brakes? [Re: Eric] #936825
02/25/11 05:16 PM
02/25/11 05:16 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Eric......I lost 16# on my Dart going from 11" drums to Wilwoods with the internal parking brake. The race brake would probably 5#-10# lighter yet.
Re: Wilwood Dana rear brakes? [Re: justinp61] #936826
02/25/11 11:08 PM
02/25/11 11:08 PM
Pottstown, Pa.
sg1093 Offline
sg1093  Offline
Pottstown, Pa.
When I put the Wilwood rear disc brakes on my Daytona with a Dana 60, I had to drill out the hats for the 5/8 drive studs in the Strange axles. I used a Unibit to drill them out. I also had to space the axles out to center the rotor in the mount.
Re: Wilwood Dana rear brakes? [Re: sg1093] #936827
02/26/11 10:55 AM
02/26/11 10:55 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
dont you shim the calliper to fit the rotor spacing?
Re: Wilwood Dana rear brakes? [Re: blownzoom440] #936828
02/27/11 06:10 AM
02/27/11 06:10 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Wilwood supplies thin shim washers to better center the caliper and on the pro-street brakes you can also mill down or add shim washers between the flange mount and caliper bracket.
