Machine shop, boring and honing ??? #927247
02/12/11 09:37 PM
02/12/11 09:37 PM
Hershey,PA
mracer360 Offline OP
Hershey,PA
Is it possible to bore/hone a block an additional .010 over?? My block is now .030 over would like to go .040 over. Any info. would be great. Not sure if this would be a machine shop no no. Thanks-Mackey
Re: Machine shop, boring and honing ??? [Re: mracer360] #927248
02/12/11 10:08 PM
02/12/11 10:08 PM
It is very possible, what type(BB,SB or Hemi) and year block are you asking about? I have had many blocks that where at .020 over honed to .030 and even .040 over if you don't know if the cylinder walls are good or not see if you can have it sonic tested first before deciding on what to do
Re: Machine shop, boring and honing ??? [Re: mracer360] #927249
02/12/11 10:12 PM
02/12/11 10:12 PM
Delray beach, Florida
P
Performance Only Offline
P
i do it all the time. it's not a big deal. make sure they use a torque plate on it when honing. no need to bore it for only .010 more.
machine shop owner and engine builder
Re: Machine shop, boring and honing ??? [Re: mracer360] #927250
02/12/11 10:12 PM
02/12/11 10:12 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
yea my stock 340 was 40 over w a 4" crank =418ci sb..go read shadydellspeedshop web page click on FAQ its good reading
Re: Machine shop, boring and honing ??? [Re: mracer360] #927251
02/12/11 10:26 PM
02/12/11 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure you can get pistons in that size before
you do it
Re: Machine shop, boring and honing ??? [Re: MR_P_BODY] #927252
02/13/11 07:26 PM
02/13/11 07:26 PM
Hershey,PA
Hershey,PA
Thanks guys, I will go to the machine shop this week and talk to them. It is a sb and the bore currently is 4.030 and 4.040 pistons seem to be available for a 4in. stroke from probe and wiseco, not sure on what brand I will be going with, I hae run Ross for years now.
Re: Machine shop, boring and honing ??? [Re: mracer360] #927253
02/13/11 07:35 PM
02/13/11 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Diamond also has a 4.040 piston for the 4" stroke
