Converter bolt question Lock tite?????
#909694
01/20/11 04:43 PM
01/20/11 04:43 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
7/16 - 20 bolts get 65 ft lbs correct? Also I've seen the lock tite post hundreds of times but don't remember the general consensus.... So I'll ask it again Lock tite or not to lock tite on the flex plate to converter bolts
Re: Converter bolt question Lock tite?????
[Re: DemonDust]
#909696
01/20/11 04:52 PM
01/20/11 04:52 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
Personally, we run a glide but I loctite the bolts with red, not going to hurt, but may save a flexplate, if the bolts back out. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Twin Turbo Mower]
#909698
01/20/11 05:02 PM
01/20/11 05:02 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Loctite blue here. I get them as tight as I can.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
#909699
01/20/11 05:02 PM
01/20/11 05:02 PM
Posts: 30,460 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Red here also. Had them in this last time for 2 years no worries. Was fun getting them out.
YOU ever use RED on your mower blades ?
[Re: pittsburghracer]
#909701
01/20/11 05:25 PM
01/20/11 05:25 PM
Posts: 1,288 Oregon
sg66mopar
Blue Loctite on my flex plate to crank bolts. Just a lock washer on my converter to flex plate bolts. The last couple years the trans has been coming out about every 10-15 passes so it needs to be easy. I've never used Loctite on the converter bolts.
[Re: Jacob Pitt]
#909702
01/20/11 05:26 PM
01/20/11 05:26 PM
Posts: 75,074 U.S.S.A.
JohnRR
U.S.S.A.
Same here , done this on many convertors installed behind a Cummins , never an issue .
[Re: dOc !]
#909703
01/20/11 05:41 PM
01/20/11 05:41 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
No need I sharpen them everytime I mow the yard.
[Re: Jacob Pitt]
#909704
01/20/11 06:34 PM
01/20/11 06:34 PM
Quicktree
same here
[Re: Quicktree]
#909705
01/20/11 06:36 PM
01/20/11 06:36 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
Does the blue work better than the red? The blue is weaker, but does it "give" enough to work better in this particular application?
[Re: an8sec70cuda]
#909706
01/20/11 06:46 PM
01/20/11 06:46 PM
Quicktree
red is supposed to be permanent, blue is removable. both will keep them from backing out 1 is harder to take out
#909709
01/20/11 07:51 PM
01/20/11 07:51 PM
dOc !
Florida STAYcation
YOU have a really ruff lawn to mow...
[Re: dOc !]
#909710
01/20/11 08:01 PM
01/20/11 08:01 PM
Twin Turbo Mower
Mt.Vernon IL
2 acers worth of thick grass. I just like to make sure it looks nice. Sharp blades and a walker ztr mower gets the baseball field look.
