trans techs, 97 604 netral switch ??? #918928
02/01/11 05:58 PM
02/01/11 05:58 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
HELLO,i need help asap.. i am working on a 97/98 caravan..build date 9/97 im going to replace the Valve Body when I noticed the Net saftety switches are different between the two VB's.. the original Vb had the bullet/round type switch.. the new VB (replacement) HAS the spade term.. can i just swap the net switch? the sep plate number is 66 on both Vb units.. the rooster comb looks the same..
please
thanks
Don
Trust_me68@yahoo.com
Re: trans techs, 97 604 netral switch ??? [Re: Dakota_Don] #918929
02/01/11 06:01 PM
02/01/11 06:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I don't think they are interchangable.
I remember a tsb or somethign of the likes saying to replace the end of the wiring when updating the VB +/or range sensor switch
Re: trans techs, 97 604 netral switch ??? [Re: gtx6970] #918930
02/01/11 06:14 PM
02/01/11 06:14 PM
Alton, IL
Alton, IL
if there is a way you can find out please let me know..
everything looks the same except the termanals.. but id like to know for sure..
thanks
Don
Re: trans techs, 97 604 netral switch ??? [Re: Dakota_Don] #918931
02/01/11 07:58 PM
02/01/11 07:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I can tell you at the dealer when we would replace some tranny's of certain years they only came in the new style terminals and they came with the updated wire harness end. We had to cut the harness and solder the new connector in. Ron
Re: trans techs, 97 604 netral switch ??? [Re: 383man] #918932
02/01/11 09:26 PM
02/01/11 09:26 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
mopar makes an adapter harness. no cutting required. plug and play.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: trans techs, 97 604 netral switch ??? [Re: 71yelladustr] #918933
02/02/11 04:01 PM
02/02/11 04:01 PM
Alton, IL
Alton, IL
thanks, but i did call and speak to the the VB tech .. and he said all i have to do is swap the switch.. since the VB is out thats what im going to do..
