Eagle I beam rods any good? #929764
02/15/11 06:56 PM
02/15/11 06:56 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
Are they stronger than a factory 340 rod? How do they compare weight wise?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Eagle I beam rods any good? [Re: 11secaarcuda] #929765
02/15/11 07:00 PM
02/15/11 07:00 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
OH BOY!! Here we go.....
That being said, NO, buy scat I beams if you want a nice rod on the cheap. Im no multi engine builder, but I have a few under my belt, and Ive seen a lot of guts spilled from SIR rods.
Thats my personal opinion though.
Kasey
Re: Eagle I beam rods any good? [Re: 11secaarcuda] #929766
02/15/11 07:20 PM
02/15/11 07:20 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Here you go:
I just weighed one of each.
Stock " 645 " rod: 744
Stock "798" Magnum: 743
Eagle SIR: 610.2
Scat I beam Pro Comp: 571
I'd be choosing the Scat way before the others.
RIP Monte Smith
Re: Eagle I beam rods any good? [Re: CompWedgeEngines] #929767
02/15/11 07:27 PM
02/15/11 07:27 PM
Moparnut426 Offline
Moparnut426  Offline
I have the scat rods in 3 different engines, and childs track masters in my 408 in the demon, they all were GREAT lookin rods, and non needed a lot of block clearances. The SIRs I have in a 360 needed a lot of honeing on the wrist pin bushings, and also needed the big end resized. That puney lookin cap looks like it distorts a bunch.
That being said after i had the SIR rods worked over, I had more than a set of H beams, both my Chids rods and the Scat rods miked out really good from the box.
Kasey
Re: Eagle I beam rods any good? [Re: 11secaarcuda] #929768
02/15/11 07:36 PM
02/15/11 07:36 PM
Az
Crizila Offline
Crizila  Offline
Az
Been running them for 3+ years now in my 408 with no problems. Engine is probably in the 475HP range and don't go over 6500rpm. No block clearancing needed.
Fastest 300
Re: Eagle I beam rods any good? [Re: Crizila] #929769
02/16/11 03:07 AM
02/16/11 03:07 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
They're light, about all I can say for them. That being said, I have a set in my 360. Had them in a 408, with an eagle cast crank. Which is why I now have them in a 360...
If I had it to do over again, I would have bought Scats (they're 4340) and gone with a FORGED Scat 4" stroke.
Re: Eagle I beam rods any good? [Re: dodgeboy11] #929770
02/16/11 09:00 AM
02/16/11 09:00 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I have a set in my Mom's Duster 362". I bought them without really asking around and then found out they don't have a good rep. That being said these rods are going on their fourth season. Best pass of a 11.48@113 shifting at 6000rpm in a almost street car. So far so good. They did need a little work done to make them right.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Eagle I beam rods any good? [Re: Jacob Pitt] #929771
02/16/11 10:41 AM
02/16/11 10:41 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a set in my 340, it was around 450 hp with the ported Edelbrocks. They ran for six years on the street and strip with no issues, I turned it from 6400-6700. I bought them before I knew there were any problems with them. I would buy Scats if I were doing that engine over again.
Re: Eagle I beam rods any good? [Re: justinp61] #929772
02/16/11 10:49 AM
02/16/11 10:49 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
i have them in my aspen. my thought is they have to be better than stock and i paid 99 for mine so it was cheaper than reconing the oe ones.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Eagle I beam rods any good? [Re: kissmyaspen] #929773
02/16/11 07:36 PM
02/16/11 07:36 PM
Newark, OH
springers340dart Offline
Newark, OH
if you gonna go I beam go with scat! thats what i got in mine now runnin 10.70's!
Re: Eagle I beam rods any good? [Re: Crizila] #929774
02/16/11 09:59 PM
02/16/11 09:59 PM
NC
barracuda man Offline
NC
I've heard the stories.been pounding on them 5+ seasons.don't no the hp on the 340cu but its been 6.85 et's in 1/8 mile. 850 passes.I have the scat rods now just need the strocker crank.
Re: Eagle I beam rods any good? [Re: 11secaarcuda] #929775
02/16/11 11:46 PM
02/16/11 11:46 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
I have a set in my 360 Barracuda, 3 years, have run a best of 11.1@120mph, shift at 64-6600rpm, bumped 7400 rpm chip more than once. I asked a very similar question a while ago got pretty much the same answers as are being posted here now. That said, I've never seen a failure. Asked an engine builder friend if he had ever seen a failure and he hadn't. Take things with a grain of salt; remember, you can break anything given time and was it the rod that broke first or something else?
Re: Eagle I beam rods any good? [Re: JBurch] #929776
02/17/11 09:42 AM
02/17/11 09:42 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
I have a set in my 360 Barracuda, 3 years, have run a best of [Email]11.1@120mph[/Email], shift at 64-6600rpm, bumped 7400 rpm chip more than once. I asked a very similar question a while ago got pretty much the same answers as are being posted here now. That said, I've never seen a failure. Asked an engine builder friend if he had ever seen a failure and he hadn't. Take things with a grain of salt; remember, you can break anything given time and was it the rod that broke first or something else?
I agree, I have had no problems with eagle rods. I question the engine build more than the rod.
