Page 3 of 5 1 2 3 4 5
Re: A ?? for actual bracket racers!! [Re: Plumcrazyracing] #911257
01/23/11 09:22 PM
01/23/11 09:22 PM
Super Scamp Offline
Super Scamp  Offline
I like to run off the top bulb or if I miss that I can bump down or If I really mess up I can leave off the bottom busting bulb, just like I did before I installed the badest box ever.
Just One Man's Opinion Mopar Mafia Racing
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911258
01/23/11 09:22 PM
01/23/11 09:22 PM
Tucson, Arizona
johnnyrotten Offline OP
Tucson, Arizona
I have run my no box car in both, and will continue to do so. But there are dozens of local hot rod types that just run the occasional test and tune, we need those guys to be bracket racers. Rolling us all together keeps them away. PERIOD At least until you have the sickness. AL, come on down, I live close to the track and have plenty of room!! It's an easy trip with the bypass open now.
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911259
01/23/11 10:02 PM
01/23/11 10:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Really??? Leaving off the flash of a top bulb doesn't help? And the double hit and bumpdown stuff is all to tune the car!!
The original question was one light, one hit. And yes, I've seen many guys screw themselves with cross-overs, bump downs and double hits.
Bottom line is that if you're a decent driver you'll do well in whatever you drive. If you suck, you suck.
If you've already convinced yourself you can't beat a box car before season even starts, take up golf.
Re: A ?? for actual bracket racers!! [Re: slantzilla] #911260
01/23/11 11:17 PM
01/23/11 11:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
exactly, I don't like bump downs. don"t need them
Re: A ?? for actual bracket racers!! [Re: Quicktree] #911261
01/24/11 12:26 AM
01/24/11 12:26 AM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Can someone explain to this electronic DUMMY, exactly and in simple terms what the terms cross-overs,cross talk, bump downs and double hits mean?
Maybe I needs me one o dem dere fancy electrical boxes
codfish
Re: A ?? for actual bracket racers!! [Re: Al_Alguire] #911262
01/24/11 12:40 AM
01/24/11 12:40 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
They are all using a blinder only seeing the bottom bulb and leaving off of it. I do the saem thing when I run Pro in the other car.
Can you explain this? What are you using for a blinder and where is it? Sorry for the hijack
Re: A ?? for actual bracket racers!! [Re: Dart1031] #911263
01/24/11 12:52 AM
01/24/11 12:52 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.biondoracing.com/detailed/crosstalk.shtml
Tony
70 AARCuda Vitamin C
Re: A ?? for actual bracket racers!! [Re: Dart1031] #911264
01/24/11 12:53 AM
01/24/11 12:53 AM
Q
Quicktree Offline
Quicktree  Offline
Q
could be as simple as a piece of tape on ther visor or windshield. just somthing to cover the top 2 lights from view. so they see the bottom bulb only.
Re: A ?? for actual bracket racers!! [Re: Quicktree] #911265
01/24/11 09:05 AM
01/24/11 09:05 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Thanks Tony
Re: A ?? for actual bracket racers!! [Re: Dart1031] #911266
01/24/11 09:34 AM
01/24/11 09:34 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
One of our tracks had a quick 32 doorcar race. It was ok at first but the fast cars quit showing up when the bump got really slow, ie like 7.4x in the 1/8. The race was changed to a quick 16 doorcar and it is much better now with average bump spot of 5.5x
I would suggest you have a quick 16 doorcar electronics class and no electronics class.
Re: A ?? for actual bracket racers!! [Re: MegaDart] #911267
01/24/11 10:01 AM
01/24/11 10:01 AM
NC
440Jim Offline
440Jim  Offline
NC
That sounds reasonable, 2 separate classes.
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911268
01/24/11 10:16 AM
01/24/11 10:16 AM
Guitar Jones Offline
What delay box guy leaves off the bottom bulb? I thought you all left of the top bulb? It's just like a footbrake race, you don't pay attention to the other side of the tree, right?
I leave off the bottom bulb. I only use my delay box (no crossover) to keep from redlighting. And no, I don't pay attention to the other side of the tree, where I race you can only see the top bulb on the other side.
Re: A ?? for actual bracket racers!! [Re: Guitar Jones] #911269
01/24/11 12:20 PM
01/24/11 12:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
It's called cross talk, try it...We have a few cars with boxes that dont use cross talk either, I never understood why. They lite the top bulb of the faster car when the slower cars tree starts. Just ad the 1.00 to the box. Give it a try you may like it. You dont have to cross over to do it, incase you dont have a box with crossover capabilities. But to each his own.
