Page 1 of 5 1 2 3 4 5
A ?? for actual bracket racers!! #911217
01/23/11 12:59 AM
01/23/11 12:59 AM
Tucson, Arizona
johnnyrotten Offline OP
Tucson, Arizona
I was having a discussion with our new track operator and some racers tonight and this question came up. How much of an advantage do you think someone has in a bracket race with a delay box? NO crossover/crosstalk, just a single hit on a .500 full tree.? Don't care about the throttle stop at this point. He is having a quick 32 door car race, but it's open for all. I was trying to get some support for a NO electronic quick 32, like transbrake/2step only, race. So let's hear what you think.
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911218
01/23/11 01:05 AM
01/23/11 01:05 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
A huge advantage. You can leave off the top bulb and add or subtract as needed to dial in your reaction time!
Re: A ?? for actual bracket racers!! [Re: cl440] #911219
01/23/11 01:10 AM
01/23/11 01:10 AM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
But I've also seen some local footbrakers hold their own in a box class (local level).
Brian
Re: A ?? for actual bracket racers!! [Re: '72CudaRacer] #911220
01/23/11 01:14 AM
01/23/11 01:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
leaving on the first yellow with a delay will have an advantage...and yes some footbrakers can do a good job...but round after round the delay box will be more consisted..
Tony
70 AARCuda Vitamin C
Re: A ?? for actual bracket racers!! [Re: '72CudaRacer] #911221
01/23/11 01:18 AM
01/23/11 01:18 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Most fast cars have delay boxes .
A .500 tree is painfully slow and its hard to be consistent when you have to sit on the last bulb and wait for it to go out.
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: A ?? for actual bracket racers!! [Re: go green] #911222
01/23/11 03:51 AM
01/23/11 03:51 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
If there is no cross over or cross talk that gives the advantage to the slowest guy. Clean tree.
Re: A ?? for actual bracket racers!! [Re: ChrisJohnston669] #911223
01/23/11 11:33 AM
01/23/11 11:33 AM
ky
68roadrunner Offline
ky
i disagree just add the et difference to your delay and leave on the other bulb. poor mans crossover.
to respond to the op, the box will have some advantage, a real fast car would be hard to setup for bottom bulb imo
Re: A ?? for actual bracket racers!! [Re: cl440] #911224
01/23/11 11:36 AM
01/23/11 11:36 AM
Q
Quicktree Offline
Quicktree  Offline
Q
easier to make changes vs adjusting the car.
Re: A ?? for actual bracket racers!! [Re: ChrisJohnston669] #911225
01/23/11 11:38 AM
01/23/11 11:38 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have a friend who has been foot brake bracket racing for almost 20 years. His average reaction time is .02. He won the heritage series in the 10.60 class a couple of years ago and he won all but one race. Typically he dials his car in to run 10.58-10.59 and lifts if he is ahead. he also runs 2 classes one with a .4 tree and the other with a .5 tree. He change front tires from small to big to get his reaction time for each class. In this old man's opinion delay boxes are for people who won't or can't practice enough to get their reactions consistant
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911226
01/23/11 11:41 AM
01/23/11 11:41 AM
NC
440Jim Offline
440Jim  Offline
NC
IMO, it is a big help once you learn to work the tree. The potential (no guarantees) improvement comes from two areas:
1) Reacting to the top bulb (first flash), can be more consistant
2) Adjusting the total RT with a computer is easier and more consistant than adjusting the driver or the car with mechanical changes.
So when you add those together, plus a good driver, the average RT of a delay box class is much better than without it. Roughly 0.010 vs 0.030 comparison, plus or minus. Your mileage may vary...
Ask the track operator to average all the RTs from last years delay box class and the same for the non-delay box class. Then post the results. Even an average from one big race (7-9 rounds) should be enough to make the point.
Re: A ?? for actual bracket racers!! [Re: babarracuda] #911227
01/23/11 11:42 AM
01/23/11 11:42 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sorry but I have to call BS on a .02 average footbrake racing. been doing this deal for far more than 20 years and have never seen a delay box driver much less a footbrake driver with a .02 average. (edit) well maybe so I was thinking .002
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911228
01/23/11 11:44 AM
01/23/11 11:44 AM
NC
440Jim Offline
440Jim  Offline
NC
That is not a NO Electronics example. The transbrake and two step are both electronics.
