trans techs, 97 604 netral switch ???
#918928
02/01/11 05:58 PM
02/01/11 05:58 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
HELLO,i need help asap.. i am working on a 97/98 caravan..build date 9/97 im going to replace the Valve Body when I noticed the Net saftety switches are different between the two VB's.. the original Vb had the bullet/round type switch.. the new VB (replacement) HAS the spade term.. can i just swap the net switch? the sep plate number is 66 on both Vb units.. the rooster comb looks the same.. please thanks Don Trust_me68@yahoo.com
Re: trans techs, 97 604 netral switch ???
[Re: 383man]
#918932
02/01/11 09:26 PM
02/01/11 09:26 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
mopar makes an adapter harness. no cutting required. plug and play.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
