The definition of "I blew up my motor" #914840
01/26/11 10:03 PM
01/26/11 10:03 PM
Land of the Brave, Home of the...
63CandyMatic Offline OP
Re: The definition of "I blew up my motor" [Re: 63CandyMatic] #914841
01/26/11 10:20 PM
01/26/11 10:20 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
wow thats gotta hurt
Re: The definition of "I blew up my motor" [Re: 63CandyMatic] #914842
01/26/11 10:36 PM
01/26/11 10:36 PM
Wild West
M_D Offline
M_D  Offline
Wild West
A little JB Weld and it'll be as good as new.................or not.
Re: The definition of "I blew up my motor" [Re: M_D] #914843
01/26/11 10:55 PM
01/26/11 10:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
wow,thats crazy. looked like the whole block fell out.
Re: The definition of "I blew up my motor" [Re: mopar dave] #914844
01/26/11 11:04 PM
01/26/11 11:04 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Looks like he found the failure point,
Re: The definition of "I blew up my motor" [Re: emarine01] #914845
01/26/11 11:23 PM
01/26/11 11:23 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Re: The definition of "I blew up my motor" [Re: PC-CHARGER] #914846
01/26/11 11:27 PM
01/26/11 11:27 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
Ive seen this happen at a tractor pull.
The announcer called it "an unscheduled high speed engine dis-assembly "
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: The definition of "I blew up my motor" [Re: PC-CHARGER] #914847
01/26/11 11:28 PM
01/26/11 11:28 PM
Apparently not that uncommon.
http://www.youtube.com/watch?v=ICuSgp8er-E&feature=related
Yet still spectacular. I like the block landing right next to the "engine" area, as if you could just hoist it back up into place and fire it up!
Now if it were only that easy.......
Re: The definition of "I blew up my motor" [Re: 63CandyMatic] #914848
01/26/11 11:35 PM
01/26/11 11:35 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Re: The definition of "I blew up my motor" [Re: HEMIDARTS] #914849
01/26/11 11:36 PM
01/26/11 11:36 PM
Lehigh Acres, Florida
rickstershemi Offline
Block just slipped off the pistons....no biggie
Rickster
Re: The definition of "I blew up my motor" [Re: rickstershemi] #914850
01/27/11 01:06 AM
01/27/11 01:06 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i have a feeeling your lucky the block went forward adn not rearward...
because i am not sure the roll bar could have withstood that impact...lol..
the motor almost hit the cieling...
its gotta be a 400lb part...flung 30ft in the air...?
no?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: The definition of "I blew up my motor" [Re: cheapstreetdustr] #914851
01/27/11 01:32 AM
01/27/11 01:32 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Read somewhere else that it was a DT466. If that's the case then there is probably more like 700 pounds of iron flying around.
Mo' Farts
Moderated by "tbagger".
Re: The definition of "I blew up my motor" [Re: Grizzly] #914852
01/27/11 12:30 PM
01/27/11 12:30 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Anybody wonder why there wasn't adaquate motorplate & midplate on that rig?
As mentioned, the driver is lucky it took flight in the direction it did.
There's a reason for safety rules.
Re: The definition of "I blew up my motor" [Re: Dean_Kuzluzski] #914853
01/27/11 12:44 PM
01/27/11 12:44 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I think part of the block is still connected. If you look closely at what is laying on the ground, I believe we are looking at the cylinders from the inside. Perhaps the block just split and it really did jump off the pistons?
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: The definition of "I blew up my motor" [Re: Irun5snd8th] #914854
01/27/11 01:36 PM
01/27/11 01:36 PM
Holly/MI
Holly/MI
Ok, after looking at it some more, it does look like the shortblock, or lower part of the crankcase, is still intact.
Scary.
Re: The definition of "I blew up my motor" [Re: Dean_Kuzluzski] #914855
01/27/11 02:48 PM
01/27/11 02:48 PM
Guitar Jones Offline
That is what happens when you take an engine designed to turn 2500 rpm's max and then twist it 7000.
Re: The definition of "I blew up my motor" [Re: Guitar Jones] #914856
01/27/11 03:56 PM
01/27/11 03:56 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Good old tractor pulling!!!!
Re: The definition of "I blew up my motor" [Re: Diablo] #914857
01/27/11 04:35 PM
01/27/11 04:35 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
those engines are supposed to have cables around them for just that reason
Re: The definition of "I blew up my motor" [Re: jamesc] #914858
01/27/11 07:20 PM
01/27/11 07:20 PM
A little copper coat on the head gaskets and that kind of thing wouldn't happen...
Re: The definition of "I blew up my motor" #914859
01/27/11 08:44 PM
01/27/11 08:44 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
It definitely lifts the cylinders off the block. Here's another video with a shot of the aftermath.
http://www.break.com/usercontent/2009/5/diesel-engine-explodes-at-tractor-pull-729364
