when to put screws in the rims for slicks
#915321
01/27/11 09:23 PM
01/27/11 09:23 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
What is the rule of thumb of when to put screws in the rims when using slicks ? what ET or power level or always? Also what if you don't would it cause problems with valve stem on the tubes tearing off ? thanks
1969 Dodge Charger
1969 Dodge Superbee
Re: when to put screws in the rims for slicks
[Re: cjs69mope]
#915323
01/27/11 09:29 PM
01/27/11 09:29 PM
Posts: 8,165 Left Coast
BobR
Left Coast
If I use slicks I use screws-especially if you are using tubes.
[Re: BobR]
#915324
01/27/11 09:36 PM
01/27/11 09:36 PM
Posts: 1,377 Ohio
Todd
Ohio
Good question. Im new to this racing in a strait line and was wondering the same thing.
What if your not running tubes? Size of tire and pressure comes into play?
[Re: BobR]
#915325
01/27/11 09:37 PM
01/27/11 09:37 PM
Challenger 1
Cincinnati, Ohio
OT a little, Why use tubes anymore? Not being a smartazz as usual. Just asking? as I think tubeless is safer with screw in metal valve stems.
[Re: Challenger 1]
#915326
01/27/11 09:45 PM
01/27/11 09:45 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Personally i like running tubes,,,sidewall seems stiffer,,,tires hold air longer,,,not sure what the downside to tubes are,,,other than weight,,,,
[Re: 69CHARGERMD]
#915327
01/27/11 10:00 PM
01/27/11 10:00 PM
Posts: 12,025 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I personally do not screw my rims since I stopped using tubes. Is there any reason anymore to screw the tires on unless you're running tubes?
Master, again and still
[Re: 69CHARGERMD]
#915328
01/27/11 10:08 PM
01/27/11 10:08 PM
Posts: 2,679 owt west
Thread Ender1
owt west
Car should 60ft better without tubes from what i hear.
[Re: Thread Ender1]
#915329
01/27/11 10:10 PM
01/27/11 10:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I can tell you my car 60s better without tubes and it was done 2 weekends back to back same tire and weather conditions.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: bigdad]
#915332
01/27/11 10:18 PM
01/27/11 10:18 PM
Posts: 1,377 Ohio
Todd
Ohio
My car has gone 9.942 @ 135.9 weighs 3770 with me , best 60 so far was 139.9
I have no tubes, no screws, tires have never moved
Awesome car!!! Love those early B's. What size are your tires and at what pressure?
[Re: Todd]
#915333
01/27/11 10:24 PM
01/27/11 10:24 PM
Posts: 34,878 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
16x32's seems to work best @ 8 3/4 lbs ..iffy tracks I drop it 1/4 lb
I'll get out in some cool spring air and it should pickup some more
[Re: Todd]
#915334
01/27/11 10:26 PM
01/27/11 10:26 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
So it is ok to run a tire that the manufacturer recommend a tube for without a tube ?
1969 Dodge Charger
1969 Dodge Superbee
[Re: sam64]
#915338
01/27/11 10:51 PM
01/27/11 10:51 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
They had bead locks on it in Tulsa Meh' I don't know , I find it hard to believe that 5-6 little #10 screws with the tapered end sticking into the tire bead maybe and 1/8 of an inch matters in anyway But, it is up to those to decide for themselves My tires have never moved any, none, zero,zip,zilch,nada But they rims are 15 inches wide and the tires are 16 inches wide so that may matter too
[Re: cjs69mope]
#915339
01/27/11 11:05 PM
01/27/11 11:05 PM
Posts: 7,506 Az
Crizila
Az
There is no answer to this question. Too many variables. Monitor them. When you see them start to slip on the wheel, thats the time to screwem.
Fastest 300
[Re: cjs69mope]
#915340
01/27/11 11:14 PM
01/27/11 11:14 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
We talked about putting screws in wheels at the Dave Morgan Chassis Seminar that I attended. There are a lot of factors to consider that get over looked. Things I would have never thought of.
For starters, You want to "Index" your screws. Basically, where ever you put a screw on the front side of the wheel, make sure you put the screw on the back of the wheel directly across from the screw on the front of the wheel. If the screws are staggered , this will cause the car to "wonder". Mis-aligned (staggered) screws tend to want to "twist" the tire, as the tire is being pulled from those points at where it is screwed to the rim.
