New cam zinc oil? #934875
02/22/11 11:36 AM
02/22/11 11:36 AM
SE Kansas
I
indytex96 Offline OP
I
SE Kansas
Getting ready to break in a new summit cam on a 440 and was wondering what I should use for oil to get the zinc thats needed, or would it be better to get the additive? Thanks!
Re: New cam zinc oil? [Re: indytex96] #934876
02/22/11 12:44 PM
02/22/11 12:44 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I installed a Hughes cam 2 months ago. 15W40 Valvoline Premium Blue heavy duty diesel (dino) oil with Redline zinc additive. After break in I drained and put the same oil and zinc additive back in with a new filter. Everything is just fine.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: New cam zinc oil? [Re: Junky] #934877
02/22/11 12:53 PM
02/22/11 12:53 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Often I read people suggesting one to
"just" run a roller valvetrain but roller components are soo expensive. Id love to be able to buy all the stuff but it comes out like so: $300 for a cam- $300 for lifters- $300-$400 for adj Rocker arms ($80 for BETTER adjusters) and around $90 for pushrods. In the past (good ole days?) a hot street hyd flat tappet cam was affordable and only required additional valvesprings. I hate the posts about wiped out cam lobes.
Keep old mopars alive.
Re: New cam zinc oil? [Re: 2boltmain] #934878
02/22/11 04:12 PM
02/22/11 04:12 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
The vast majority of wiped cam lobes are from improper installations and/or oil. I had never installed a cam before, but did so successfully by following directions and careful installation, and using the right kind of oil/additive for the break in.
Re: New cam zinc oil? [Re: indytex96] #934879
02/22/11 06:48 PM
02/22/11 06:48 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I have had my share of wiped cams. Mostly the .590 lift solid cams from Mopar Performance. Lately I have been running Racer Brown hydraulic cams with lower spring pressures and have been using diesel oil along with Lucas zinc additive, So far..so good. I see that 4 seconds flat (Racer Brown) offers composite lifters which show a lot of promise.
Re: New cam zinc oil? [Re: rbstroker] #934880
02/22/11 07:00 PM
02/22/11 07:00 PM
SE Kansas
I
I
SE Kansas
Any certain type of diesel oil that you guys recommend?
Re: New cam zinc oil? [Re: indytex96] #934881
02/22/11 07:42 PM
02/22/11 07:42 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Just swapped out the lifters on my engine. Ran Castrol diesel oil with a bottle of STP oil additive dumped over the cam/coated the bottom of the lifters. Seems to be doin alright
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: New cam zinc oil? [Re: Junky] #934882
02/22/11 08:37 PM
02/22/11 08:37 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I don't want to jinx you, but 2 months ago in the winter probably means you don't have enough miles on your fresh build to know if the cam is safe or not. I hope you are right!
I broke my last one in a few years ago, after the zinc was gone from the oil. I used the diesel oil with moly paste on the cam lobes and bottom of the lifters. Straight oil on the sides of the lifters. And I was able to use my old wimpy valve springs to break in the new cam (check for coil bind before you try this!). I hated to have to go back in and swap the springs, but in reality, it's much less work/time/money than pulling the engine and starting over after the cam wipes.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: New cam zinc oil? [Re: indytex96] #934883
02/22/11 08:50 PM
02/22/11 08:50 PM
Brad Penn breakin oil.Black moly paste on teh lobes/lifter bottoms (only). Do follow all the std preps ahead of time including making sure the lifters have enough clearance to rotate properly. On mockup, lifter body/bores cleaned & lightly oiled w WD40, lift each lifter off of it's lobe w your finger & let it go & it must fall back onto the lobe w a resounding "thunk" from it's own weight & if not you are too tight. For the ring breakin part read "breakin secrets" at www.mototuneusa.com (5 minute read)
Re: New cam zinc oil? [Re: GO_Fish] #934884
02/22/11 08:50 PM
02/22/11 08:50 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I've used oil from here with new flat tappet cams and had no problems: http://full-synthetic.com/
Of course you would not want to use full synthetic if it's a fresh motor with new rings. The owner of the company is Ed Evans. Give him a call I'm sure he can suggest something. Ed's number 815-739-5588
Re: New cam zinc oil? [Re: TooMany62s] #934885
02/22/11 09:36 PM
02/22/11 09:36 PM
IN
ahy Offline
ahy  Offline
IN
I used Rotella T 10W30 diesel engine oil + STP for break in then Rotella 15W40 + STP. About 7k miles on a moderatly aggressive FT and no problems.
