Header modification????????
#916800
01/29/11 09:37 PM
01/29/11 09:37 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I love my headers.
I hate the fact that they designed them to hang so low under the car.
To that end they are real close to the ground....
Mostly it hasn't really been a problem other then going in and out of the trailer I have been raising the front of the trailer to get by and just barely.
My first thought was to cut and re weld them but the more I look at that there really isn't any good way to do it and keep everything aligned.
I seem to recall the the last time I brought this up someone saying to heat and bend them up.
Just wondering if that's really a viable option before I go and screw something up.
Re: Header modification????????
[Re: WILD BILL]
#916809
01/30/11 12:33 AM
01/30/11 12:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yes it is.
The headers had the same issues before the plate as they do now.
FWIW, I bolted the motor in with the factory mounts to "locate" it when welding the tabs for the plate.
Bill, anyone have a B engine header you can try... not a RB
[Re: dustergirl340]
#916811
01/30/11 12:43 AM
01/30/11 12:43 AM
WILD BILL
BROOK PARK, OH
Damn dude, better hope your new bullet doesn't cause massive wheelstands, lol
That would probably push em up enough
[Re: WILD BILL]
#916812
01/30/11 01:01 AM
01/30/11 01:01 AM
Posts: 9,875 MI, usa
dvw
MI, usa
You ought to street drive with them that low like I do. Then you would learn to be very careful. remember , how do you know when it's low enough, when it scrapes, how do you know when the tires are big enough,when they rub, how do you know when the cam is big enough, no such thing, just not enough motor. Doug
[Re: WILD BILL]
#916814
01/30/11 01:28 AM
01/30/11 01:28 AM
Posts: 43,295 Bend,OR USA
Cab_Burge
I have used a floor jack and a piece of wood under the headers to raise them No cracking or unsightly damages to the pipes. On your car I would put it up on jackstands under the suspension so it sits like when it is on the ground and get after it, it will probally take four or five trys to get it to stay where you want it, go slowly and take your time, don't be afraid to put tension on the pipes when raising them up, it has to go by the spot under pressure you want them to end up at Oh Yeah, with your luck yours pipes will probally break off at the head flanges or it will rip the heads off of the motor Just kidding don't we love drag racing
