Re: need help quick 71-2 satellite doors
[Re: chargers777]
#926484
02/11/11 04:22 PM
02/11/11 04:22 PM
Posts: 1,213 Los Angeles, CA
Mobarge
Los Angeles, CA
I don't think the 71 - 72 doors will swap. I believe the trunk lids do.
'71 SSP - SOLD!
[Re: chargers777]
#926485
02/11/11 05:01 PM
02/11/11 05:01 PM
Posts: 616 TP Exit 7, NJ, USA
DANA60
TP Exit 7, NJ, USA
71-74 doors will work together, hinges are actually better design on 73-74. 71-74 trunks will work. Fron clip completely different. No lower valances on 73-74. Quarters different. 71-74 dash is the same. Rear windows different. I think this guy has some 71-72 doors: instock102@aol.com
[Re: DANA60]
#926486
02/11/11 05:14 PM
02/11/11 05:14 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
71/2 totally different door than 73/4 73/4 deck lid will work but has larger lock hole and no wing cut outs. 74 had different hinges that 71/3 rear window same 71/4 all 2 door B's Dashes different. 71. 72/3 and 74 on the clusters. 71/2 and 73/4 and the frames.
My after owning over 60 71/4B's.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#926487
02/11/11 11:35 PM
02/11/11 11:35 PM
DaytonaTurbo
Manitoba, Canada
The 71-72 has the body line pressed into the lower part of door door where a 73-74 door is smooth in that area because those cars didn't have that body line. I suspect a 73-74 door could be bolted onto a 71-72 rr/satellite but the body line in the door would definitely be a very noticeable mismatch. I don't know about how the rest of the door would fit either. The 71-72 door may also be different in the area where it meets the rear 1/4 window area.
[Re: DANA60]
#926488
02/11/11 11:38 PM
02/11/11 11:38 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
I'll add 73-4's DO have lower valences front and rear....
[Re: QuickBpBp]
#926489
02/12/11 12:28 AM
02/12/11 12:28 AM
Posts: 176 Rome, GA
GTXX
Rome, GA
the radius along line on the the top of the door is different too also, the 73-4 doors are flat in the area of where the mirror bolts on, 71-2 have a contour in that area
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
[Re: GTXX]
#926490
02/12/11 12:41 AM
02/12/11 12:41 AM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
So we have not helped the OP very much here . One is saying one thing and another is saying something totally diff. One poster is saying he has owned over 60 b bods and the 73 and 74s have no front valences. I have to disagree , I think they do, the 71 -2 doors are diff from 73-74s. Just my observation from owning just a several b bods . So who's right here ?????
[Re: moparmarks]
#926496
02/13/11 10:03 AM
02/13/11 10:03 AM
mopar_man
Newfoundland
I never said they didn't have valances.
Sorry . me bad ....but another poster said it .