On the blinder deal, just design something that works. We simply use the factory visor/extension in the car and some head movement to blind the tree.
Re: A ?? for actual bracket racers!! [Re: Al_Alguire] #911270
01/24/11 12:48 PM
01/24/11 12:48 PM
I don't use it for two reasons, one I also run pro et where a transbrake and two step is allowed but no delay box. I adjust my reaction time with the two step rpm and the button. And two is because I don't have a crossover delay box and I'm, not going to be doing the math every round, too much chance for error plus it screws up my routine and I will get confused.
Top bulb racing = let go of the button on the top bulb then stand on the throttle.
Bottom bulb racing = stand on the throttle on the top bulb and let go of the button on the bottom bulb.
Re: A ?? for actual bracket racers!! [Re: Al_Alguire] #911271
01/24/11 01:08 PM
01/24/11 01:08 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
This is always a heated discussion. The average rt of the delay box class is almost always better than the no box and or foot brake class. That being said, there are drivers in the no box category that can and do have better averages than many of the box racers. Why? Because when you miss with a box its typically a bunch. Now that being said what you guys that have never used a box might not realize is that these things are alot more than just a plain delay anymore. Like the pro stage stuff where the throttle falls to the floor and all you have to do is worry about bumpin in consistent and let go on the first flash of anything. And then there is the bumpdown. Oh crap I missed it and start banging on the bumpdown taking .01 out on every hit of that button. Seen a racer that took .08 out bumping down. He would have been .100 on the tree and ended up .020 and won the rd. It is not a level playing field even though there are guys that can compete. I feel that I am one of those guys; but I would venture to say that the percentage of guys that can average an actual .020 or better without a box is much lower than with. Where I find the real disadvantage is the consistency of the cars. The vast majority of footbrake non delay cars are back halved cars at most that are much less consistent than the dragsters and tube chassis cars. Big disadvantage! You rarely chase these cars. Disadantage for two reasons. First chance to red light and you dont have the race out in front of you.
Bottom line is that consistently the bottom bulbers are going to be at a disadvantage. But the great thing is that on any given day we can take out the box cars. I really like the races that separate the bottom from the top until the final. I really like my odds on a one shot deal! Of course by that time you really have your car dialed in typically.
And keep in mind that there are always exceptions to the rule but as a general statement that includes the not so good footbrake and no box guys we are at a disadvantage.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: A ?? for actual bracket racers!! [Re: Irun5snd8th] #911272
01/24/11 01:24 PM
01/24/11 01:24 PM
No. cal., sacramento usa
speedy383 Offline
speedy383  Offline
I have a custom bilt blinder,i can split the last bulb to see it full,half or a sliver.The last time i raced last year (night)i was picking up just a sliver of the bulb ,10runs ,worst .032 best .012 ave. .024 no red lights..If i was running super pro on this night i woulb be lucky to win a round. I was parked with 3 10.90 regulars running super pro,there combined ave was .012 over 22 runs. I can win rounds in super pro at small events, small tracks,but at a competitive race against the regular .90 boys i would be toast without a delay box. I dont know any heavy hitters out here in no box that do not blind the tree.I also agree that a good racer can win in any class and some cant win period.
Re: A ?? for actual bracket racers!! [Re: speedy383] #911273
01/24/11 01:33 PM
01/24/11 01:33 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Speedy383 makes a good point. If we are talking guys at the no box nationals and or the Jegs US open. Its different than talking guys at the local track level. You have to be set on kill at those events. My brother finished 2nd in points at our local track and I can assure you that his average for the year is .025-.03 worse than mine if not more.
Re: A ?? for actual bracket racers!! [Re: speedy383] #911274
01/24/11 01:38 PM
01/24/11 01:38 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I'm a box guy and there is an advantage with a box, no doubt. Taking the "if you suck, you suck" out of the equation, the box guys are usually better because of a more pure reaction leaving off the top bulb and being able to bump down. But if you chassis isn't right in a door car or dragster, RT will move around. And it's a disadvantage when you can't leave off of the opponent's tree because of the flashing dirty light. Under those circumstances I leave on the bottom and take my chances. Also shielding the 2 top bulbs was how I ran before switching to the box.
Re: A ?? for actual bracket racers!! [Re: Dart1031] #911275
01/24/11 01:56 PM
01/24/11 01:56 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
here's how I do it.... I velcro a piece of cardboard to my visor in the right lane, and my rear-view mirrow in the left
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: A ?? for actual bracket racers!! [Re: StripeHOG] #911276
01/25/11 01:06 AM
01/25/11 01:06 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Thanks again on the blinder info guys I just look at the bottom bulb, but never thought of using a blinder
