70 K-Frame into 63 B-Body
#927661
02/13/11 11:27 AM
02/13/11 11:27 AM
Posts: 337 Colorado
67plymouthman
Colorado
I have the opportunity to buy a rebuilt 70 k-frame with: disk brakes,new bushing kit installed, with a sway bar from a friend off his 70 Roadrunner that he wants a magnum front end. Will it fit into my 63 Polara??? I have asked 3 local "experts" and have recieved 3 different answers... Has anyone done it? Someone said the motor sits differently on the older k-frames. Thanks
Re: 70 K-Frame into 63 B-Body
[Re: 67plymouthman]
#927662
02/13/11 11:58 AM
02/13/11 11:58 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
It fits.It does set the motor back so you need to modify the trans mount and the drive shaft.The 70 rotors are pricey to replace .Rocky
Chrysler Firepower
[Re: 67plymouthman]
#927664
02/13/11 02:28 PM
02/13/11 02:28 PM
Posts: 660 East Lansing, Michigan
OldHippie
super gas
super gas
If memory serves correctly the engine set-back will be roughly 1.5 inches with the late K in the earlier car. This was a sneaky Pete thing that stock and super stock racers did for years before sanctioning bodies got wise. Check with your Header manufacturer to see if the tubes are built with this modification in mind. It could be that fender well tubes for a '66-up car are what you will need........
The Old Hippie Hisself
[Re: 67plymouthman]
#927668
02/13/11 09:57 PM
02/13/11 09:57 PM
Haven't personally done it but researched it before I put a stock V-8 K in my '63 330.
I decided it wasn't worth the hassle for a street driven car.
Moves back approximately 1 5/8".
If you plan on using a crossram, firewall will need to be beat on or cut to provide room.
Rear transmission mount will need to be re-worked whereas you can get a later syle transmission to bolt up if you use the original style k with a Schumacher conversion mount.
[Re: 67plymouthman]
#927672
02/15/11 10:01 PM
02/15/11 10:01 PM
Posts: 1,443 Maryland
Dads426
Maryland
I did the conversion on a 64 Plymouth. Stock mounts worked and headers from a 66-up B-body fit real well. Found a driveshaft at the junkyard that fit. Check Mancini's site for the SS spring part number as you need new front perches. Trans mount was modified to move the box back 1-1/2" and used the cheaper 68 auto mount.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#927673
02/15/11 10:47 PM
02/15/11 10:47 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah get w/ Kevin and his dad.... they know their junk.
