Page 3 of 4 1 2 3 4
Re: 1100 HP out of a N/A small block [Re: BobsProFab] #912040
01/28/11 06:39 AM
01/28/11 06:39 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I don't think a P7 will get there, most of the Pro Stock stuff in Australia I don't believe has tipped over the 1100hp mark as yet. most are running with around 1050-1070hp and are running all the tricks in the book at 400 cubes. 10K may be harder on springs than you think.
Keep us posted on how you go Bob,
Alan Jones
Re: 1100 HP out of a N/A small block [Re: LA360] #912041
01/28/11 08:37 AM
01/28/11 08:37 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
bob still going right way, other than probily would be useing the endor PSI springs, as these are desing for 10,000 rpm jg309
Re: 1100 HP out of a N/A small block [Re: Leon441] #912042
01/28/11 01:25 PM
01/28/11 01:25 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Got a couple sets of P7's that I am really really attached to. But, I know of a certain 468 short block that would definately incourage me to change my mind.
Sorry Leon!! I got to hang on to it!!!
Re: 1100 HP out of a N/A small block [Re: DakFink] #912043
01/29/11 11:42 AM
01/29/11 11:42 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
This is gonna be one cool build Bob.
Re: 1100 HP out of a N/A small block [Re: BobsProFab] #912044
05/08/11 02:03 AM
05/08/11 02:03 AM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
went up to Milan last night for the AM class to meet John from JTS to watch him tune on his lastest small block build.
440 inch with Slawko heads
best pass was a 8.11 @ 167 mph with a race weight of 2890 lbs on a tricky track after the rain, reading the info from the data it was spining in high gear and BK was pulling timing out to launch it on a 29.5 x 10.5 non W.
this is a single carb N/A combo with more in it.
BK is the man taking the win last night !
cant wait till mine is done
Re: 1100 HP out of a N/A small block [Re: BobsProFab] #912045
05/08/11 07:58 AM
05/08/11 07:58 AM
gregsdart Offline
gregsdart  Offline
Good luck on the combo and your quest! I wish I had the $$ to compete at that level, I am sure it will be a ton of fun.
Re: 1100 HP out of a N/A small block [Re: BobsProFab] #912046
05/08/11 08:25 AM
05/08/11 08:25 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
My money is on Butch for the 1st 7.99 All Motor Pass at Milan. I had to work late Friday & missed the race. I will not miss the next one. June's race is gong to be Killer!!
Re: 1100 HP out of a N/A small block [Re: STEFF] #912047
05/08/11 10:16 AM
05/08/11 10:16 AM
IN
Dartman928 Offline
Dartman928  Offline
IN
I missed the first one also.....I can't wait for next month
Re: 1100 HP out of a N/A small block [Re: Dartman928] #912048
05/08/11 11:10 AM
05/08/11 11:10 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Hey Bob, who cares if it can't be done? I say do it anyway cause thats how innovation happens. You might find what others have not plus if nothing else, you'll learn lots from the experience. Then when you get through, take the car to some races in the South so I can come watch lol
Adriel Paradise
Substation Design Engineer III
Re: 1100 HP out of a N/A small block [Re: BobsProFab] #912049
05/08/11 12:19 PM
05/08/11 12:19 PM
Get-X Offline
Get-X  Offline
I think Pettiwitt (sp?) went 8.06 with the Chevelle. That was with a 1.18 60' so it ain't gonna hook much harder than that. Chris said the da was about 1000', so they will probably see better air later on. I wouldn't rule out Vince Khoury, he was running teens and also has the potential to get it done. Should be interesting to see who gets to the 7's first.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 1100 HP out of a N/A small block [Re: Get-X] #912050
05/08/11 12:28 PM
05/08/11 12:28 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
These guys are flying no doubt.
What are they using for transmissions?
Leon
Re: 1100 HP out of a N/A small block [Re: Leon441] #912051
05/08/11 12:43 PM
05/08/11 12:43 PM
STEFF Offline
STEFF  Offline
Leon
I know Butch Kemp is a long time Pro Flite user. Not sure of anyone else.
Re: 1100 HP out of a N/A small block [Re: STEFF] #912052
05/08/11 10:21 PM
05/08/11 10:21 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
that motor in butch kemp's car is a sm blk sb2 built by jeremy shannon @ extreme engines here in LI NY its a cast intake also it went 8.11's @ 174mph... ps there's a sm blk here on moparts i wont say who,that has a stock blk 340 in it,,and it halls the mail pretty well also.
Re: 1100 HP out of a N/A small block [Re: Leon441] #912053
05/09/11 05:04 PM
05/09/11 05:04 PM
Get-X Offline
Get-X  Offline
Leon
I think it's a Rossler T-400 in the Chevelle. Liberty in Khoury's deal.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 1100 HP out of a N/A small block [Re: Al_Alguire] #912054
05/10/11 10:40 AM
05/10/11 10:40 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I think the PS truck engines were there a long time ago Just bring your wheelbarrel full of dead presidents and let the games begin!
Those would be the P5 heads.
I know for a fact that the 358's didn't make 1100 HP.
Re: 1100 HP out of a N/A small block [Re: BobR] #912055
05/10/11 11:01 AM
05/10/11 11:01 AM
San Angelo, Texas
W8n2DustU Offline
W8n2DustU  Offline
San Angelo, Texas
The Ritter block with the P5 head at 434" and two carbs would do it pretty easily I would think. Even at 410" should be no problem. Call Patterson up and talk to him. He told me to find a set of heads and he would build me one for a turbo application. The P7 would be my second choice.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: 1100 HP out of a N/A small block [Re: fishy340] #912056
05/10/11 11:12 AM
05/10/11 11:12 AM
detroit area
moderncylinder Offline
detroit area
i dont think butch went 174mph,, he went 5.162 @ 133.80
at the 1/8th,, that would be a 40 mph gain in the "big end",, which would be impossible for him n/a and an auto,, i thought i was told he went 164-165 or around there,, i think thats a solid 1000hp
Re: 1100 HP out of a N/A small block [Re: moderncylinder] #912057
05/10/11 11:20 AM
05/10/11 11:20 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The 174mph number was caused by faulty timing equipment. Kemp does not claim to have ran that number
Re: 1100 HP out of a N/A small block [Re: joshking440] #912058
05/10/11 12:08 PM
05/10/11 12:08 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
X2 That's what I heard too...too bad I sent out about 3 text right after I saw that 174.95 MPH. I think the fastest MPH last Friday was by Khoury, in the BBC-powered grey Mustang, which was 170. I think the next few runs Kemp settled in around 166+ MPH.
Re: 1100 HP out of a N/A small block [Re: HardcoreB] #912059
05/10/11 01:01 PM
05/10/11 01:01 PM
OHIO,USA,43154
johnl1961 Offline
johnl1961  Offline
OHIO,USA,43154
I have a spread port small block head that is in R&D as we speak!
We are looking for big things out of this head! We will offer a intake as well as a cam!
Page 3 of 4 1 2 3 4
