70 K-Frame into 63 B-Body #927661
02/13/11 11:27 AM
02/13/11 11:27 AM
Colorado
67plymouthman Offline OP
Colorado
I have the opportunity to buy a rebuilt 70 k-frame with: disk brakes,new bushing kit installed, with a sway bar from a friend off his 70 Roadrunner that he wants a magnum front end. Will it fit into my 63 Polara??? I have asked 3 local "experts" and have recieved 3 different answers... Has anyone done it? Someone said the motor sits differently on the older k-frames.
Re: 70 K-Frame into 63 B-Body [Re: 67plymouthman] #927662
02/13/11 11:58 AM
02/13/11 11:58 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
It fits.It does set the motor back so you need to modify the trans mount and the drive shaft.The 70 rotors are pricey to replace .Rocky
Chrysler Firepower
Re: 70 K-Frame into 63 B-Body [Re: therocks] #927663
02/13/11 12:10 PM
02/13/11 12:10 PM
Colorado
Colorado
Thanks Rocky- I am also going to use some fenderwell headers. Will the motor be back to far? I am not worried about the driveshaft since I need to make one and I am not using a push button tranny.
Re: 70 K-Frame into 63 B-Body [Re: 67plymouthman] #927664
02/13/11 02:28 PM
02/13/11 02:28 PM
East Lansing, Michigan
O
OldHippie Offline
super gas
OldHippie  Offline
super gas
O
If memory serves correctly the engine set-back will be roughly 1.5 inches with the late K in the earlier car. This was a sneaky Pete thing that stock and super stock racers did for years before sanctioning bodies got wise. Check with your Header manufacturer to see if the tubes are built with this modification in mind. It could be that fender well tubes for a '66-up car are what you will need........
The Old Hippie Hisself
Re: 70 K-Frame into 63 B-Body [Re: OldHippie] #927665
02/13/11 05:20 PM
02/13/11 05:20 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I don't have any info on the fit in your car, but please do your friend a favor and have him research the magnum force suspension before he converts over. I did not find the old posts on this subject in a quick search, but I think is was brought up before and determined the magnum force suspension system was the worst thing to do to a car.
Re: 70 K-Frame into 63 B-Body [Re: OldHippie] #927666
02/13/11 08:21 PM
02/13/11 08:21 PM
Colorado
Colorado
That makes sense- that it would help weight distribution.
Re: 70 K-Frame into 63 B-Body [Re: 67plymouthman] #927667
02/13/11 09:28 PM
02/13/11 09:28 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Unless you already have the fenderwell headers, just buy regular headers for a 70 Roadrunner.
Re: 70 K-Frame into 63 B-Body [Re: 67plymouthman] #927668
02/13/11 09:57 PM
02/13/11 09:57 PM
Haven't personally done it but researched it before I put a stock V-8 K in my '63 330.
I decided it wasn't worth the hassle for a street driven car.
Moves back approximately 1 5/8".
If you plan on using a crossram, firewall will need to be beat on or cut to provide room.
Rear transmission mount will need to be re-worked whereas you can get a later syle transmission to bolt up if you use the original style k with a Schumacher conversion mount.
Re: 70 K-Frame into 63 B-Body #927669
02/14/11 12:28 AM
02/14/11 12:28 AM
Canada
demon Offline
demon  Offline
Canada
I know a guy who put a 69 k frame in a 64. It sets the engine back a bit. There are a few considerations:
Good:
better weight distibution
common 66-72 oil pans all fit
common 66-72 headers all fit
more clearance for fan clutch
common 66-72 B or C body engine mounts
better thru bolt idler arm
Bad:
kickdown linkage interferes with heater hoses at firewall
trans mount needs some modifying.
Manual trans cars need clutch linkage reworked
driveshaft needs shortening
Max Wedge manifolds now interfere with firewall
stick B engine ex manifolds might not clear.
I guess you should take everything into consideration and see if it will benefit your situation
Re: 70 K-Frame into 63 B-Body [Re: demon] #927670
02/15/11 11:54 AM
02/15/11 11:54 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
I have done it on quite a few 63-65 B-bodies....moving the entire engine&trans inch and a half rearward changes the weight transfer,with SS springs&a snubber.....the launch is awesome!the best shocks you can buy are a must....when you launch and the front end comes up and does that little shimmy dance when you shift....it settles down and hauls the mail!yes you will need to modify the trans mount, i made a simple flat plate extension that bolted in....with an automatic trans i used a reverse manual valve body and elimanated the kickdown linkage.
Re: 70 K-Frame into 63 B-Body [Re: Joesixpack] #927671
02/15/11 09:46 PM
02/15/11 09:46 PM
Colorado
Colorado
Whats the part # for SS spring?
Re: 70 K-Frame into 63 B-Body [Re: 67plymouthman] #927672
02/15/11 10:01 PM
02/15/11 10:01 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I did the conversion on a 64 Plymouth. Stock mounts worked and headers from a 66-up B-body fit real well. Found a driveshaft at the junkyard that fit. Check Mancini's site for the SS spring part number as you need new front perches. Trans mount was modified to move the box back 1-1/2" and used the cheaper 68 auto mount.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 70 K-Frame into 63 B-Body [Re: Dads426] #927673
02/15/11 10:47 PM
02/15/11 10:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah get w/ Kevin and his dad.... they know their junk.
Coming soon!!!!
Re: 70 K-Frame into 63 B-Body [Re: Mr.Yuck] #927674
02/15/11 11:25 PM
02/15/11 11:25 PM
Colorado
Colorado
Thanks for the great info. My fenderwell headers are for a 63, does anyone know if the will work? I probably need to mock it up.