Here is the best picture I could find in my library. SORRY it isn't a Mopar.
You can see that the wrinkle is pulling from where the screw is on the wheel.
Second, how many screws do you put in the wheel? That depends on how big or small you want the "paddle" of the tire to be. Watch some of the high horsepower cars, and the tracks they make out of the whole. you can see the tire is "paddling" the ground. If the screws are further apart, the "paddle" is bigger, the closer the screws are, the smaller the paddle it.
for example....
5 screws around the diameter of the wheel will make for large paddles, but fewer paddles (4 paddles)
10 screws around the diameter of the wheel will make for smaller paddles, but more paddles (9 paddles)
What is the right amount of screws for a car? That I don't know. I personally haven't run screws. My tires seem to hook up just fine with out them.
-Kenny
[Re: cjs69mope]
#915342
01/27/11 11:20 PM
01/27/11 11:20 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I run screws in every bias ply tire I run(havn`t tried radials yet)so as to keep the tire from slipping on the rim and to help keep the bead seated. No tubes EVER for me and they leak very little when it sits for a couple of weeks. Next step............bead locks; Can`t imagine the high hp 6-second cars NOT running screws or locks.
[Re: sam64]
#915344
01/27/11 11:44 PM
01/27/11 11:44 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I quit running tubes years ago just because I had 2 valve stems rip off the tube and quickly lose air, could be dangerous. I think this happened because the hole in the wheel didn't properly line up with the valve stem on the tube.
I use Dawn dish soap and no tubes, and I use 8 screws on each side of the wheels. I saw a Mustang wreck many years ago from breaking a bead.
I've heard that running 16 screws on each side of each wheel will help stiffen the sidewall.
Also, I recently read that the screw should thread into the wheel, I didn't know that, the holes in my wheels have always been bigger than the screws so the screws just thread into the tire.
340Rick and Bobsprofab turned me onto a stainless screw that has a nice rounded head and uses a square drive bit, they look clean and can even be polished.
[Re: DaveRS23]
#915345
01/28/11 12:33 AM
01/28/11 12:33 AM
BobR
Left Coast
If you have enough power and bite you can knock a bead out and the tire will go flat instantly. The lower the tire pressure the more likely this could happen-especially if you are "driving" the car. That's why faster NHRA cars are required to use beadlock wheels.
[Re: ProSport]
#915346
01/28/11 12:40 AM
01/28/11 12:40 AM
StrokerAspen
Alberta Canada
Running 16 screws each side probably acts like a stiffer sidewall because you are anchoring the tire to the wheel more often, and closer together. I have notices some of the higher powered small tire cars are running more screws.
That "Square bit" screw you speak of is a Canadian invention It is called a "Robertson" Head. I really like them, much easier to use with out striping the head of the screw or the end of your bit.
-Kenny
[Re: ProSport]
#915348
01/28/11 12:43 AM
01/28/11 12:43 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
On new slicks I just soap them up with dawn soap and put them on, run them till the side walls are leaking air to the point that air is needed every day, then install the tubes. I prefer to screw them on. If the tubes are installed properly you won't rip out the stems. Use plenty of tire talc inside a dry clean slick, that means all the soap residue must be flushed out or your tube will stick and rip.
[Re: bigdad]
#915353
01/28/11 02:47 AM
01/28/11 02:47 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
Do they run screws in the rims in NASCAR ?
No they have inner-liners
[Re: SB412DUSTER]
#915354
01/28/11 02:52 AM
01/28/11 02:52 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
This I know but, what keeps the tire on the bead ?
[Re: bigdad]
#915355
01/28/11 07:31 AM
01/28/11 07:31 AM
Quicktree
ties are stiff sidewalls, not anywhere near what we run. they also run steel wheels.
