Roller lifter for B1 Engine question? #926523
02/11/11 05:59 PM
02/11/11 05:59 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
For a standard B1 headed engine, what configuration offset should be used? I have been looking around and come across some various options. For example the ISKY 3772-LO-180 has 8 on centre lifters, 4 left 0.180" and 4 right 0.180".
A Comp Cams Elite Roller lifter 98827-16 has 8 left 0.180" and 8 right 0.180"
Thanks for you help!
Alan Jones
Re: Roller lifter for B1 Engine question? [Re: LA360] #926524
02/11/11 07:05 PM
02/11/11 07:05 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
98827-16 Elite Race™ .180" Offset Roller Lifters .904" 4 Pairs Centered & Left
4 Pairs Centered & Right (4) 98829CL-2
(4) 98829CR-2
Re: Roller lifter for B1 Engine question? [Re: supercomp] #926525
02/11/11 09:20 PM
02/11/11 09:20 PM
LA360 Offline OP
LA360  Offline OP
Are you running these lifters currently?
Alan Jones
Re: Roller lifter for B1 Engine question? [Re: supercomp] #926526
02/11/11 09:25 PM
02/11/11 09:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are those push rod oiling?
Re: Roller lifter for B1 Engine question? [Re: MR_P_BODY] #926527
02/12/11 10:58 AM
02/12/11 10:58 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Re: Roller lifter for B1 Engine question? [Re: supercomp] #926528
02/12/11 10:58 AM
02/12/11 10:58 AM
NC
440Jim Offline
440Jim  Offline
NC
(4) 98829CR-2
From the Comp Cams web site:
web page
Interchangeable pushrods seats can be easily swapped for centered, left or right offsets. A patent-pending design allowing oil control through the pushrod insert allows builders to modify lifters to meter extra oil to the top.
Re: Roller lifter for B1 Engine question? [Re: 440Jim] #926529
02/12/11 09:25 PM
02/12/11 09:25 PM
NC
440Jim Offline
440Jim  Offline
NC
As an alternative, the Comp 892 lifters have offset intake pushrod seats, push rod oiling, and about half the cost of the Elite series. But they don't have the features of the Elite series either...
And they have an offset pushrod set without pushrod oiling also.
Re: Roller lifter for B1 Engine question? [Re: 440Jim] #926530
02/13/11 09:17 AM
02/13/11 09:17 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Jim do you know the part number without pushrod oiling?
Re: Roller lifter for B1 Engine question? [Re: mac56] #926531
02/13/11 10:30 AM
02/13/11 10:30 AM
NC
440Jim Offline
440Jim  Offline
NC
It is on the Comp Cams web site under BB Mopar roller lifters. Not hard to find. You can find it with a few clicks. I don't know it off the top of my head, but it is a long number (5 digits?) not a 3 digit one.
EDIT: 87019
Re: Roller lifter for B1 Engine question? [Re: 440Jim] #926532
02/13/11 10:48 AM
02/13/11 10:48 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Comp no longer makes the 892 lifter. the no pushrod oiling is 87019-16
Re: Roller lifter for B1 Engine question? [Re: supercomp] #926533
02/13/11 11:07 AM
02/13/11 11:07 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Thanks Guys. Just thought maybe you did have it on the top of your head Jim. I don't mind doing my own clicking around.
Re: Roller lifter for B1 Engine question? [Re: mac56] #926534
02/13/11 11:59 AM
02/13/11 11:59 AM
NC
440Jim Offline
440Jim  Offline
NC
Mac,
This is a screen capture from last years catalog for roller lifters:
Supercomp,
Thanks for the update, they still show it on their web site:
892L, 892R, 892C (individual, not sets). web page
And Summit says ships tomorrow (Mon), so that implies it is in stock? Summit web page
Re: Roller lifter for B1 Engine question? [Re: 440Jim] #926535
02/13/11 06:25 PM
02/13/11 06:25 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Thanks, that's what we run in the B1 S/C dragster. Glad they are still available.
Re: Roller lifter for B1 Engine question? [Re: supercomp] #926536
02/13/11 10:00 PM
02/13/11 10:00 PM
LA360 Offline OP
LA360  Offline OP
Thanks for the info! Is anyone running the lifter that Bullet Cams currently offer???
Alan Jones
Re: Roller lifter for B1 Engine question? [Re: LA360] #926537
02/25/11 08:34 PM
02/25/11 08:34 PM
LA360 Offline OP
LA360  Offline OP
Alan Jones
