CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? #928759
02/14/11 04:15 PM
02/14/11 04:15 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
isnt there an adapter i have to have to convert from power to manual steering? 73up a body. where do i get this adapter?
74 dart sport 440 www.Csucarbs.com
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: shoebox] #928760
02/14/11 04:42 PM
02/14/11 04:42 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Mancini has them. Both the MOPAR one and if you want to spend more on a classy looking universal one from Flamming River, they have that as well.
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: shoebox] #928761
02/14/11 04:47 PM
02/14/11 04:47 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: dangina] #928762
02/15/11 09:39 PM
02/15/11 09:39 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
thanks
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: shoebox] #928763
02/15/11 09:43 PM
02/15/11 09:43 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
With the Mopar one you still need the manual steering pot couple. The Firm Feel one uses the power coupler.
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: shoebox] #928764
02/15/11 10:03 PM
02/15/11 10:03 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
My advice is not to bother.
Keep the upper column intact and use the lower column fom the donor car.
If it makes you feel better replace the plastic shear pins in the middle where the two overlap.
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: GwaiiEagle] #928765
02/15/11 10:45 PM
02/15/11 10:45 PM
middleburg,fl
barryv Offline
barryv  Offline
middleburg,fl
how important is it to replace the shear pins
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: barryv] #928766
02/16/11 10:21 AM
02/16/11 10:21 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
Good question. I'm sure that there are a bunch, maybe even mine and yours that the pins were broke during restores, etc. The column isn't going anywhere (up and down), and unless it can be "pulled" out of the coupler some how. The pins do nothing for the turning ability of the column, they just shear off if it is compressed during an accident and the column telescopes down.
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: DANA60] #928767
02/16/11 02:41 PM
02/16/11 02:41 PM
Winterville, Ga USA
rogue_leader007 Offline
Winterville, Ga USA
Will this work on a 1970 a-body as well?
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: rogue_leader007] #928768
02/16/11 03:54 PM
02/16/11 03:54 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
I switched my 74 Duster from Power to Manual.
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: GwaiiEagle] #928769
02/16/11 04:16 PM
02/16/11 04:16 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Just go to the junkyard and get a coupler off of a 70s/80s B-van. Same thing
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: 69L78Nova] #928770
02/17/11 12:08 AM
02/17/11 12:08 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
R.Ehrenberg (sp?) at Mopar Action covers some technical issues with the coupler in the April 2009 issue. Nothing drastic, but it might offer some good info if you have it.
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: 67SATisfaction] #928771
02/17/11 03:39 AM
02/17/11 03:39 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Been using this since I put my 63 on the road in 2006. Ron
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: 383man] #928772
02/17/11 04:55 PM
02/17/11 04:55 PM
Baton Rouge, La.
StandOnIt Offline
StandOnIt  Offline
Baton Rouge, La.
Don't forget to get the pitman arm. The manual one has a diff size and spline.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: StandOnIt] #928773
02/18/11 03:07 PM
02/18/11 03:07 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
If I were doing it again I'd weld a universal joint on the end of the column and be done
https://www.lefthanderchassis.com/v2a/viewproduct_group.asp?idgroup=2512553
Re: CONVERTING TO MANUAL STEERING-- WHERE TO GET ADAPTER? [Re: GTXKen] #928774
03/30/11 06:28 PM
03/30/11 06:28 PM
Long Island Ny
V
varlo Offline
varlo  Offline
V
Long Island Ny
Which one did you buy? There are a few options on that link.