[Re: Quicktree]
#915356
01/28/11 08:50 AM
01/28/11 08:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have done it both ways... no screws and no tubes... I did mark the tire to the stem and mine moved all the time... thing was I never knew if it went a few inches or a few turns... then I switched over to running tubes and screws... this currant set up has yielded my best 60ft with a 1.19 and I think its the stiffer side wall....also I get more runs out of a set of tires... I never get rid of the tires due to being worn out (tread surface) but the side walls giving out and when they start going I see the 60 ft going away. So for me its a better set up all around with tubes and screws..... my opinion is if you have a big tire with low pressure you COULD be asking for problems
[Re: DaveRS23]
#915357
01/28/11 10:37 AM
01/28/11 10:37 AM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
I agree, I have a buddy runnin 8.60's in a 2800# car and when he spent $450 a piece on new rims he sure wasn't gonna drill hole in them. We marked the wheel/rim and it moved about 1/2" after the first pass then never again.
[Re: Monte_Smith]
#915358
01/28/11 11:19 AM
01/28/11 11:19 AM
BobR
Left Coast
I run 9 x 28 M/T's with tubes on an 8 inch rim with 18 lbs of air. They aren't screwed to the rims. Been doing this for the past 6 seasons without any issues. The tubes keep the tire stiffer at launch and all the way down the track.
This is dangerous right here. If the tire ever happens to slip on the wheel, it will likely rip the stem out of the tube and you will be in for a rough ride, straight into the wall. I understand you have done it for 6 years. But all it takes is once.
Personally, I think people are nuts, not to anchor the tire to the rim in some way, but thats just me. Last year at an ADRL race, I saw a driver get after an XTF car too hard in the water and knocked both rear tires off the beads. Thats how fast it can happen
Monte
I really don't know what these guys are thinking. Maybe they just haven't seen this stuff happen themselves.
[Re: bigdad]
#915359
01/28/11 11:20 AM
01/28/11 11:20 AM
BobR
Left Coast
Apples to oranges comparison.
[Re: StrokerAspen]
#915360
01/28/11 12:11 PM
01/28/11 12:11 PM
Posts: 7,506 Az
Crizila
Az
for example....
-Kenny
Good info. Thanks!
Fastest 300
[Re: rebel]
#915363
01/28/11 05:45 PM
01/28/11 05:45 PM
Quicktree
this doesn't compare with my pic showing NO screws at all. somethings not right with this theory.
not exactly sure what you are talking about ? what yours shows is a little low on air pressure, but not real bad
[Re: actionange]
#915364
01/28/11 05:47 PM
01/28/11 05:47 PM
Quicktree
yep I agree with Monte, don't matter how many passes or years you have been doing it you are taking a huge risk for yourself and the car in the other lane. I would refuse to race you.
[Re: Quicktree]
#915365
01/28/11 05:54 PM
01/28/11 05:54 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Find the spot in the rule book that states
Car must run tubes
car must have screws in rims
You goofs still doing dry hops too ?
[Re: bigdad]
#915367
01/28/11 06:01 PM
01/28/11 06:01 PM
Quicktree
Car must run tubes
don't care what it says in the rule book, I will not risk running somebody with tubes and no screws. it's crazy
[Re: Quicktree]
#915368
01/28/11 06:09 PM
01/28/11 06:09 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Car must run tubes
Then you better go thru tech with everyones car and also, you better check their drivetrain to see if there is a failure going to happen soon there too
Good lord
[Re: bigdad]
#915369
01/28/11 06:11 PM
01/28/11 06:11 PM
Quicktree
Car must run tubes
Good lord
whatever,most of the guys I race with knows better than to do stupid things like that.
[Re: bigdad]
#915370
01/28/11 06:11 PM
01/28/11 06:11 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Car must run tubes
Thanks for that Big Dad
[Re: Quicktree]
#915371
01/28/11 06:15 PM
01/28/11 06:15 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Car must run tubes
Good lord
Know better than what ? To disagree with you ?
You really think, if NHRA thought for a 2nd after 60 years that you needed screws, they would not have that in the rule book ?
[Re: Quicktree]
#915372
01/28/11 06:16 PM
01/28/11 06:16 PM
actionange
anywhere@ anytime
So do you inspect every car that lines up against you for EVERYTHING that MIGHT POSSIBLY GO WRONG? I'm estatic to know that I'll never have to race you...maybe my 8 3/4 would break and send shrapnel into your lane too
[Re: bigdad]
#915373
01/28/11 06:22 PM
01/28/11 06:22 PM
Quicktree
Car must run tubes
Good lord
here it is, if you dont think it's dangerous to have tubes in a wheel with nothing to prevent them from shearing off the valve stem somethingb is wrong with you I don't need nhra or anybody else to tell me it's dangerous. I have seen it happen, lucky the tire went down in the pits not on the track at speed.
