What kind and year cars did this a/c bracket come on? #926556
02/11/11 06:46 PM
02/11/11 06:46 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
My friend is needing this bracket for a 440.. The one in the picture is for a 383 so it is cut into and will be modified to make it work on a 440. He wants one for a spare and really cannot remember what they came on.. I know pre 70 but what?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: What kind and year cars did this a/c bracket come on? [Re: Boosted] #926557
02/11/11 07:10 PM
02/11/11 07:10 PM
indiana
generallee6901 Offline
indiana
I had one from a 67 440 but do not know what other years used the same.
Re: What kind and year cars did this a/c bracket come on? [Re: Boosted] #926558
02/12/11 12:29 AM
02/12/11 12:29 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1967 and 1968,
I know it's NOT 1969 or later, but I'm not sure of 1966 and/or earlier models
Re: What kind and year cars did this a/c bracket come on? [Re: gtx6970] #926559
02/12/11 12:54 AM
02/12/11 12:54 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
I've got a similar cast bracket on our '65 w/361.
I checked the photos and there might be a small difference in shape where it meets the compressor, but where it meets the engine block it's the same.
I also saw one exactly like mine on an Imperial, so I bet they were used on big blocks across the wide range.
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: What kind and year cars did this a/c bracket come on? [Re: Boosted] #926560
02/12/11 03:33 PM
02/12/11 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In some installations that bracket carries an 1858XXX part number so it dates back to around '58.
Re: What kind and year cars did this a/c bracket come on? [Re: John_Kunkel] #926561
02/12/11 06:39 PM
02/12/11 06:39 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Had one on a 67 and 68 383 and 440 engines.
I dont know which way you would lengthen the arm,(long side or short side) but I do know that changing the thermostat is a real challenge with the proper bracket.
Re: What kind and year cars did this a/c bracket come on? [Re: sthemi] #926562
02/14/11 01:09 PM
02/14/11 01:09 PM
GA
Boosted Offline OP
Boosted  Offline OP
GA
you guys are just too good.... Now if we can just find another one....
2011 RAM3500
