Re: Stock hood friendly hemi intake
[Re: rowin4]
#908927
01/20/11 03:23 AM
01/20/11 03:23 AM
Posts: 3,505 DFW
mr_340
DFW
The Indy 426-2 is fairly flat, so it should be good for hood clearance. Don't know how it works on a street Hemi.
Floyd Lippencott IV
[Re: mt162]
#908929
01/20/11 10:46 AM
01/20/11 10:46 AM
Posts: 2,826 NY usa
540challenger
NY usa
I'm running a 528 and it's a dog with the factory dual plane. Is the stage V intake the best breathing hemi intake that will clear a stock hood? Any good 4 barrel intakes that will clear?
What car is it in????
[Re: bwdst6]
#908932
01/20/11 01:47 PM
01/20/11 01:47 PM
Posts: 123 Indiana
mt162
Indiana
Must be in a '78 New Yorker with 2.73 gears.
Still should go high 11's!
I run the stock shaker hood/scoop on my cuda and have run a Ray Barton single plane with a Dominator as well as a Stage V with two Carters. Both fit but the single plane Dominator was a tight one! I probably lost some ET with the Stage V but I changed so many other things that it would be impossible to tell.
Isn't the Ray Barton intake about 2 or 3 inches taller than the stock intake?
[Re: 540challenger]
#908933
01/20/11 01:59 PM
01/20/11 01:59 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
X 3 , can't even remotely give you an answer with knowing what car with what hood
[Re: JohnRR]
#908935
01/20/11 03:19 PM
01/20/11 03:19 PM
Posts: 123 Indiana
mt162
Indiana
70 Challenger with a ralley hood and the air cleaner is right against the brace with the stock intake and air cleaner. 69 Charger, same thing. I know I could go with a six pack hood, etc but I'm resisting it on these cars. I'm thinking of buying another car so are there models with substantially greater clearance under the hood with a flat hood?
