Converter bolt question Lock tite????? #909694
01/20/11 04:43 PM
01/20/11 04:43 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
7/16 - 20 bolts get 65 ft lbs correct?
Also I've seen the lock tite post hundreds of times but don't remember the general consensus.... So I'll ask it again
Lock tite or not to lock tite on the flex plate to converter bolts
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Converter bolt question Lock tite????? [Re: DemonDust] #909695
01/20/11 04:51 PM
01/20/11 04:51 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
ALL I have ever done is use RED ...and just tap the wrench with a rubber hammer.
...but I am sure the EXACT-&-Proper-Torque "police" will try and me ..
Re: Converter bolt question Lock tite????? [Re: DemonDust] #909696
01/20/11 04:52 PM
01/20/11 04:52 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
Personally, we run a glide but I loctite the bolts with red, not going to hurt, but may save a flexplate, if the bolts back out. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Converter bolt question Lock tite????? [Re: Mopar_racer_99] #909697
01/20/11 04:54 PM
01/20/11 04:54 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Red here also. Had them in this last time for 2 years no worries. Was fun getting them out.
Re: Converter bolt question Lock tite????? [Re: Twin Turbo Mower] #909698
01/20/11 05:02 PM
01/20/11 05:02 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Loctite blue here. I get them as tight as I can.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Converter bolt question Lock tite????? [Re: Twin Turbo Mower] #909699
01/20/11 05:02 PM
01/20/11 05:02 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
YOU ever use RED on your mower blades ?
Re: Converter bolt question Lock tite????? [Re: dOc !] #909700
01/20/11 05:18 PM
01/20/11 05:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Clean the bolts on a wire where,clean off any oil that may be on them with an oil free cleaner,make sure bolts are dry and apply 271 (red) loctite, and tighten the heck out of them.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Converter bolt question Lock tite????? [Re: pittsburghracer] #909701
01/20/11 05:25 PM
01/20/11 05:25 PM
sg66mopar Offline
sg66mopar  Offline
Blue Loctite on my flex plate to crank bolts. Just a lock washer on my converter to flex plate bolts.
The last couple years the trans has been coming out about every 10-15 passes so it needs to be easy. I've never used Loctite on the converter bolts.
Re: Converter bolt question Lock tite????? [Re: Jacob Pitt] #909702
01/20/11 05:26 PM
01/20/11 05:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Same here , done this on many convertors installed behind a Cummins , never an issue .
Re: Converter bolt question Lock tite????? [Re: dOc !] #909703
01/20/11 05:41 PM
01/20/11 05:41 PM
Mt.Vernon IL
Mt.Vernon IL
No need I sharpen them everytime I mow the yard.
Re: Converter bolt question Lock tite????? [Re: Jacob Pitt] #909704
01/20/11 06:34 PM
01/20/11 06:34 PM
Q
Quicktree Offline
Quicktree  Offline
Q
same here
Re: Converter bolt question Lock tite????? [Re: Quicktree] #909705
01/20/11 06:36 PM
01/20/11 06:36 PM
an8sec70cuda Offline
Does the blue work better than the red?
The blue is weaker, but does it "give" enough to work better in this particular application?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Converter bolt question Lock tite????? [Re: an8sec70cuda] #909706
01/20/11 06:46 PM
01/20/11 06:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
red is supposed to be permanent, blue is removable. both will keep them from backing out 1 is harder to take out
Re: Converter bolt question Lock tite????? [Re: Quicktree] #909707
01/20/11 06:51 PM
01/20/11 06:51 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I use Blue....when I have used red, I have sometimes had to heat the bolts with a propane torch to break them free.
Re: Converter bolt question Lock tite????? [Re: Quicksilver440] #909708
01/20/11 07:48 PM
01/20/11 07:48 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Red!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Converter bolt question Lock tite????? [Re: Twin Turbo Mower] #909709
01/20/11 07:51 PM
01/20/11 07:51 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
YOU have a really ruff lawn to mow...
Re: Converter bolt question Lock tite????? [Re: dOc !] #909710
01/20/11 08:01 PM
01/20/11 08:01 PM
Mt.Vernon IL
Mt.Vernon IL
2 acers worth of thick grass. I just like to make sure it looks nice. Sharp blades and a walker ztr mower gets the baseball field look.
Re: Converter bolt question Lock tite????? [Re: Twin Turbo Mower] #909711
01/20/11 08:06 PM
01/20/11 08:06 PM
Q
Quicktree Offline
Quicktree  Offline
Q
how did we get into mowing grass
Re: Converter bolt question Lock tite????? [Re: Quicktree] #909712
01/20/11 08:10 PM
01/20/11 08:10 PM
organ
maximum entropy Offline
organ
i think the answer is obvious.
Re: Converter bolt question Lock tite????? [Re: dOc !] #909713
01/20/11 08:22 PM
01/20/11 08:22 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I used RED on my dart, when I took everything back out yea it was a little snug but I just added a small cut piece of fence pipe for leverage on the ratchet and unloosened no sweat! Ill use red again
Mopar Performance
