Door Mechanism Attaching Bolts - Removal #921080
02/04/11 04:17 PM
02/04/11 04:17 PM
Oakville, Ontario, Canada
CDN72SE Offline OP
CDN72SE  Offline OP
Hello All,
Just stripping down the doors on my Charger, removing the trim, door handles, etc. My Phillips screwdriver doesn't seem to be doing the job on the 3 bolts (screws) that hold the door mechanism in place, I also have a socket attachment that seems to shallow to get proper grip, I really don't want to round them and then have to drill them out or something. Any ideas? Borrowed a pic from the web. ~ Alan.
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921081
02/04/11 04:25 PM
02/04/11 04:25 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Use a impact screwdriver if there real tight but sometimes you can smack the end of the screwdriver with a hammer to loosen them.
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921082
02/04/11 04:25 PM
02/04/11 04:25 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
You have to have an impact screw driver. You hit it with a hammer and it turns the screw little by little.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921083
02/04/11 04:43 PM
02/04/11 04:43 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Hello All,
Those screws that you show don't have the correct under head shape. They should be countersink or beveled under the head. Whack the screw driver with a hammer as said and then use the correct size screw driver, if you have too attach vise grips to the screw driver for more leverage.
logan426
Re: Door Mechanism Attaching Bolts - Removal [Re: MOPARMIKE69] #921084
02/04/11 04:45 PM
02/04/11 04:45 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
I use my large Snap-on screwdriver which has a six point end near the handle and I put my box end wrench to turn it.
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Door Mechanism Attaching Bolts - Removal [Re: MOPARMIKE69] #921085
02/04/11 04:50 PM
02/04/11 04:50 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thank you guys for the responses I wouldn't have known that. I've basically used only the tools in my small toolbox to strip down my entire car.
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921086
02/04/11 04:56 PM
02/04/11 04:56 PM
N.J. north west
1972challenger Offline
N.J. north west
You may need a Posi-drive screw driver bit. If the screws have small hash marks in the cross of the slots it's posi-drive. A phillips screw driver will strip out the head of the screw.
Re: Door Mechanism Attaching Bolts - Removal [Re: MLR426] #921087
02/04/11 05:00 PM
02/04/11 05:00 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Hello All,
logan426
Thanks Logan, I borrowed the crew pic from Jim's Auto Parts site.
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921088
02/04/11 05:31 PM
02/04/11 05:31 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use a big phillips head.Put it in then give it a smack with a hammer while turning it.It takes a large one.The impact driver works great too.Just sometimes I dont have it here.Rocky
Chrysler Firepower
Re: Door Mechanism Attaching Bolts - Removal [Re: 1972challenger] #921089
02/04/11 05:35 PM
02/04/11 05:35 PM
CDN72SE Offline OP
CDN72SE  Offline OP
I had to google what that was, lol. I'll have to give that a try as well, thanks.
Re: Door Mechanism Attaching Bolts - Removal [Re: therocks] #921090
02/04/11 05:36 PM
02/04/11 05:36 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks for the input therocks.
Re: Door Mechanism Attaching Bolts - Removal [Re: MOPARMIKE69] #921091
02/04/11 07:44 PM
02/04/11 07:44 PM
QLD Australia
Keith Black® Offline
QLD Australia
Darren Beale
Keith Black Racing Engines®
Re: Door Mechanism Attaching Bolts - Removal [Re: Keith Black®] #921092
02/05/11 09:24 AM
02/05/11 09:24 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
As I said the impact driver is probally best.The big thing is most people dont have a really big phillips.They try to use a small one.I have 2 real big ones.One Craftsman thats probally 30 years old and a SnapOn.Ive removed quite a few with just them.I like the Snapon best because it has a hex head that a wrench fits on.Rocky
Chrysler Firepower
Re: Door Mechanism Attaching Bolts - Removal [Re: therocks] #921093
02/05/11 03:26 PM
02/05/11 03:26 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks again, I'll post my results after I pick up the impact driver.
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921094
02/06/11 12:22 PM
02/06/11 12:22 PM
SE Pa.
LimeliteAero Offline
SE Pa.
does anyone have a source for replacement screws for this application?
Re: Door Mechanism Attaching Bolts - Removal [Re: LimeliteAero] #921095
02/06/11 12:33 PM
02/06/11 12:33 PM
SE Kansas
I
indytex96 Offline
indytex96  Offline
I
SE Kansas
Just be careful when using the driver and a hammer as you can actually bend the door jamb. (Don't ask me how I know)
Re: Door Mechanism Attaching Bolts - Removal [Re: CDN72SE] #921096
02/06/11 12:40 PM
02/06/11 12:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have just used a proper size phillips and a channel lock pliers, many times and never had one I couldn't get out. Don't see a need for hammer impact. The large size phillips is included in the basic tool kits. It has to be in good shape and not a cheap one though.
Re: Door Mechanism Attaching Bolts - Removal [Re: Challenger 1] #921097
02/06/11 01:18 PM
02/06/11 01:18 PM
IMGTX Online content
IMGTX  Online Content
I use the proper size phillips in a socket wrench. I am not sure it's a #4 or #3 or #2 but they sell them in sets.
I TAP it a little first to let it know I mean business then press hard and turn.
Re: Door Mechanism Attaching Bolts - Removal [Re: IMGTX] #921098
02/06/11 01:57 PM
02/06/11 01:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
Yes I agree that is the best tool IMGTX.
Just a couple days ago I cleaned out my storage area above my garage. I found 2 old cardboard boxes that I stored door hardware in. I brought them down and looked em over and put em in a bucket.I kept every peice inside those doors rubber bumpers and all! I was surprised.
Stripped a very rusty red 73 challenger around 1985? I bought it and installed a 340 and drove it for a few years. Then it got too rusty to be safe and I stripped it of every bolt that I unscrew. Then cut up chunks of it each week with my torch and put it out for garbage man each week, A whole car!
Anyway I have ever bumper, guides, window hardware, everything in this bucket for 2 doors.
Like what was said above, those screws shown above are wrong.
Nothing is for sale so please don't PM me. Always happy to post pictures.
Here's the tool I like with a pair of channel locks. It's a #3 phillips.
Re: Door Mechanism Attaching Bolts - Removal [Re: LimeliteAero] #921099
02/06/11 02:00 PM
02/06/11 02:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
as far as dead nuts on correct ? No
but very close is avail.
