Eagle I beam rods any good?
#929764
02/15/11 06:56 PM
02/15/11 06:56 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Are they stronger than a factory 340 rod? How do they compare weight wise?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: Eagle I beam rods any good?
[Re: 11secaarcuda]
#929765
02/15/11 07:00 PM
02/15/11 07:00 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
OH BOY!! Here we go.....
That being said, NO, buy scat I beams if you want a nice rod on the cheap. Im no multi engine builder, but I have a few under my belt, and Ive seen a lot of guts spilled from SIR rods.
Thats my personal opinion though.
Kasey
[Re: 11secaarcuda]
#929766
02/15/11 07:20 PM
02/15/11 07:20 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Here you go:
I just weighed one of each.
Stock " 645 " rod: 744 Stock "798" Magnum: 743 Eagle SIR: 610.2 Scat I beam Pro Comp: 571
I'd be choosing the Scat way before the others.
RIP Monte Smith
[Re: 11secaarcuda]
#929768
02/15/11 07:36 PM
02/15/11 07:36 PM
Posts: 7,506 Az
Crizila
Az
Been running them for 3+ years now in my 408 with no problems. Engine is probably in the 475HP range and don't go over 6500rpm. No block clearancing needed.
Fastest 300
[Re: dodgeboy11]
#929770
02/16/11 09:00 AM
02/16/11 09:00 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I have a set in my Mom's Duster 362". I bought them without really asking around and then found out they don't have a good rep. That being said these rods are going on their fourth season. Best pass of a 11.48@113 shifting at 6000rpm in a almost street car. So far so good. They did need a little work done to make them right.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: justinp61]
#929772
02/16/11 10:49 AM
02/16/11 10:49 AM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
i have them in my aspen. my thought is they have to be better than stock and i paid 99 for mine so it was cheaper than reconing the oe ones.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: Crizila]
#929774
02/16/11 09:59 PM
02/16/11 09:59 PM
Posts: 526 NC
barracuda man
NC
I've heard the stories.been pounding on them 5+ seasons.don't no the hp on the 340cu but its been 6.85 et's in 1/8 mile. 850 passes.I have the scat rods now just need the strocker crank. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: 11secaarcuda]
#929775
02/16/11 11:46 PM
02/16/11 11:46 PM
Posts: 644 Owego, NY
JBurch
Owego, NY
I have a set in my 360 Barracuda, 3 years, have run a best of 11.1@120mph, shift at 64-6600rpm, bumped 7400 rpm chip more than once. I asked a very similar question a while ago got pretty much the same answers as are being posted here now. That said, I've never seen a failure. Asked an engine builder friend if he had ever seen a failure and he hadn't. Take things with a grain of salt; remember, you can break anything given time and was it the rod that broke first or something else?
[Re: JBurch]
#929776
02/17/11 09:42 AM
02/17/11 09:42 AM
Posts: 892 Illinois
StrkrDart69
Illinois
I have a set in my 360 Barracuda, 3 years, have run a best of [Email]11.1@120mph[/Email], shift at 64-6600rpm, bumped 7400 rpm chip more than once. I asked a very similar question a while ago got pretty much the same answers as are being posted here now. That said, I've never seen a failure. Asked an engine builder friend if he had ever seen a failure and he hadn't. Take things with a grain of salt; remember, you can break anything given time and was it the rod that broke first or something else?
I agree, I have had no problems with eagle rods. I question the engine build more than the rod. ![](/ubbthreads/images/graemlins/Twocents.gif)