That is a common mistake.
IMO, if you are going to put electronics in a car, put them all in.
Re: A ?? for actual bracket racers!! [Re: '72CudaRacer] #911229
01/23/11 11:49 AM
01/23/11 11:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Brian
X2
I have no fear of the guys with the boxes. I took a win home one night in a box class and for the final, the guy put my dial in, in his cross over, mine being the slower car with a 340 Cuda vs. a 468 powered Chevette...I tree'd him for the class win that night. They ran box and no box togather for whatever reason, and I weeded thru the whole class for the win.
In a quick 16 or quick 32, those guys use it for traction control off the launch a lot so they can have the throttle come in as the track will hold, so I am not so sure my opinion counts for weekly brackets...
If your on, your on, box or no box. Maybe the box is more consistant, but seat time will gain you that. You have to tweek some mechanical stuff, but I don't see a huge advantage to it if you know your car and where you react.
Re: A ?? for actual bracket racers!! [Re: 440Jim] #911230
01/23/11 11:52 AM
01/23/11 11:52 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
If I were still racing, I would want a no trans brake, no delay box, no throttle stop and no starting line rev limiter. When I started in the 60's, it was all driver and tuner. I hate finish line racing line in the NHRA super classes.
Re: A ?? for actual bracket racers!! [Re: 440Jim] #911231
01/23/11 11:53 AM
01/23/11 11:53 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Go spend a racing day in the tower and look at the reaction times. The averages will reflect what 440Jim has stated. Delay box racers on average will be .02 to .03 better.
The box has also beem credited with making an average or poor bottom bulb racer a good top bulb racer. It takes a lot more discipline to concentrate on the full tree and hit your spot. It also takes more effort to sort out your car so that human reaction and car reaction work together. The delay box was created by Ike Hamma so that he could run Super Pro and Super Gas with the same setup.
Re: A ?? for actual bracket racers!! [Re: 440Jim] #911232
01/23/11 11:59 AM
01/23/11 11:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the difference... around here(this division)
the trans brake isnt called electronics .... like
said if you have a fast reacting car its HARD to
split the last bulb after its out... with the box
its MUCH better and a more consistent light
Re: A ?? for actual bracket racers!! [Re: 68roadrunner] #911233
01/23/11 12:19 PM
01/23/11 12:19 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Alot of us carried calculators in 1985. lol That was part of the original reasoning for shading the tree. At least around here. It's not necessarally the driver that makes a good bottom bulb combo. If the car is off enough that conventional adjustments won't get it tight enough, the only recourse is to spend money. A small percentage of drivers have plain dumb luck with this, and get a reputation for being good, when in fact, their car driver fit was luck. Many, many more go home early.
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911234
01/23/11 02:38 PM
01/23/11 02:38 PM
Tucson, Arizona
Tucson, Arizona
Thanks to those who have responded. I went through about a dozen different logbooks that were lent to me by box/no box racers. Approx. avg for a no box was a .028 and the box was .014. I don't know how tough the competition is in different parts of the country, but there are at least a dozen guys here that go CONSISTENT doube oooooo's.
I consider myself a decent no box racer and if I go .020-.030 for 8-10 passes in a row before screwing up, I'm happy!! Myabe some magic footbrake guy can do better, fly'em out, I'll pay the expenses and let's go. LOL If delay boxes were not a HUGE advantage for consistency why do ALL super classes run them? Of the hundreds of big buck bracket races around the country I think I read about ONE being won by a footbrake racer. And as far as a transbrake and 2 step being an electronic devise, they have been par for the course out west for only 20-25 years or so. Even the street/sportsman/heavy class can run them. Sorry about the long post, and thanks again for the input.
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911235
01/23/11 02:41 PM
01/23/11 02:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
like said the faster the car the more need for a delay box. they will go red leaving off the last bulb. thats why you see them more on super class and faster cars.
Re: A ?? for actual bracket racers!! [Re: johnnyrotten] #911236
01/23/11 02:47 PM
01/23/11 02:47 PM
Tucson, Arizona
Tucson, Arizona
What delay box guy leaves off the bottom bulb? I thought you all left of the top bulb? It's just like a footbrake race, you don't pay attention to the other side of the tree, right?
