Stock hood friendly hemi intake #908925
01/19/11 10:19 PM
01/19/11 10:19 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
I'm running a 528 and it's a dog with the factory dual plane. Is the stage V intake the best breathing hemi intake that will clear a stock hood? Any good 4 barrel intakes that will clear?
Re: Stock hood friendly hemi intake [Re: mt162] #908926
01/20/11 02:13 AM
01/20/11 02:13 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I'd like to know also, so I'll give it a bump.
Re: Stock hood friendly hemi intake [Re: rowin4] #908927
01/20/11 03:23 AM
01/20/11 03:23 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
The Indy 426-2 is fairly flat, so it should be good for hood clearance. Don't know how it works on a street Hemi.
Floyd Lippencott IV
Re: Stock hood friendly hemi intake [Re: mt162] #908928
01/20/11 06:31 AM
01/20/11 06:31 AM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
vanke port your stock intake!
Re: Stock hood friendly hemi intake [Re: mt162] #908929
01/20/11 10:46 AM
01/20/11 10:46 AM
NY usa
540challenger Offline
NY usa
What car is it in????
Re: Stock hood friendly hemi intake [Re: 540challenger] #908930
01/20/11 12:11 PM
01/20/11 12:11 PM
Jensen Beach, Florida
pressureangle Offline
Must be in a '78 New Yorker with 2.73 gears.
Why do I torture myself so?
Re: Stock hood friendly hemi intake [Re: pressureangle] #908931
01/20/11 01:11 PM
01/20/11 01:11 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Still should go high 11's!
I run the stock shaker hood/scoop on my cuda and have run a Ray Barton single plane with a Dominator as well as a Stage V with two Carters. Both fit but the single plane Dominator was a tight one! I probably lost some ET with the Stage V but I changed so many other things that it would be impossible to tell.
This post is available in double vision where drunk.
Re: Stock hood friendly hemi intake [Re: bwdst6] #908932
01/20/11 01:47 PM
01/20/11 01:47 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
Isn't the Ray Barton intake about 2 or 3 inches taller than the stock intake?
Re: Stock hood friendly hemi intake [Re: 540challenger] #908933
01/20/11 01:59 PM
01/20/11 01:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
X 3 , can't even remotely give you an answer with knowing what car with what hood
Re: Stock hood friendly hemi intake [Re: mt162] #908934
01/20/11 02:03 PM
01/20/11 02:03 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
Sounds about right. Never actually measured it, myself.
Re: Stock hood friendly hemi intake [Re: JohnRR] #908935
01/20/11 03:19 PM
01/20/11 03:19 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
70 Challenger with a ralley hood and the air cleaner is right against the brace with the stock intake and air cleaner. 69 Charger, same thing. I know I could go with a six pack hood, etc but I'm resisting it on these cars. I'm thinking of buying another car so are there models with substantially greater clearance under the hood with a flat hood?