[Re: actionange]
#915374
01/28/11 06:26 PM
01/28/11 06:26 PM
Quicktree
no, most people have enough sence to know better you know I hope you never have a failure. this is one of those things I would get no pleasure out of saying I told you so.
[Re: actionange]
#915375
01/28/11 06:31 PM
01/28/11 06:31 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I dont have any screws and I never have, I have been through tech over and over and they have never said anything about rim screws. Even though I marked my tires last year and seemed to turn a couple inches each run. I was told if they turned it would break the beads with no tubes? I had tubes in my old slicks and when I bought my new Hoosier Q.T. pro's at the track the Hoosier dealer said dont run tubes!! I have a 8 3/4 to!! 3800lbs I will probly screw them for next year.
67' charger 499 RB
10.57 at 127
[Re: Quicktree]
#915376
01/28/11 06:54 PM
01/28/11 06:54 PM
You really crack me up. I go low 8's with no tubes or screws in a 3300 lb. car. Been running it this way for 12 years. Never had an issue. I run 12.75 lbs. in my TT5 M/T.
Car must run tubes
#915377
01/28/11 06:57 PM
01/28/11 06:57 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Car must run tubes
Lol
well be careful , those tires are going to fly right off the rims !!
[Re: Quicktree]
#915378
01/28/11 06:58 PM
01/28/11 06:58 PM
Well after many months of not agreeing with you. This time with you. Never run a slick with tubes without screws. Valve stem is guranteed to shear off. My buddy that goes as slow as you heared off his valve stems w/o screws.
Car must run tubes
Good lord
[Re: Quicktree]
#915379
01/28/11 07:00 PM
01/28/11 07:00 PM
[Re: bigdad]
#915382
01/28/11 10:37 PM
01/28/11 10:37 PM
Quicktree
Guy on the bullet goes 5.14 and has never used screws or bead locks ..
lets argue some more
geez, what does that have to do with running tubes with out screws
[Re: Quicktree]
#915383
01/28/11 10:43 PM
01/28/11 10:43 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
The topic at hand was slick / screws
Never was tubes, slicks, screws
And , it was also do tires turn and it turned into the tires come off the rims without screws
[Re: bigdad]
#915384
01/28/11 10:50 PM
01/28/11 10:50 PM
Quicktree
well if you had read my post I replied to another post about somebody running tubes with out screws. I have run slicks with out screws but never with tubes in them. although I do think you get a better result with screws and safer to boot.dosn't matter how fast people have gone with out them. take a look at how many people have posted problems with out them. it only takes opnce to have a bad day.
[Re: bigdad]
#915386
01/28/11 11:30 PM
01/28/11 11:30 PM
MR_P_BODY
I will stand by this
I think people run screws in sidewalls ..
Just because
Do they help performance .. ??
No idea
is is safe ???
There is NO rule that says you need to
When NHRA or IHRA demands it and there a long, long history that says they will never ..
No need
Do what ever floats your boat... I KNOW my tire cant pop of the beads.... but then again I run tubes and alot dont believe the tube helps... AGAIN to each their own
[Re: MR_P_BODY]
#915388
01/28/11 11:44 PM
01/28/11 11:44 PM
Quicktree
Just because
No idea
is is safe ???
No need
[Re: poppaj]
#915389
01/28/11 11:47 PM
01/28/11 11:47 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I changed to a new set of rear rims last year and was going to put screws in them ( I run my slicks tubeless and always had used screws)The guy at M/T told me Not to put the screws in, he showed me on the new rims they are now putting a safety bead to keep the tires from braking off the outside bead. Look at the new rims there is indeed a hump on the inside. He said the old spun style rims like super tricks definitly needed screws but not the new designs.
Easy on the dry hops boys !!
[Re: bigdad]
#915391
01/28/11 11:59 PM
01/28/11 11:59 PM
Quicktree
who does that? I have to admit I did a few in the old days but it's been over 20 years ago.
