Page 1 of 3 1 2 3
Crower says no to Synthetic motor oil #912175
01/24/11 12:06 AM
01/24/11 12:06 AM
Glendale Az
Darryls-Demon Offline OP
Glendale Az
A friend told me about this on Crowers web site in there Q@A section, under support.
Crower does Not recommend using synthetic oil for any application, they recommends a non detergent-race only petroleum based 30wt with a ZPP plus additive.
I do not remember a company like Crower saying not to use synthetic oil.
Re: Crower says no to Synthetic motor oil [Re: Darryls-Demon] #912176
01/24/11 01:19 AM
01/24/11 01:19 AM
Winterpeg, Canada
hvyweight Offline
hvyweight  Offline
Winterpeg, Canada
this should be good!
Re: Crower says no to Synthetic motor oil [Re: hvyweight] #912177
01/24/11 02:25 AM
01/24/11 02:25 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Re: Crower says no to Synthetic motor oil [Re: Labratt] #912178
01/24/11 10:55 AM
01/24/11 10:55 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I had the same sort of conversation with Richard Iskidarian about scuffing on the body of my red zones.
Re: Crower says no to Synthetic motor oil [Re: The Shadow] #912179
01/24/11 10:58 AM
01/24/11 10:58 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
There was a time that in the Mopar Bible they recommended that synthetic not be used. We don't use it in our race car.
Re: Crower says no to Synthetic motor oil [Re: BobR] #912180
01/24/11 11:22 AM
01/24/11 11:22 AM
Az
Crizila Offline
Crizila  Offline
Az
Crower and Iski need to turn the page.
Fastest 300
Re: Crower says no to Synthetic motor oil [Re: Crizila] #912181
01/24/11 11:34 AM
01/24/11 11:34 AM
detroit area
moderncylinder Offline
detroit area
they say it doesnt "cling" to the parts as well as conventional oil,, it runs off therefore not lubricating as well
mark williams tells you not to run synthetic gear lube either
Re: Crower says no to Synthetic motor oil [Re: moderncylinder] #912182
01/24/11 11:50 AM
01/24/11 11:50 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I ran synthetic in my 8.75 a several of years ago, and did not like the scuffed look on the teeth, switched back to dino oil and problem went away.
Re: Crower says no to Synthetic motor oil [Re: moderncylinder] #912183
01/24/11 12:15 PM
01/24/11 12:15 PM
ill
dennismopar73 Offline
ill
yeah i would never run the stuff
it wear youre stuff out,,
rot youre teeth,
make you have bad breath
give you gas,,
mm nope wont run it
Re: Crower says no to Synthetic motor oil [Re: dartman366] #912184
01/24/11 12:15 PM
01/24/11 12:15 PM
Guitar Jones Offline
I've used nothing but synthetics for well over 10 years now without a problem and my engine has a flat tappet cam in it. I can tell the difference in just the way the engine idles from synthetic to dino oil of the same viscosity. I use dino oil to clean up my engine after sitting for extended periods like a year or more and then change to synthetic. It's an instant 200 rpm increase.
From what I've heard and read on the interweb synthetic clings better than dino oil.
Re: Crower says no to Synthetic motor oil [Re: Guitar Jones] #912185
01/24/11 01:18 PM
01/24/11 01:18 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I've been running it for 15 years. The only time I run conventional oil is for break in. I did just switch to Brad Penn semi syn. lately.
My bearings have always looked good when the motor came apart for rebuild unless there was another problem.
Re: Crower says no to Synthetic motor oil [Re: Guitar Jones] #912186
01/24/11 01:59 PM
01/24/11 01:59 PM
Locomotion Offline
Locomotion  Offline
First couple of times I thought something was wrong with the carb or inside the engine.....till I put the synthetic in after break-in. My engine, trans and differential builders have had only compliments on how well my stuff wears with the Amsoil synthetics I've been using.
Amsoil source and info
Re: Crower says no to Synthetic motor oil [Re: Crizila] #912187
01/24/11 02:05 PM
01/24/11 02:05 PM
GA
Boosted Offline
Boosted  Offline
GA
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Crower says no to Synthetic motor oil [Re: Boosted] #912188
01/24/11 02:27 PM
01/24/11 02:27 PM
As far as synthetic engine oil clinging to parts when it sits very long(week or more) Mobil oil got sued 15 or 20 yrs. ago over the thier Mobil 1 synthetic aircraft oils causing cams to go bad in Contintental air cooled and liquid cooled aircraft engines. Mobil CO. quit making and selling that oil and payed many aircraft owners millions of dollars for new motors One of the other problems with that oil( I used it for many years and dind't have any cam problems in my Lycoming motor, my cam was located in a different location than in Contintentals ) is that Mobil 1 AV oil wouldn't keep dirt particles in suspension long enough so the oil filter could clean it out, that oil would leave and make nasty sludge deposits in the motor That airplane had ran Phillips brand aviation brand multi viscosity(SP?) oil in it for several hundred hours before I bought it, I switched it to Mobil one on the first oil change and ran it for 6 or 7 yrs, I did have one valve cover off when I first bought it and it was spotless inside, not so 6 yrs later I changed oil and filter every 50 hours or sooner I switched to Shell multi viscoty avaition oil and started running Marvel mystery oil in it to clean the sludge out, that worked eventually All multi weight oils have synthetic polymers in them to make the oil change viscoty
Re: Crower says no to Synthetic motor oil [Re: Boosted] #912189
01/24/11 02:30 PM
01/24/11 02:30 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Just like the petroleum, all synthetics are not the same.
Re: Crower says no to Synthetic motor oil [Re: CMcAllister] #912190
01/24/11 03:15 PM
01/24/11 03:15 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
conventional im to cheap to change synthetic after every weekend of racing
Re: Crower says no to Synthetic motor oil [Re: sturmenater] #912191
01/24/11 03:58 PM
01/24/11 03:58 PM
You'll probably crap when I tell you I run mine all season without changing the oil and filter.
Re: Crower says no to Synthetic motor oil [Re: Guitar Jones] #912192
01/24/11 05:32 PM
01/24/11 05:32 PM
organ
maximum entropy Offline
organ
fascinating. i've used both synthetic and conventional with excellent results either way. mosier specified conventional in my mosier 60, but they couldn't tell me why.
Re: Crower says no to Synthetic motor oil [Re: maximum entropy] #912193
01/24/11 10:44 PM
01/24/11 10:44 PM
Glendale Az
Glendale Az
The 440 in my Challenger lost a 100 RPMs when changing to a petroleum based oil of the same weight.
I cannot rap my head around that a full synthetic oil is harmful to the life of my motor.
Re: Crower says no to Synthetic motor oil [Re: maximum entropy] #912194
01/24/11 11:51 PM
01/24/11 11:51 PM
North Branch, MI, USA
notchbackcuda Offline
My Strange S60 had a sticker on it warning against synthetic lube.
Page 1 of 3 1 2 3
