need help quick 71-2 satellite doors #926483
02/11/11 04:00 PM
02/11/11 04:00 PM
Nashport, OH
chargers777 Online content OP
chargers777  Online Content OP
Nashport, OH
Do they interchange with 73-4 satellite?Also will a 71-2 deck lid interchange witrh a 73-4?
Re: need help quick 71-2 satellite doors [Re: chargers777] #926484
02/11/11 04:22 PM
02/11/11 04:22 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
I don't think the 71 - 72 doors will swap. I believe the trunk lids do.
'71 SSP - SOLD!
Re: need help quick 71-2 satellite doors [Re: chargers777] #926485
02/11/11 05:01 PM
02/11/11 05:01 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
71-74 doors will work together, hinges are actually better design on 73-74. 71-74 trunks will work. Fron clip completely different. No lower valances on 73-74. Quarters different. 71-74 dash is the same. Rear windows different.
I think this guy has some 71-72 doors:
instock102@aol.com
Re: need help quick 71-2 satellite doors [Re: DANA60] #926486
02/11/11 05:14 PM
02/11/11 05:14 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
instock102@aol.com
71/2 totally different door than 73/4
73/4 deck lid will work but has larger lock hole and no wing cut outs.
74 had different hinges that 71/3
rear window same 71/4 all 2 door B's
Dashes different. 71. 72/3 and 74 on the clusters. 71/2 and 73/4 and the frames.
My after owning over 60 71/4B's.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: need help quick 71-2 satellite doors [Re: moparmarks] #926487
02/11/11 11:35 PM
02/11/11 11:35 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The 71-72 has the body line pressed into the lower part of door door where a 73-74 door is smooth in that area because those cars didn't have that body line. I suspect a 73-74 door could be bolted onto a 71-72 rr/satellite but the body line in the door would definitely be a very noticeable mismatch. I don't know about how the rest of the door would fit either. The 71-72 door may also be different in the area where it meets the rear 1/4 window area.
Re: need help quick 71-2 satellite doors [Re: DANA60] #926488
02/11/11 11:38 PM
02/11/11 11:38 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I'll add 73-4's DO have lower valences front and rear....
Re: need help quick 71-2 satellite doors [Re: QuickBpBp] #926489
02/12/11 12:28 AM
02/12/11 12:28 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
the radius along line on the the top of the door is different too
also, the 73-4 doors are flat in the area of where the mirror bolts on, 71-2 have a contour in that area
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
Re: need help quick 71-2 satellite doors [Re: GTXX] #926490
02/12/11 12:41 AM
02/12/11 12:41 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
So we have not helped the OP very much here . One is saying one thing and another is saying something totally diff.
One poster is saying he has owned over 60 b bods and the 73 and 74s have no front valences. I have to disagree , I think they do, the 71 -2 doors are diff from 73-74s. Just my observation from owning just a several b bods .
So who's right here ?????
Re: need help quick 71-2 satellite doors [Re: mopar_man] #926491
02/12/11 12:43 AM
02/12/11 12:43 AM
moparmarks Offline
moparmarks  Offline
I never said they didn't have valances.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: need help quick 71-2 satellite doors [Re: moparmarks] #926492
02/12/11 08:07 AM
02/12/11 08:07 AM
eganville ont
440beep Offline
440beep  Offline
eganville ont
71-72 doors are not the same
as 73-74 doors
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: need help quick 71-2 satellite doors [Re: DANA60] #926493
02/12/11 11:16 AM
02/12/11 11:16 AM
IL
71383beep Offline
71383beep  Offline
IL
The hinges may work, but as others are pointing out the doors and other parts are not the same.
The other advice is correct...the 73/74 cars are WAY different than the 71/72 B bodies.
Good advice for 71/72 owners is to NOT look at 73/74 cars for parts. Maybe the glass and a few interior trim pieces, but for the most part there are vast differences between these cars. I have argued with way to many bozo's at swap meets with 71-74 marked on fenders, door, etc. I am quite sure that people have gotten burned by buying a 73 door or fender and then bolting it on the car only to find that it doesn't line up worth a darn. Its a pet peeve of mine...
'73 GK6 Challenger Rallye - 340 4-Speed
Re: need help quick 71-2 satellite doors [Re: 71383beep] #926494
02/12/11 07:38 PM
02/12/11 07:38 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
I'll add this...
1971 & 72 2 door Satellite roof is the same as 73 & 74 Charger.
Re: need help quick 71-2 satellite doors [Re: gregn96cuda] #926495
02/13/11 02:07 AM
02/13/11 02:07 AM
Nashport, OH
Nashport, OH
Thanks for the help.A guy had a 73-4 rr hood for sale and 71-4 doors.It looks like the 71-2 doors are different.
Re: need help quick 71-2 satellite doors [Re: moparmarks] #926496
02/13/11 10:03 AM
02/13/11 10:03 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Sorry . me bad ....but another poster said it .