Re: New cam zinc oil? [Re: ahy] #934886
02/22/11 10:00 PM
02/22/11 10:00 PM
SE Kansas
I
I
SE Kansas
I assume when just breaking in a cam it wouldn't make any difference running 40w oil instead of the 30w as recommended for new rings?
Re: New cam zinc oil? [Re: indytex96] #934887
02/22/11 10:03 PM
02/22/11 10:03 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'd definitely use the thinner 30 weight, especially if you are doing the break in during cold weather. The rings will need plenty of oil during that first start up.
Re: New cam zinc oil? [Re: RapidRobert] #934888
02/22/11 10:52 PM
02/22/11 10:52 PM
southern illinois
O
ozz383 Offline
ozz383  Offline
O
southern illinois
I agree on the brad penn. have installed 3 cams in the last 2 years and had no problems. ozz
Re: New cam zinc oil? [Re: indytex96] #934889
02/22/11 11:26 PM
02/22/11 11:26 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I am a fan of diesel oils (bought mega amounts at work) and I agree they are great oils---except--they have very high detergent levels. Not a problem in itself except that the oil tends to drain off in 'rivers' as opposed to clinging in a film. Picture that on a cam, thats been sitting for weeks.
I used to use them but for that reason I switched to regular oil plus ZDDPlus, but the next oil change I will just buy Redline's additive.
More than one way to skin a cat on this issue, and they probably all work pretty good. Obviously the higher the lift and the higher the spring pressure the greater concern.
Re: New cam zinc oil? [Re: Pacnorthcuda] #934890
02/23/11 01:07 AM
02/23/11 01:07 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Last one I did was with shell rotella T diesel oil and a bottle and a half of GM EOS. But here we could (in summer 2009 anyway) still get the old style EOS that at that time was no longer available at US gm dealers. I've been meaning to go back there and see if I can get a few more bottles of the good stuff. I know hughes sells a special break in additiave and I think comp does as well. I've heard nothing but good things about the brad penn break in oil, I think I'll give theirs a try when I put together my new motor. A roller cam would be nice but it is an additional cost, and roller rockers and roller lifters are not without their own set of problems.
Re: New cam zinc oil? [Re: GO_Fish] #934891
02/23/11 02:11 PM
02/23/11 02:11 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
It wasn't a fresh build, just a cam swap.
So far I have about 400 miles on the cam. Been driving it every chance I get. Have had my foot in it many times, up to 6k. I've been running it hard to either break the cam in good, or break the cam. I want to have at least 1,000 miles on it by the time cruise season gets here in June.
Hope it's good for many thousands of miles to come!
I was very meticulous checking the lifter rotation and everything else. Cam lift is 0.518.
Re: New cam zinc oil? [Re: 2boltmain] #934892
02/23/11 02:31 PM
02/23/11 02:31 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
THEN there are the reports on the roller lifters or rockers COMING APART and then (potentially)trashing the whole motor.
Re: New cam zinc oil? [Re: dOc !] #934893
02/23/11 02:48 PM
02/23/11 02:48 PM
Campbellsport, Wisconsin
Abodysforever Offline
How about Mobil 1 racing oil, anyone try that?
Re: New cam zinc oil? [Re: Abodysforever] #934894
02/23/11 07:30 PM
02/23/11 07:30 PM
desomod Offline
desomod  Offline
I have also heard that Valvoline Racing and Joe Gibbs Hot Rod Oil are supposed to be good.
