70 cuda steering column ? #930796
02/16/11 11:29 PM
02/16/11 11:29 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
I'm rebuilding my steering column and I see in the book there should be a steering shaft dust seal in the steering tube(inner tube not the black outer tube) that seals around the steering shaft. There was nothing there when I took it apart. Is there a part available or part number?
Re: 70 cuda steering column ? [Re: 340swing] #930797
02/17/11 09:01 AM
02/17/11 09:01 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Anybody have any idea's any pics I'm not sure what goes there?
Re: 70 cuda steering column ? [Re: 340swing] #930798
02/17/11 12:16 PM
02/17/11 12:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Are you talking about the dust seal at the bottom of the shaft just above the nylon "bearing"? I used a length of 1 inch wide, black, spongy, medium closed cell, foam tape(non-adhesive backed). I rolled it around the tube until I got the desired thickness(it took about a foot), and secured it with a dab of weatherstrip adheasive.
Re: 70 cuda steering column ? [Re: jbc426] #930799
02/17/11 08:36 PM
02/17/11 08:36 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
No I did the same for that one. It's the inner tube steel finish and the solid steel shaft that goes to the steering box. I will take a picture if I can. The repair manual calls for a dust seal but there is no picture of it.
Re: 70 cuda steering column ? [Re: 340swing] #930800
02/18/11 12:24 AM
02/18/11 12:24 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Here are the pics. What goes here? does anybody have one or know where to get one?
Re: 70 cuda steering column ? [Re: 340swing] #930801
02/18/11 12:26 AM
02/18/11 12:26 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
2nd pic from book
Re: 70 cuda steering column ? [Re: 340swing] #930802
02/18/11 08:27 AM
02/18/11 08:27 AM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
anybody know ?
Re: 70 cuda steering column ? [Re: 340swing] #930803
02/18/11 10:46 AM
02/18/11 10:46 AM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Re: 70 cuda steering column ? [Re: 340swing] #930804
02/18/11 01:57 PM
02/18/11 01:57 PM
IMGTX Offline
IMGTX  Offline
I am pretty sure it is just a foam rubber tube like they have around copper pipes.
Re: 70 cuda steering column ? [Re: IMGTX] #930805
02/18/11 04:51 PM
02/18/11 04:51 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
It is a medium density adhesive backed foam... about 3/4 inch wide. You can get it at you local hardware store. Cut it to length and put it on your column and you are done.
Re: 70 cuda steering column ? [Re: 70mopes] #930806
02/18/11 10:21 PM
02/18/11 10:21 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks for the info guys. I was thinking it might be a bushing or bearing but thought it was strange that it was missing when I took it apart. There was no way for it to go anywhere. The foam would explain how it would have disappeared. Thanks
Re: 70 cuda steering column ? [Re: 340swing] #930807
06/24/11 03:30 PM
06/24/11 03:30 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hmm,i thought 70 barracuda only had a foam dust seal behind the lower plastic bushing,on the lockout tube.ive only dismantled 2 -70 columns but both only had foam stripes glued? to the lock out tube,and those stripes of foam sealed to the outer column tube.
