Page 1 of 5 1 2 3 4 5
when to put screws in the rims for slicks #915321
01/27/11 09:23 PM
01/27/11 09:23 PM
IL . usa
cjs69mope Offline OP
IL . usa
What is the rule of thumb of when to put screws in the rims when using slicks ? what ET or power level or always?
Also what if you don't would it cause problems with valve stem on the tubes tearing off ?
thanks
1969 Dodge Charger 1969 Dodge Superbee
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915322
01/27/11 09:27 PM
01/27/11 09:27 PM
Kissimmee, Florida
aarlucas Offline
aarlucas  Offline
Kissimmee, Florida
I think this is a matter of vehicle weight and power verses ET. I started screwing mine together when I seen the tire move on the rims. I marked both and watched them close. Mine started moving in the low 13's and MPH was 110. My car weighs 3800lbs too.
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915323
01/27/11 09:29 PM
01/27/11 09:29 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
thanks
If I use slicks I use screws-especially if you are using tubes.
Re: when to put screws in the rims for slicks [Re: BobR] #915324
01/27/11 09:36 PM
01/27/11 09:36 PM
Ohio
Todd Offline
Todd  Offline
Ohio
thanks
Good question. Im new to this racing in a strait line and was wondering the same thing.
What if your not running tubes? Size of tire and pressure comes into play?
Re: when to put screws in the rims for slicks [Re: BobR] #915325
01/27/11 09:37 PM
01/27/11 09:37 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
thanks
OT a little, Why use tubes anymore? Not being a smartazz as usual. Just asking? as I think tubeless is safer with screw in metal valve stems.
Re: when to put screws in the rims for slicks [Re: Challenger 1] #915326
01/27/11 09:45 PM
01/27/11 09:45 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Personally i like running tubes,,,sidewall seems stiffer,,,tires hold air longer,,,not sure what the downside to tubes are,,,other than weight,,,,
Re: when to put screws in the rims for slicks [Re: 69CHARGERMD] #915327
01/27/11 10:00 PM
01/27/11 10:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I personally do not screw my rims since I stopped using tubes. Is there any reason anymore to screw the tires on unless you're running tubes?
Master, again and still
Re: when to put screws in the rims for slicks [Re: 69CHARGERMD] #915328
01/27/11 10:08 PM
01/27/11 10:08 PM
owt west
Thread Ender1 Offline
owt west
Car should 60ft better without tubes from what i hear.
Re: when to put screws in the rims for slicks [Re: Thread Ender1] #915329
01/27/11 10:10 PM
01/27/11 10:10 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I can tell you my car 60s better without tubes and it was done 2 weekends back to back same tire and weather conditions.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: when to put screws in the rims for slicks [Re: dusturbd340W5] #915330
01/27/11 10:14 PM
01/27/11 10:14 PM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
My car has gone 9.942 @ 135.9
weighs 3770 with me , best 60 so far was 139.9
I have no tubes, no screws, tires have never moved
Re: when to put screws in the rims for slicks [Re: dusturbd340W5] #915331
01/27/11 10:16 PM
01/27/11 10:16 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I run 9 x 28 M/T's with tubes on an 8 inch rim with 18 lbs of air. They aren't screwed to the rims. Been doing this for the past 6 seasons without any issues. The tubes keep the tire stiffer at launch and all the way down the track.
Re: when to put screws in the rims for slicks [Re: bigdad] #915332
01/27/11 10:18 PM
01/27/11 10:18 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Awesome car!!! Love those early B's. What size are your tires and at what pressure?
Re: when to put screws in the rims for slicks [Re: Todd] #915333
01/27/11 10:24 PM
01/27/11 10:24 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
16x32's seems to work best @ 8 3/4 lbs ..iffy tracks I drop it 1/4 lb
I'll get out in some cool spring air and it should pickup some more
Re: when to put screws in the rims for slicks [Re: Todd] #915334
01/27/11 10:26 PM
01/27/11 10:26 PM
IL . usa
IL . usa
So it is ok to run a tire that the manufacturer recommend a tube for without a tube ?
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915335
01/27/11 10:32 PM
01/27/11 10:32 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
The main reason AFAIK for a tube is to keep the air from leaking out ?
My tires are stiff sidewall , and honestly they hardly leak air
I always ran tubes , and screws and bought into the wives tales myself .
Needed ? Maybe ..but so far so good here !!
Re: when to put screws in the rims for slicks [Re: bigdad] #915336
01/27/11 10:41 PM
01/27/11 10:41 PM
okla.
sam64 Offline
sam64  Offline
okla.
bigdad i don't know if you caught a look at the maroon 65 coronet 500 at tulsa ,i think high 9s.well she popped a slick off the bead on launch at mokan,it was the right rear and it launched hard left ending up in the left lane gaurd rail facing the starting line,not a lot of damage but screws would have saved the day there.they were running slicks no tubes.
Re: when to put screws in the rims for slicks [Re: sam64] #915337
01/27/11 10:47 PM
01/27/11 10:47 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I'D SAY 10'S, i think it would look funny on a 13 sec car,,,like the guys that have a parachute on 12 sec cars
Re: when to put screws in the rims for slicks [Re: sam64] #915338
01/27/11 10:51 PM
01/27/11 10:51 PM
S.E. South Dakota !
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
They had bead locks on it in Tulsa
Meh'
I don't know , I find it hard to believe that 5-6 little #10 screws with the tapered end sticking into the tire bead maybe and 1/8 of an inch matters in anyway
But, it is up to those to decide for themselves
My tires have never moved any, none, zero,zip,zilch,nada
But they rims are 15 inches wide and the tires are 16 inches wide so that may matter too
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915339
01/27/11 11:05 PM
01/27/11 11:05 PM
Az
Crizila Offline
Crizila  Offline
Az
There is no answer to this question. Too many variables. Monitor them. When you see them start to slip on the wheel, thats the time to screwem.
Fastest 300
Re: when to put screws in the rims for slicks [Re: cjs69mope] #915340
01/27/11 11:14 PM
01/27/11 11:14 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
thanks
We talked about putting screws in wheels at the Dave Morgan Chassis Seminar that I attended. There are a lot of factors to consider that get over looked. Things I would have never thought of.
For starters, You want to "Index" your screws. Basically, where ever you put a screw on the front side of the wheel, make sure you put the screw on the back of the wheel directly across from the screw on the front of the wheel. If the screws are staggered , this will cause the car to "wonder". Mis-aligned (staggered) screws tend to want to "twist" the tire, as the tire is being pulled from those points at where it is screwed to the rim.
Here is the best picture I could find in my library. SORRY it isn't a Mopar.
You can see that the wrinkle is pulling from where the screw is on the wheel.
Second, how many screws do you put in the wheel? That depends on how big or small you want the "paddle" of the tire to be. Watch some of the high horsepower cars, and the tracks they make out of the whole. you can see the tire is "paddling" the ground. If the screws are further apart, the "paddle" is bigger, the closer the screws are, the smaller the paddle it.
for example....
5 screws around the diameter of the wheel will make for large paddles, but fewer paddles (4 paddles)
10 screws around the diameter of the wheel will make for smaller paddles, but more paddles (9 paddles)
What is the right amount of screws for a car? That I don't know. I personally haven't run screws. My tires seem to hook up just fine with out them.
-Kenny
