when to put screws in the rims for slicks
#915321
01/27/11 09:23 PM
01/27/11 09:23 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
What is the rule of thumb of when to put screws in the rims when using slicks ? what ET or power level or always? Also what if you don't would it cause problems with valve stem on the tubes tearing off ? thanks
1969 Dodge Charger
1969 Dodge Superbee
Re: when to put screws in the rims for slicks
[Re: cjs69mope]
#915323
01/27/11 09:29 PM
01/27/11 09:29 PM
Posts: 8,165 Left Coast
BobR
Left Coast
If I use slicks I use screws-especially if you are using tubes.
[Re: BobR]
#915324
01/27/11 09:36 PM
01/27/11 09:36 PM
Posts: 1,377 Ohio
Todd
Ohio
Good question. Im new to this racing in a strait line and was wondering the same thing.
What if your not running tubes? Size of tire and pressure comes into play?
[Re: BobR]
#915325
01/27/11 09:37 PM
01/27/11 09:37 PM
Challenger 1
Cincinnati, Ohio
OT a little, Why use tubes anymore? Not being a smartazz as usual. Just asking? as I think tubeless is safer with screw in metal valve stems.
[Re: Challenger 1]
#915326
01/27/11 09:45 PM
01/27/11 09:45 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Personally i like running tubes,,,sidewall seems stiffer,,,tires hold air longer,,,not sure what the downside to tubes are,,,other than weight,,,,
[Re: 69CHARGERMD]
#915327
01/27/11 10:00 PM
01/27/11 10:00 PM
Posts: 12,036 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I personally do not screw my rims since I stopped using tubes. Is there any reason anymore to screw the tires on unless you're running tubes?
Master, again and still
[Re: 69CHARGERMD]
#915328
01/27/11 10:08 PM
01/27/11 10:08 PM
Posts: 2,679 owt west
Thread Ender1
owt west
Car should 60ft better without tubes from what i hear.
[Re: Thread Ender1]
#915329
01/27/11 10:10 PM
01/27/11 10:10 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I can tell you my car 60s better without tubes and it was done 2 weekends back to back same tire and weather conditions.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: bigdad]
#915332
01/27/11 10:18 PM
01/27/11 10:18 PM
Posts: 1,377 Ohio
Todd
Ohio
My car has gone 9.942 @ 135.9 weighs 3770 with me , best 60 so far was 139.9
I have no tubes, no screws, tires have never moved
Awesome car!!! Love those early B's. What size are your tires and at what pressure?
[Re: Todd]
#915333
01/27/11 10:24 PM
01/27/11 10:24 PM
Posts: 34,880 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
16x32's seems to work best @ 8 3/4 lbs ..iffy tracks I drop it 1/4 lb
I'll get out in some cool spring air and it should pickup some more
[Re: Todd]
#915334
01/27/11 10:26 PM
01/27/11 10:26 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
So it is ok to run a tire that the manufacturer recommend a tube for without a tube ?
1969 Dodge Charger
1969 Dodge Superbee
[Re: sam64]
#915338
01/27/11 10:51 PM
01/27/11 10:51 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
They had bead locks on it in Tulsa Meh' I don't know , I find it hard to believe that 5-6 little #10 screws with the tapered end sticking into the tire bead maybe and 1/8 of an inch matters in anyway But, it is up to those to decide for themselves My tires have never moved any, none, zero,zip,zilch,nada But they rims are 15 inches wide and the tires are 16 inches wide so that may matter too
[Re: cjs69mope]
#915339
01/27/11 11:05 PM
01/27/11 11:05 PM
Posts: 7,506 Az
Crizila
Az
There is no answer to this question. Too many variables. Monitor them. When you see them start to slip on the wheel, thats the time to screwem.
Fastest 300
[Re: cjs69mope]
#915340
01/27/11 11:14 PM
01/27/11 11:14 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
We talked about putting screws in wheels at the Dave Morgan Chassis Seminar that I attended. There are a lot of factors to consider that get over looked. Things I would have never thought of.
For starters, You want to "Index" your screws. Basically, where ever you put a screw on the front side of the wheel, make sure you put the screw on the back of the wheel directly across from the screw on the front of the wheel. If the screws are staggered , this will cause the car to "wonder". Mis-aligned (staggered) screws tend to want to "twist" the tire, as the tire is being pulled from those points at where it is screwed to the rim.
Here is the best picture I could find in my library. SORRY it isn't a Mopar.
You can see that the wrinkle is pulling from where the screw is on the wheel.
Second, how many screws do you put in the wheel? That depends on how big or small you want the "paddle" of the tire to be. Watch some of the high horsepower cars, and the tracks they make out of the whole. you can see the tire is "paddling" the ground. If the screws are further apart, the "paddle" is bigger, the closer the screws are, the smaller the paddle it.
for example....
5 screws around the diameter of the wheel will make for large paddles, but fewer paddles (4 paddles)
10 screws around the diameter of the wheel will make for smaller paddles, but more paddles (9 paddles)
What is the right amount of screws for a car? That I don't know. I personally haven't run screws. My tires seem to hook up just fine with out them.
-Kenny
