Page 1 of 3 1 2 3
Bronze bushing for distributor........ #925591
02/10/11 03:05 PM
02/10/11 03:05 PM
Chicken coop
dustergirl340 Offline OP
Chicken Little
Chicken Little
Chicken coop
We just replaced the bronze bushing that goes into the engine block (small block Mopar) for the distributor, what size does it need to be reamed out to? The distributor shaft is .490 in diameter, I'm assuming a 1/2" would be fine? What do you think? Thanks
Re: Bronze bushing for distributor........ [Re: dustergirl340] #925592
02/10/11 03:14 PM
02/10/11 03:14 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
These don't generally get reamed AND .010 would be too much clearance in a bushing anyway. Ideally they get installed with a special tool that seems to expand the bushing in the hole. However, any I've ever installed in a big block by pulling them in from the bottom never needed any fitting for the shaft afterwards.
Re: Bronze bushing for distributor........ [Re: dustergirl340] #925593
02/10/11 03:16 PM
02/10/11 03:16 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
My comment won't answer your question but will tell the story of how the bushing was/is meant to be 'burnished' after installation. Back in the day the dealers had a special tool that did the job. Once burnished the bushing not only fit the dist shaft but it fit tightly to the block.
If reamed to fit the dist shaft the bushing could eventually spin in the block. AND this did happen often.
Re: Bronze bushing for distributor........ [Re: dustergirl340] #925594
02/10/11 09:15 PM
02/10/11 09:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Hi,
You want it tighter than .010" I just checked mine here that has been run and I have maybe .003"
I'd be looking for .015-.003 on the side cleance.
I pressed the gear off this oil pump shaft and have used it when I drove a new bushing in. Stick the shaft in the new bushing and drive it in with a deep socket and extension. Then use a old screw driver chucked in a drill and spin it up. I do use a washer under it, just didn't have one handy for the picture.
So I would advise trying a stock shaft to ream it because it has a real nice taper built into it.
Re: Bronze bushing for distributor........ [Re: Challenger 1] #925595
02/10/11 09:23 PM
02/10/11 09:23 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Great...thanks Gary!
Re: Bronze bushing for distributor........ [Re: dustergirl340] #925596
02/11/11 01:21 AM
02/11/11 01:21 AM
IN
ahy Offline
ahy  Offline
IN
The installation/burnishing tool is available from Mancini and/or Sumit now. As posted, without the tool you risk a loose fit in the block and/or incorrect clearance between bushing and shaft.
I had a "near miss" on a BB bushing installed by a mostly Chevy shop w/o the tool. The bushing was loose in the block and almost spinning and shaft clearance was too tight and the shaft damaged. A new bushing, new shaft and the correct tool borrowed from a friendly Dodge dealer fixed it.
Re: Bronze bushing for distributor........ [Re: ahy] #925597
02/11/11 02:59 AM
02/11/11 02:59 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I took a well used dist shaft and using a grinder, I made a groove lengthwise in the shaft.
It only took a few turns and the groove cut the excess material out and it was a perfect fit.
Cost was free
Re: Bronze bushing for distributor........ [Re: sthemi] #925598
02/11/11 05:08 AM
02/11/11 05:08 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The installation tool.
Make sure you install the bushing on the tool as shown before driving it into the block. The bushing is burnished when you pull the tool through bushing.
Re: Bronze bushing for distributor........ [Re: Snoopy] #925599
02/11/11 02:44 PM
02/11/11 02:44 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
And worth every penny that it costs....
Re: Bronze bushing for distributor........ [Re: sthemi] #925600
02/11/11 04:37 PM
02/11/11 04:37 PM
I took a well used dist shaft and made a groove lengthwise in the shaft. It only took a few turns and the groove cut the excess material out and it was a perfect fit.
Someone (on here) did the same w a cam to fit cam bearings and reported it worked perfect & best way they'd ever found. I'll get the (pictured) tool if necc but if the slot will do it nicely I'm game
Re: Bronze bushing for distributor........ [Re: RapidRobert] #925601
02/11/11 05:20 PM
02/11/11 05:20 PM
Cincinnati, Ohio
Cincinnati, Ohio
I have installed at least 5 or 6 of those bushings over the years and don't remember having any problems doing it. I don't know what the big deal is with the tool?
Re: Bronze bushing for distributor........ [Re: Challenger 1] #925602
02/12/11 04:06 PM
02/12/11 04:06 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ive put in 5 of them over the years without a tool. No problems.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Bronze bushing for distributor........ [Re: Von] #925603
02/12/11 08:35 PM
02/12/11 08:35 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Some aftermarket bushings don't require sizing.
Re: Bronze bushing for distributor........ [Re: Von] #925604
02/13/11 09:28 PM
02/13/11 09:28 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Same here...
Re: Bronze bushing for distributor........ [Re: Von] #925605
02/14/11 12:53 AM
02/14/11 12:53 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
fwiw, my experience has been that the mp 1s are tight, but the pioneer brand 1s i've used don't need purnished. dave
Re: Bronze bushing for distributor........ [Re: 3ddart] #925606
02/14/11 01:50 AM
02/14/11 01:50 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
This has been my experience as well. I've been told you can use an old oil pump drive to drive the tight ones in and then knocking it out burnishes it enough to allow the shaft to spin. A light polish on the shaft will help gain the clearance you would need if it's tight.
Re: Bronze bushing for distributor........ [Re: dodgeboy11] #925607
02/14/11 01:56 AM
02/14/11 01:56 AM
Anyone see a prob w epoxying the OD of the bushing b 4 you drive it in, more security
Re: Bronze bushing for distributor........ [Re: RapidRobert] #925608
02/14/11 03:15 PM
02/14/11 03:15 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Still...The best and proper way is to use the tool to burnish the bushing and seat it to the block. Those here that say differently may be correct as well but I feel that you do it the right way the first time and you eliminate any future problems that might crop up...
Re: Bronze bushing for distributor........ [Re: dodgeboy11] #925609
02/14/11 03:18 PM
02/14/11 03:18 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's what I said, and have done. Nobody had to tell me, I figured it out on my own, like 20 years ago when I was 20 or 30.
Re: Bronze bushing for distributor........ [Re: RapidRobert] #925610
02/14/11 04:20 PM
02/14/11 04:20 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Let us know how it works. No need to over think something as simple as installing the bushing.
Page 1 of 3 1 2 3
