Re: The definition of "I blew up my motor"
[Re: 63CandyMatic]
#914842
01/26/11 10:36 PM
01/26/11 10:36 PM
Posts: 1,361 Wild West
M_D
Wild West
A little JB Weld and it'll be as good as new.................or not.
[Re: PC-CHARGER]
#914846
01/26/11 11:27 PM
01/26/11 11:27 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
Ive seen this happen at a tractor pull.
The announcer called it "an unscheduled high speed engine dis-assembly "
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: rickstershemi]
#914850
01/27/11 01:06 AM
01/27/11 01:06 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i have a feeeling your lucky the block went forward adn not rearward... because i am not sure the roll bar could have withstood that impact...lol.. the motor almost hit the cieling... its gotta be a 400lb part...flung 30ft in the air...? no? cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: Grizzly]
#914852
01/27/11 12:30 PM
01/27/11 12:30 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Anybody wonder why there wasn't adaquate motorplate & midplate on that rig?
As mentioned, the driver is lucky it took flight in the direction it did.
There's a reason for safety rules.
[Re: Dean_Kuzluzski]
#914855
01/27/11 02:48 PM
01/27/11 02:48 PM
Posts: 20,673 in a cattle trailer down by th...
Guitar Jones
That is what happens when you take an engine designed to turn 2500 rpm's max and then twist it 7000. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: jamesc]
#914858
01/27/11 07:20 PM
01/27/11 07:20 PM
A little copper coat on the head gaskets and that kind of thing wouldn't happen... ![](/ubbthreads/images/graemlins/biggrin.gif)
