Re: New cam zinc oil?
[Re: Junky]
#934877
02/22/11 12:53 PM
02/22/11 12:53 PM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Often I read people suggesting one to "just" run a roller valvetrain but roller components are soo expensive. Id love to be able to buy all the stuff but it comes out like so: $300 for a cam- $300 for lifters- $300-$400 for adj Rocker arms ($80 for BETTER adjusters) and around $90 for pushrods. In the past (good ole days?) a hot street hyd flat tappet cam was affordable and only required additional valvesprings. I hate the posts about wiped out cam lobes.
Keep old mopars alive.
[Re: indytex96]
#934883
02/22/11 08:50 PM
02/22/11 08:50 PM
RapidRobert
Brad Penn breakin oil.Black moly paste on teh lobes/lifter bottoms (only). Do follow all the std preps ahead of time including making sure the lifters have enough clearance to rotate properly. On mockup, lifter body/bores cleaned & lightly oiled w WD40, lift each lifter off of it's lobe w your finger & let it go & it must fall back onto the lobe w a resounding "thunk" from it's own weight & if not you are too tight. For the ring breakin part read "breakin secrets" at www.mototuneusa.com (5 minute read)
[Re: GO_Fish]
#934884
02/22/11 08:50 PM
02/22/11 08:50 PM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
I've used oil from here with new flat tappet cams and had no problems: http://full-synthetic.com/Of course you would not want to use full synthetic if it's a fresh motor with new rings. The owner of the company is Ed Evans. Give him a call I'm sure he can suggest something. Ed's number 815-739-5588
[Re: indytex96]
#934887
02/22/11 10:03 PM
02/22/11 10:03 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I'd definitely use the thinner 30 weight, especially if you are doing the break in during cold weather. The rings will need plenty of oil during that first start up.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: indytex96]
#934889
02/22/11 11:26 PM
02/22/11 11:26 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Any certain type of diesel oil that you guys recommend?
I am a fan of diesel oils (bought mega amounts at work) and I agree they are great oils---except--they have very high detergent levels. Not a problem in itself except that the oil tends to drain off in 'rivers' as opposed to clinging in a film. Picture that on a cam, thats been sitting for weeks. I used to use them but for that reason I switched to regular oil plus ZDDPlus, but the next oil change I will just buy Redline's additive. More than one way to skin a cat on this issue, and they probably all work pretty good. Obviously the higher the lift and the higher the spring pressure the greater concern.
[Re: GO_Fish]
#934891
02/23/11 02:11 PM
02/23/11 02:11 PM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I installed a Hughes cam 2 months ago. 15W40 Valvoline Premium Blue heavy duty diesel (dino) oil with Redline zinc additive. After break in I drained and put the same oil and zinc additive back in with a new filter. Everything is just fine.
I don't want to jinx you, but 2 months ago in the winter probably means you don't have enough miles on your fresh build to know if the cam is safe or not. I hope you are right!
It wasn't a fresh build, just a cam swap.
So far I have about 400 miles on the cam. Been driving it every chance I get. Have had my foot in it many times, up to 6k. I've been running it hard to either break the cam in good, or break the cam. I want to have at least 1,000 miles on it by the time cruise season gets here in June.
Hope it's good for many thousands of miles to come!
I was very meticulous checking the lifter rotation and everything else. Cam lift is 0.518.
[Re: 2boltmain]
#934892
02/23/11 02:31 PM
02/23/11 02:31 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
THEN there are the reports on the roller lifters or rockers COMING APART and then (potentially)trashing the whole motor.