[Re: bigdad]
#915393
01/29/11 12:17 AM
01/29/11 12:17 AM
MR_P_BODY
It means , tires in 2011 are not like they were in ...
And possibly , we have grown to the era that we no longer need to run screws in our rims
Hence , dry hops
Again , there is NO RULES to run screws in the beads
AGAIN.... what ever floats your boat... its your car you do with it as you please... I'll take care of mine
[Re: poppaj]
#915394
01/29/11 12:22 AM
01/29/11 12:22 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
I bought a car with rims like this on it. But it's only on the outside bead. Guess what, all the rims screws were broke off from the previous owner, lol.
[Re: MR_P_BODY]
#915395
01/29/11 12:33 AM
01/29/11 12:33 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Hence , dry hops
It is not about floating my boat
Please , tell me where the rules say you have to run any screws in the rim ?
I just want to abide by the rules
[Re: bigdad]
#915397
01/29/11 12:40 AM
01/29/11 12:40 AM
MR_P_BODY
Hence , dry hops
Guys run bead locks also when not needed... is it for safety.... it is for me.... I KNOW my tire isnt popping off the bead on the hit or if my car gets loose off the line going sideways
[Re: MR_P_BODY]
#915398
01/29/11 12:45 AM
01/29/11 12:45 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Hence , dry hops
I would like to hear an engineer tell us just how many lbs of air pressure holds a tire to the bead
I am not but I'm sure it will amaze you
[Re: MR_P_BODY]
#915400
01/29/11 01:04 AM
01/29/11 01:04 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Sorry but I have seen tires come off the rims when the car was sideways ... your not going to see that occur on mine ... as to what pressure it takes... it s a matter of which has the greater pressure... is it the air pressure inside it or the side loading of the tire going sideways.
You better start screwing those front tires too
then
LAST COMMENT FOR ME ON THIS TOPIC
STAY SAFE FELLAS
[Re: bigdad]
#915401
01/29/11 01:16 AM
01/29/11 01:16 AM
MR_P_BODY
then
STAY SAFE FELLAS
Yeah I figured you'd quit now... since the fronts run about 45# pressure VS my 6.5 to no more than 7# with 14" across and thats not even figuring the total surface area thats on the ground so you better figure out which has the greater load .... but your right this IS my last word on this tread
[Re: MR_P_BODY]
#915402
01/29/11 08:36 AM
01/29/11 08:36 AM
Posts: 2,915 A shed in England
Tig
A shed in England
FWIW I first ran screws on the car when it was running 12's, 29 x 10 Slick on 8 1/2 inch convo pro. @ 10 psi the tyre moved 4 inches on the rim I've done it ever since. I run tubes now for the extra sidewall strength, it does improve the 60ft's, at least on my car. If I'd been running tubes back then I have no doubt I would have torn the valve out of the tube. IMHO for the little time and money it costs it's worth doing for the extra insurance, I've also yet to see a car run slower after screwing the tyre to the rim.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: sjs64polara]
#915405
01/29/11 07:31 PM
01/29/11 07:31 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Big tire+quick 60'+low pressure=screws.
I've always ran screws. Didn't bother to mark the wheels or any of that. If it might be beneficial and it can't hurt and it doesn't cost anything, I just do it, but that's me.
I know my 60' improved a bit and became more consistent when I went to 16 screws per side.
[Re: rebel]
#915406
01/31/11 01:02 AM
01/31/11 01:02 AM
StrokerAspen
Alberta Canada
Not sure what your trying to get at here... No your situation won't compare with this set up BECAUSE your not running any screws. Screws serve the purpose of holding the tire where it is, but they also serve the purpose of controlling the "paddle" of the tire.
[Re: StrokerAspen]
#915407
01/31/11 01:27 AM
01/31/11 01:27 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Used to run screws with slicks, now I just glue the drag radials because they use alot more air presure.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#915408
01/31/11 01:37 AM
01/31/11 01:37 AM
dartman366
Mt. Vernon, Ohio
Years ago I ran slick's and did not screw the rim's, twice I ripped the stem out, finally drilled and screwed the rim's and have not ripped a tube since, so now you know my opinion.
